Question about OKI MICROLINE 591 Matrix Printer
Help!! Troubleshooting I'm haning issues with my printer. It is printing in the Norwegian symbols I want to set it up to use English symbols. Can you help me?
  • Tim Babcock
    Tim Babcock May 11, 2010
    I'll have to look this one up. I haven't touched one of these in 8 years.
    What started the symbol set to get changed or did the printer do it on it's own.
    If it did, you might want to change the printer cable. The data signal lines could be bad.
  • OKI Master
  • 2,794 Answers
First thing to try is turning the printer off and back on again. If it still continues, replace the printer cable.
Posted on Jun 20, 2008
How can i put english language to my canon ir3300 printer? it only has norwegian.
hi Soko.
this is all i could find so not sure if this will help you out.
Enter service mode, *, 2 & 8 together, *,
COPIER, DISPLAY, USER, LANGUAGE (displays <LANGUAGE xxyy.zz.aa>),
xx = country code
yy = language code
zz = destination code (i.e. Canon)
aa = paper size configuration code (00: AB, 01: Inch, 02: A, 03: all sizes)
EN English
FR French
ED German
IT Italian
JP Japanese
CS Czech
DA Danish
EL Greek
ES Spanish
ET Estonian
FI Finnish
HU Hungarian
KO Korean
NL Dutch
NO Norwegian
PL Polish
PT Portuguese
RU Russian
SL Slovenian
SV Swedish
TW Chinese (traditional)
ZH Chinese (simplified)
the only other thing i could find was this.
Use the following procedure to change the language setting.
  1. Open the printer properties dialog box.
  2. Click [Printing Preferences].
  3. Click the [Printer Configuration] tab ( ).
  4. Click [Environment Settings...] ( ...
  5. In the language list (shown below), find the language you require.
More items...
Selecting the Printer Driver Language
support.ricoh.com/bb_v1oi/pub_e/oi_view/0001037/0001037617/.../0097.htm
you could also try this link.
how do change the language on my canon printer Google Search
Nov 23, 2017 | Canon Computers & Internet
Hi, we have a GCC Elite XL 40N Printer at work on a network with about 12 computers attached to it. One day when I wasn't here, (so im not sure how it started) It started printing A LOT of sheets with...
This could be caused by a few different problems with the printer but here are some troubleshooting techniques that may help:
1. Check that the printer is able to print correctly on its own. Print out a configuration page from the printer or install the printer onto a new machine as a local printer and print out a test page. If this prints out as symbols, the problem is a most likely hardware error and the printer will need to be serviced. Try step 2 before servicing. If the printer prints normal characters, go to step 3.
2. Carefully go through the settings on the printer and review the printer's configuration page to make sure everything has the correct settings and nothing was changed accidentally.
3. The most common problem is that the drivers on the print server, or on the server computer, have become corrupted. In Printers and Faxes on the print server, delete all the drivers for the printer, reinstall them, and then add the printer again. Make sure to print a test page at the end of the add printer wizard.
4. It could be a problem with the ethernet cable so try swapping the current ethernet cable with a new one.
5. If it is still printing symbols at this point, it is most likely a hardware issue and the printer will need to be serviced.
May 24, 2011 | GCC Technologies Elite XL 40N Laser...
Printing but page comes out blank
To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. First, check the ink levels. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
If not, try to restart the printer. Restarting the printer might clear the issues and allow the printer to function correctly again.Press the power button to turn-off the printer then unplug the power cord from the back of the printer, and the USB cable(if connected). Leave unplug for 30 seconds then reconnect the USB cable and the power cord.
If issue persists, try to reboot your computer. Restarting your computer might resolve the issue. If the printer prints all pages correctly, but it adds blank pages to the printout, check for blank pages in the print preview.
If the preview contains no blank pages, check the printer cables. If the printer connects with a USB cable or an Ethernet cable, a faulty connection might cause the issue.
If the issue persists, check the printer settings on the computer. Issues with the printer settings on the computer might cause the issue. Follow these steps to check the computer: Step one: Check the default paper settings. Make sure that the default paper size matches the width and length of the paper loaded in the tray. If the paper loaded in the tray is different from the paper size setting, the printer might print blank pages. For instance, the issue might occur if legal size paper (215 x 355 mm (8.5 x 14 in)) is in the tray, and the paper size setting is letter (215 x 279 mm (8.5 x 11 in)).Follow these steps to check the default paper settings.Click Start then go to Printers and Faxes .Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences . Under Printing Preferences window click the Features tab. Compare the settings in the Size drop-down menu with the paper in the tray. If the size of the paper in the tray is not the same as the setting in the Size drop-down menu, change the setting:Click the Size drop-down list, and then select More . The Size is window opens.Select the size of the paper that is in the tray, and then click OK .Click OK in the Printing Preferences window, and then click OK in the Properties window. Step two: Print a test page A test page might help determine if the printer installation caused the problem.Click Start , and then click Control Panel .Right-click the Printers and Faxes folder (c01532297.gif ), and then click Open.Right-click the printer icon (c01532298.gif ).Click Properties .In the General tab, click Print Test Page . The printer prints the Windows XP Printer Test Page.If the Windows XP Printer Test Page prints successfully, you do not need to continue troubleshooting.
If the page is blank, print from an alternate program to determine if the current program is causing the issue.Browse to the location of your saved document, right-click the file, and then click Open With .Select a program other than the program you are currently using to print the document.Open the file in the program, and then check the contents.(Most files open in plain text applications, such as Notepad or WordPad, even if the contents include unusual symbols or text that does not make sense). Try to print the file. If successful, the printer prints exactly what displays in the program window. If the document prints successfully in the alternate program, you do not need to continue troubleshooting. The issue is likely specific to the program you are trying to print from. Consult the program manufacturer for assistance. If the document still prints blank pages in the alternate program, disconnect other devices. Other connected devices, such as scanners, MP3 devices, or other printers might cause conflicts in the communication between the printer and the computer.
If the issue persists, go to this link for the rest of the troubleshooting steps. Go directly to solution nine. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892627&cc=us&lc=en&dlc=en&product=3390949&tmp_track_link=ot_search#N46
Apr 03, 2011 | HP DeskJet F4280 All In One Printer InkJet
Plis help mi norwgian to amharic transleter or
Unfortunately, it doesn't look like there are any Amharic- Norwegian dictionaries or translators.
Here are some free lessons I found that will help a Norwegian speaker learn Amharic though: http://www.internetpolyglot.com/lessons-am-no
You could also use a Norwegian- English dictionary/translator and then an English-Amharic one. I know it's not ideal, but it looks like that's your best bet.
Here is a free online English-Amharic dictionary: http://www.amharicdictionary.com/2.0/Default.aspx
Here are a few free English-Norwegian dictionaries:
http://www.freedict.com/onldict/nor.html
http://www.tritrans.net/
and a free translator: http://www.translation-guide.com/free_online_translators.php?from=Norwegian&to=English
I hope this helps, and I'm sorry again that there isn't a better solution for you.
Let us know if you have other questions.
May 31, 2010 | Acer Computers & Internet
Printer only prints half of page
My printer does this when the paper isn't seated properly and/or that paper guide isn't set correctly. If this all seems OK, then try a head clean. You should be able to do this from the printer options in Windows.
Dec 13, 2009 | Dell A920 InkJet Printer
I can not print, the error is: LANG=ENGLISH, please help
Changing the Control Panel Display Language
The default control panel display language is set for English.
Supported languages are: English, French, German, Italian,
Spanish, Finnish, Danish, Dutch, Swedish, Norwegian, Turkish,
Polish, and Portuguese. Follow these instructions to change the
display language.
1 Switch OFF the printer.
2 Press and hold Select while switching the printer ON until
SELECT LANGUAGE appears in the display.
3 After the power-on self test, LANG=ENGLISH appears. Press
[Value+/-] until the desired language appears in the display.
4 Press [Select] to save your choice. An asterisk (*)appears next
to the language to indicate it is now the default.
5 Press [Go]. The On Line indicator is lit, and display messages
are now in the language you selected.
Sep 21, 2009 | HP LaserJet 4 plus Printer
My printer is printing weird symbols
Try this:
Click Start, then internet explorer, then tools, then internet options, advanced tab, reset button, a new window appears then reset, close Ok.
Jul 08, 2009 | Compaq Inkjet IJ650 Printer
How do I change the language from Norwegian to American English, on my SGH-E700?
go to your settings menu and press the language tab this will alow you to change it
Apr 25, 2009 | Samsung E700 Cell Phone
Printer not Print data in English Language
Hi, you may want to reset/restore the Epson LX300 to default settings. This can be done by pressing down on the FONT button while powering on the printer. If done right the LX300 will print a test page with the firmware version. It is also possible that the drivers are corrupted. In Start, Printers & Faxes, delete the LX300 printer, restart your PC and then re-install via Add Printer. In some cases, defective parallel cable can also cause problems. Unfortunately the only sure way of checking is by replacing the printer/parallel cable with a known good/operation cable. If the printer would really be requiring service, a Service Manual is available at (http://www.eserviceinfo.com/index.php?what=search2&searchstring=DPA-300) Hope this be of some help to you. Good luck and pls post again how things turn up.
May 26, 2007 | Epson LX-300 Matrix Printer
OKI MICROLINE 591 Matrix Printer Logo
104 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
