Question about Samsung SGH-D900 Cellular Phone
SIM Card Where is the sim card, how do i remove it.
    President:
  • 2,712 Answers
You should be able to find it once you remove the battery from the mobile. Here is a pic:
Sometimetime it will be located inside a slot or by a cover, depending upon your model..
Posted on Jun 16, 2008
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Stuck Sim card
Certainly not an unheard of event. In fact, so common that if you search for "stuck sim card in (fill in your device brand and maybe model)" you may pull up a video or instructions for your particular device. And you can even search for "sim card stuck in wrong slot." Acuatually, I would not be surprised to find "sim card stuck stuck in ear" for about any conceivable thing that can happen to a sim card has happened. That said, here are some videos:
How to remove micro SIM stuck in normal SIM slot YouTube
How to extract remove Micro or Nano SIM from wrong sized SIM slot
How to remove micro Sim Stuck in Normal Sim Slot
Sep 14, 2017 | Cell Phones
How to fit sim card to ipad
Insert the tip of the SIM eject tool or a straightened paper clip into the hole of the SIM card tray on the side of the iPad.
Press the SIM eject tool or paper clip firmly into the hole until the SIM tray ejects.
Remove the SIM card from the tray, if necessary, and place the other SIM card in the tray.
Push the SIM card tray back into the iPad.
http://www.bing.com/videos/search?q=how+to+fit+sim+card+to+ipad&mid=C532A5A729B9058B83CAC532A5A729B9058B83CA&view=detail&FORM=VIRE6
video insert micro sim card into Ipad
hope this helps
Sep 17, 2012 | Apple Ipad 2 Wi-fi Black 16 Gb Pc Tablet
How do i clean my sim card
  • Hi
    To clean your sim card, remove the SIM card from the phone. Rub a dense white eraser along the exposed metal part of the SIM card. Make sure that the eraser is brand new, otherwise you could get the SIM card even dirtier.
  • Remove the back of your phone and the SIM card. Spray canned air into the back of the phone, removing all dust and dirt particles, especially those that could be stuck in the SIM card groove.
    Regards
  • Jun 30, 2011 | Nokia 2220 Cell Phone
    How to remove sim card from nokia c7
    RIGHT SOLUTION: To remove the SIM-card, press the SIM-card a bit further down the slot (with another sim-card, a memory card, your nails if they're long enough,...) and then release the pressure. The SIM-card will come out far enough for you to pull it back out.
    Feb 28, 2011 | Nokia C7 (8 GB) Smartphone
    How to remove sim card?
    For removing the SIM Card, insert the end of the 'SIM eject tool' (supplied in the box) into the hole on the SIM tray. Press firmly and push it straight in until the SIM tray pops out. If you don't have a SIM eject tool, you can use the end of a pin/paper clip. Pull out the SIM tray and remove the SIM card in the tray. The angled corner of the SIM ensures that the card fits only the correct way in the tray.
    With the tray aligned as shown, carefully replace the SIM tray containing the SIM card
    in iPhone.
    Oct 07, 2010 | Apple iPhone (16 GB) Smartphone
    How do I remove the Sim card from a Motorola Razr V3M cell phone?
    it is very easy to remove.just use your finger to open the back cover of the phone, remove the battery close to where the battery terminal is, and slide out the Sim card out.
    But if you can not remove the Sim card with you finger, just get s screw on something you can use to pull the back cover and the battery out, then you can get access to your Sim card.
    Good luck to you.
    Mar 15, 2010 | Motorola Mobility RAZR V3m Cellular Phone
    Sim card removal
    To remove the Subscriber Identity Module (SIM) card, complete the following steps:
    1) Place thumb or forefinger at the base of the SIM card closest to the edge of the battery compartment.
    2) While applying force down toward the SIM card, slide the SIM card gently out of the SIM card tray. See the following image:
    Warning:
    Avoid the use of any tools to prevent damaging the BlackBerry smartphone components
    Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
    Samsung SGH-D900 Cellular Phone Logo
    121 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
