Question about Wahl 79111
I have a Wahl 79524-6001 hair cutting trimmer. Everything was working fine during a trim and then it immediatly became SCREAMING LOUD. Usually just a nice buzz. I adjusted the black screw and temporarily got the loud buzz to stop but the trimmer blades don't seem to be operating as before. The 2 screws on the head are tight.....Wassup?
  • Wahl Master
  • 1,628 Answers
Be sure that you have oiled the blades per the manufacturer instructions. This is essential.
The noise you've described is usually due to a problem with the blade tension. You're in the right area with the screw but it sounds like you've over-tightened it causing the blades to not move. The correct way to adjust the tension is to turn the screw clockwise with the clipper running. When the blades begin to make a chattering sound, back the screw back by a quarter turn
Posted on Nov 02, 2017
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: Wahl razor's not cutting, how do I fix it?
have you tried taking apart the blades and replacing them so that they line up together? Have you had a professional shear sharpener look at your blades? mabie all they need is to be sharpened again. Blades like knives or scissors need to be sharpened every once in a while. Also try replacing the blades with a new ones. The blades may have worn out. also try oiling the blades every once in a while.
Posted on Oct 14, 2008
  • 61 Answers
SOURCE: I just bought a wahl detailer trimmer and when I trim my beard,
Your problem is in your blade adjustment,nothing is wrong with the clipper,trust me i've adjusted thousands, set teeth so that hair can easily be feed through when clipper is on,perfect solution,wish i could draw you a picture.
Posted on Jan 26, 2009
  • 12 Answers
SOURCE: Wahl Razor will not realign after removing blades for cleaning!
This is always a problem with clippers, it's just a matter of holding the blades tightly in place and getting the screws in as tightly as possible without letting the blades go. This has always worked for me in the past.
Posted on Aug 11, 2009
  • 30 Answers
SOURCE: wahl magic clip clippers are very noisy , tried to adjust ?
1 or 2 basic things happened. 1st there is an armature adjustment on the right hand side when viewing the clipper from the top (it looks like a screw). Place a screw driver in this and turn it counter clockwise, if this screw is up against the stop than you can place a small screwdriver behind it and pop it out (this is actually a cap) now you can access the actual adjuster. back this out about an 1/8 of a turn at a time until the noise stops, turn them side to side to insure that the armature is far enough off of the motor coil. Then replace the cap.
Posted on Sep 21, 2009
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
Wahl clippers
The clipper was being held at too sharp of an angle
Oct 01, 2013 | Wahl Super Taper Hair Clipper 2000 Hair...
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
Nov 12, 2011 | Health & Beauty
The trimmer won't cut
This Wahl trimmer you need to have the blade sharpen and the trimmer motor adjust. for more power. www.mannyssharpening.com
Mar 17, 2010 | Wahl 8040 Hair Trimmer
The moving cutting edge keeps going diagonal to the bottom cutting guide- to the point where it overlaps and chews into skin! how do i fix this?
if this is a Wahl clipper Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers.
Mar 15, 2010 | Wahl Super Taper Hair Clipper 2000 Hair...
Does the Wahl Model AC Trimmer have an adjustment for the blades? There is only a plastic insert between the blades
Wahl has two type of blades for this AC trimmer, some come with a fix blade no adjustment,the other type of blade has adjustable blade. Wahl dose market the blade as adjustable or non adjustable. But mannyssharpening.com has the adjustable blade type were they can adjust the blade for a close cut.
Feb 22, 2010 | Wahl AC Trimmer Hair Trimmer
Mar 17, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
Wahl Trimer #6691
THEY SHOULD SNAP ON THE BLADE.
Feb 10, 2009 | Wahl 9961-701 Hair Trimmer
Wahl 79111 Logo
176 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
