I have 2008 Dell Inspiron with XP pro- no parallel port for an old HP printer.(HP deskjet 1000C) I bought a RC-302 PCI adapter with the assurance it would work. I am computer savvy about installing these devices. The ports did not list as your instructions say. There is no manual on the disk for the 302. What port should I use? Joan McDonald joanm@ccvn.com
  • joanm514 Jun 16, 2008
    No more USB ports. I really love that old printer as it prints 11X17 paper and works for my house plans. It must be 8-10 years old and still prints like a champ.
    Joan McDonald
    Sergeant:
  • 284 Answers
Try buying a USB to Paralell adapter Device.
make sure its USB 2.0.
Best Buy might have it. Im sure radio shack does
Also many places ONLINE would have it.
Posted on Jun 16, 2008
I have an older HP DeskJet 722C printer and an Acer Aspire 5050 3242 laptop. Is it possible to hook up this printer?
I would say, it quite possible. If, the printer is a USB connection then it is only the matter of assuring the drivers for the printer will work properly with the operating system. You may obtain the latest drivers here HP DeskJet 722C printer
If the Printer happens to use the outdated parallel port, I would suggest to use an adapter, you can review the ones currently available online here Parallel to USB printer cable
It is always possible to use old peripherals on newer machines, it is only the matter of researching the internet to rather any available adapters are on the market to maintain older printers.
I hope this is helpful!
Jul 13, 2011 | Acer Aspire One Netbook 8.9" Notebook
We have bought a new packard bell computer and cannot use our HP deskjet printer as the cables do not fit .Is there anything we can do?
If your printer is parallel and your computer only has USB ports, you need only get a USB>Parallel adapter cable and follow the install instructions with it. Any computer store should carry them.
Mar 11, 2011 | HP Office Equipment & Supplies
My new computer does not have a parallel printer port. My old 840C printer has both parallel and USB ports, though I only ever used it with a parallel cable, so I tried connecting with a USB cable. The...
Hello and welcome draepeacock !
The only solution is a workaround :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.Back up your data first.
Both are easy and safe , no specific knowledge required .
Regards .
Feb 14, 2011 | HP DeskJet 840c InkJet Printer
I have an old HP deskjet 3820 printer and a new HP pavilion desk top which has only USB I/O ports, no parallel ports. Therefore I need an adapter cable to connect my printer to my new PC. Does the adapter...
You can almost buy a new printer for the cost of the adapter you are talking about buying. They have all kinds of adapters: the kind that connects to the flat end of a USB or the square end. Parallel, male or female. Go to a computer store like best buy, they should be able to hook you up.
Hope this helps.
Dec 10, 2009 | Cars & Trucks
HP Deskjet 920c will not work with my Dell inspiron 1720 with windows vista. The wizard asks which port I want to use but only gives LPT 1,2 or 3. My computer only uses USB. What can I do?
If you really wanted to use it,you have to buy a USB to LPT port or parallel port cable. The other end of the cable is USB and the other end is LPT.
Sep 18, 2009 | HP DeskJet 920c InkJet Printer
Can't install old printer on newer computer
The appropriate printer drivers are bundled with XP. With the printer connected to the computer and powered on, the system should automatically recognize the printer and install the correct drivers if it is connected via USB. If it is connected to the parallel port, go to Control Panel -> Printers, select Add New Printer and follow the on-screen prompts.
Mar 21, 2009 | HP DeskJet 932c InkJet Printer
New Dell Inspiron connected to HP 820Cse printer. Won't print.
I've not worked with one of these cables before, but here's what I would do: Right-click on the printer icon and go to properties. You'll be looking for the tab that says "ports." Open that tab and see what port the computer thinks it's using for the printer. Chances it says it's using a parallel port, but it is in fact, using a USB port. I can't tell you which to choose without looking at what you see, but I think you might find one that makes reference to a USB port with a parallel connection of some type. Try clicking on that and see if your situation improves.
Feb 24, 2009 | HP DeskJet 820Cse Printer
I got this dell inspiron 531 were do you plug your printer into?
If you have a PARALLEL cabled printer, You need the same sized port on your PC.
Most newer PCs no longer have serial ports, as they are antiquated and slow method of communication.
There are adapters however, if you have a smaller SERIAL port.
And ones that are USB - or a combo one like the following....
52a5421.jpg The Inspiron 531 Does not appear to have the PARALLEL port you require.
My 812c (older) has a parallel cable and usb cable. Look for the Mini USB on the back of the printer, and all you would need is a cable like this - TYPE A to TYPE B
Good Luck!
Jan 20, 2009 | Computers & Internet
Windows Vista won't boot
Windows vista is not included in product min OS requirements technical details. That may be the problem.
Product Features
  • HP DC195A Serial/Parallel Multi I/O PCI Card General Features: Serial/Parallel adapter PCI interface
  • Easy to install Fast transfer rate (430 Kbps) Connectors: One (1) Serial port (9-pin D-Sub DB-9)
  • One (1) Parallel port (25-pin D-Sub DB-25) Regulatory Approvals: FCC CE
Technical Details
  • Model: DC195A
  • Item Package Quantity: 1
  • Hardware Platform: PC
  • networking_feature: Parallel/serial adapter
  • form_factor: Plug-in card
  • Network Interface Description: PCI
  • Connectivity Technology: Wired
  • Data Link Protocol: Parallel, RS-232
  • Minimum system requirements: Microsoft Windows NT, Microsoft Windows XP Home Edition, Microsoft Windows 2000 / XP Professional
  • Depth: 4.7 inches
  • Height: 3.5 inches
Jan 22, 2008 | HP (DC195A) Serial Adapter
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
