Question about Hanns.G Corporation HW173D Monitor
HG281D will not turn on - Hanns.G Corporation HW173D Monitor
Im having issues with the hanns-g hg281d. my screen is always faintly flickering, especially when the screen is on darker colors
i was having same issue.i would turn off monitor for 10 secs. then turn on .and it would not happen for a while .i went to i cable and it now rearly ever happens.
i use this as a external monitor for my laptop for 6 mons.now.
Jan 04, 2011 | Hannspree HW191D LCD Monitor
I have a hanns g hg281d just over a year old. It has started blinking on and off several times when it comes out of sleep mode in the am. Is the power supply going bad? I have talked to other people having...
your monitors pwr supply has been worn down, you need a new one (most just get a new monitor) in order to avoid this problem in the future, make sure the screen is placed in a vell ventilated area, and that you turn the power off every once in a while.
Sep 26, 2010 | Hanns.G Corporation 27.5" Widescreen...
Have a green rectangle about 2 inches by 5 inches in center of screen with yellow letters that say, input signal mout of range. It is A hanns g hg281d monitor
Restart your computer,
and keep hitting the F8 key until a "start-up" menu
(white text over a black background) is displayed.
Choose "Safe Mode" and let Windows start.
Reset the screen-resolution to 800-by-600, and 60 Hertz refresh-rate.
Restart your computer, normally,
and then "tweak" the screen-resolution and refresh-rates that are "optimal" for your monitor.
Aug 09, 2010 | Computers & Internet
My HannsG 28" (HG281D) shuts off the screen intermittently, as if it were overheating and was self-protecting. Power light remains on and steady. I can turn it off and wait a few seconds, when I turn it on...
That happens when the ballast transformer for the backlight overheat. Backlight or cold cathode light function is responsible for the images that you see in the screen.
Unless you are capable of replacing by yourself the parts with the same value and you have the right tools and skill to do it your own.
Otherwise, I suggest you bring your monitor to a credible technician.. or if the unit is still under warranty you can bring that to their service center..
May 20, 2010 | Hannspree HannsG HG281DP 28" LCD Monitor
My Hanns.g monitor 1080P HDM1 has a power problem, when it's turned on either by the power switch or when it's activated by the keyboard, it flashes on & off several times & then goes off, playing...
nfleurat, If nothing wrong with the "on"/"off" switch, then must be the "switch-mode-power-supply"/"CCFL inverter supply" circuit card inside of unit. Look for a possible "thermally intermittant solder connection" and then resolder it. Also, inspect unit for possible "swollen" electrolytic filter capacitors on power supply board. Read more of my responses to other owners in my FIXYA profiles for more options you can use to solve your LCD display problem. 12fixlouie aka louie12fix Good luck on the repair.
Jan 05, 2010 | Hanns.G Corporation Computers & Internet
I have something that looks like jumping hash marks going nearly to the top of my monitor. Video card is GeForce 8600 GT. Monitor is Hanns G 281D. Have had both 18 months and problem is new. Have moved...
Request to follow the article provided in;http://www.redhat.com/docs/manuals/linux/RHL-7.2-Manual/getting-started-guide/s1-q-and-a-xconfig.html
Hope it works for you.
Warm regards,
Anirban Mazumdar
Nov 05, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Have a Hanns G HG281D that has started to go to a
I have had the same problem, but noticed something while moving cables. When I tap on the side of the screen, near the control buttons, it fixes it. You know like in the old days when your tv wasn't working, a good bang on the side of it got it working again? :) Anyway, that tells me it is a loose connection problem, internally, and not a heat problem. I will have to open the thing up to get more detail. Not today.
Mar 16, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Open Questions:
Hanns.G Corporation HW173D Monitor Logo
534 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
giarcnameloc
Level 1 Expert
Jose Pino
 Grubhead
Grubhead
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
