Question about Bosch Nexxt WTMC 3300 Electric Dryer
Dryer runs, but no heat. No clog. - Bosch Nexxt WTMC 3300 Electric Dryer
  • 37 Answers
Sounds like the heating element is bad. if so unhook dryer pull out from wall remove acess panel on back. after you remove plate the element looks like a coiled spring looking wire put a ohm meter on each end where it connects should let you no if it is bad. then after testing just disconnect wires and go to store that carries that brand. (lowes) get a new one and reinstall good luck and hope this helps
Posted on Nov 09, 2010
Take forever to dry
If your dryer still heats, but your clothes take longer than usual to dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
Exhaust ducting that runs to the attic is usually the worst configuration, because the air has to be forced up. The blower fan will meet more resistance and any lint that does not exhaust completely, ends up stuck in the vent. Water appearing in the drum is another sign that you have a clog somewhere causing condensation to develop.
FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make the appliance run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, this is generally a sign that the heating element IS working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat. If you have any questions, please post back and let me know. I hope you find this information helpful.
Aug 11, 2011 | Speed Queen ADE3LR Dryer
Our 4 cycle whirlpool dryer runs for 5 -10 minutes gets hot and shuts off.
check to see if the dryer vent is clogged up - When a dryer gets to hot it will shut off to prevent catching fire!!! If the vent is clogged it forces the heat from the dryer to stay in and that causes the dryer to over heat!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Jun 25, 2011 | Dryers
Will start, won't completely dry our clothes... Taking FOEVER!!!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 01, 2011 | Dryers
Dryer shuts off after 5 minutes.hose is clear..appears to get hot...also hot to touch on top
If your dryer is still heating, but your clothes aren't drying properly, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
In severe cases of dryer vent clogging, you may experience condensation inside the drum and/or vent exhaust. The dryer exhausts warm, moist air. If the heat and moisture have no where to go, it will condensate inside the drum and exhaust vent. Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This eventually will lead to component failures and is the source of many fire hazards.
There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, this usually a good sign the heating element is working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat.
NOTE: If you have already determined the exhaust ventilation is clear from the point where it leaves the back of the dryer to the point where it exits your home, you need to check the vent hose run to ensure there are no excessive bends or kinks that can be causing choke points that restrict air flow. If the vent line checks ok, then you need to inspect your blower fan housing inside the dryer to ensure it is not clogged. If you have any questions, please post back with your COMPLETE MODEL NUMBER and let me know. I hope you find this information helpful.
Dec 23, 2010 | Roper Dryers
My dryer starts and runs but puts out little heat. To dry a load of towels I must run 3 or 4 cycles
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Nov 26, 2010 | Whirlpool Dryers
Dryer is taking much longer to dry clothes than it once did. Took 3 hours to dry clothes last night and had an unusal odor. Dryer is 3 years old, the dryer vent is not clogged up.
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, the heating element is working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat.
Nov 03, 2010 | Frigidaire GLEQ2152ES Electric Dryer
I have a newer but not brand new kenmore dryer. I have to run it twice to get a load dried. Serial number of dryer is ML4641775. Where is the heating element and how do I replace it?
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
Oct 08, 2010 | Dryers
The dryer still runs well, there is no heat and you have to run the dryer hours before your clothes are dry
This could be one of several problems. The most common problem that causes no heat is a clogged duct or vent. If air is not flowing out of your unit due to a clogged vent or duct, it will immediately overheat and shut down the gas burner, in gas models or the calrod heating system in the electric models. Try removing duct, checking for clogs in the duct and at the connector at the unit itself. Then check the vent inside your home and on the outside wall for lint clogs.
Jun 07, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer not heating up
either your element is shot or your filter is clogged or your duct line is clogged
Nov 24, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer heats slowly
When dryer heats too slow, that means that there is a problem either with the heating element, the thermostat, or the vent.
See the following suggeations from Repairclinic:
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Oct 04, 2008 | Whirlpool Dryers
Bosch Nexxt WTMC 3300 Electric Dryer Logo
49 people viewed this question
Top Bosch Dryers Experts
Elie Balas
Tommmix
Level 1 Expert
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
