Question about Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer
This isn't much of a problem as it is a qestion. Is there a was I can hook up my Pioneer car sprekers to a TV or an electric piano? If there is, can you describe materials I need and what I would need to do to install them
  • 23 Answers
You'd have to know what impedance the TV amp is (probably 8 or 16 ohms). Then you would have to match the impedance of the car speakers to that impedance. Tthe car speakers are likely 4 ohms, in which case you'd have to series 2 of them together (or 4 if the TV amp is 16 ohms) for each channel of the TV amp. You'd probably also prefer to mount them in an enclosure, since the power output on the TV is probably really low.
This assumes you're not trying to add a power source of some sort, but are intending to power the speakers off of the TV or piano.
Speaker wire/stripper, **** connectors, spade connectors to fit speaker terminals, crimper.
Posted on Nov 08, 2010
Vga hook up
may need to tell the laptop in the screen resolution settings to display the image on the tv instead of the laptop. Right click on the empty desktop of the laptop and go to either propertie or screen resolution and then make sure that the computer can see that the tv is hooked up and that the image is showing on the tv instead of the laptop. You may also need to change the mode on the tv to vga.
Nov 21, 2013 | Pioneer SD-532HD5 53" Rear Projection...
Can i hook pioneer speakers from a system to my lg flat screen
Absolutely! To provide a better solution to your problem, however, you will need to provide model numbers of your TV and surround sound system. Depending on the available hookups and your hardware, you may need a received to make everything compatible.
Feb 13, 2013 | Proscan 32LA30Q Television
Aoc monitor flashs on hen gose off
What is this monitor hooked to? try unpluging it from the wall and un hook all the componets from it. just leaving the electrical cord atached. now plug it back in and turn it on. Or hook it up to some other device and see if it works.
Oct 27, 2012 | AOC 2036SA 20" Widescreen LCD Monitor in...
I have a Pioneer VSX-D308 reciever and I have... no idea how to hook it up to my big TV (bought receiver used). Do I need the red/white cords? Do I need other cables? HELP! Wanting to hook up to big...
What your unidentified TV >>requires<< is the BEST Video from every video source. That would be the DVD, SAT Box. It probably has multiple high-end video inputs, right?
What your receiver needs is at least a basic composite video connection to the TV so you can set it up and manage it.
A web search for "Pioneer VSX-D308 manual" will find the manual.
ALL of the BEST Audio should go directly to the Pioneer. That includes the SAT and DVD player.
Your TV can exist just fine with basic audio from the video sources. And you could still watch it/them without the Pioneer turned of if you want.
I can't find the exact manual for free anywhere but if you download something similar like http://www.retrevo.com/support/Pioneer-VSX-D409-Receivers-manual/id/385ci977/t/2/ it should give you the basic guidance you need.
I recommend
Do some web searching for what the cables are for. It's all basic and standard.
Sep 07, 2011 | Pioneer VSX-D308 Receiver
I have tv hooked up to the pioneer but the TV will not play its sound through the speakers? what Am I doing wrong? I have the DVD hooked to the Pioneer and it works fine.
Is the unidentified TV a sound source from the SX-315's perspective? Is it's audio output enabled whene the TV volume is down? Would the Cable Box be a BETTER source?
Jul 26, 2011 | Pioneer SX-315
Hooking up optical input output
What kind ot TV?
Not sure what you mean by all signals.
Think about this: if your TV had any AUDIO capabilities that were superior to your REAL audio components, why would you need them?
The TV is the end of the line. Wouldn't it make more sense to get your TV-related audio as close to the source as possible? Your BD, DVD, cable and satellite all have high end audio outputs just begging for a place in the Pioneer.
Mar 20, 2010 | Pioneer VSX-D557
I need wiring color coding 4 pioneer deh 2050mpg? i know red is constant power.
Not to question you about the red being constant power but I have a pioneer deh-1600 car stereo and red is hooked to electric terminal controlled by ignition switch (on/off) and if your unit has a yellow wire that goes to constant power. The only problem with hooking up the red wire to constant would be if you happened to accidentally leave your player on it could drain the battery. Hope this helped a little. Good luck.
Oct 10, 2009 | Pioneer DEH-P2000 CD Player
Hook up for pioneer htv c1
To hook up to tv you have to make sure your tv has a (audio out) port then use rca cables and hook up to (audio In) port in the back.
Jan 01, 2009 | Pioneer HTV-1 Shelf System
SUBWOOFER ENCLSURE FOR TWO PIONEER TSW307F 12" FREE AIR
Hi, i know its a long time since 2008.
but do you or enyone else know where to get specs to a pioneer ts-w307f???
im building a box for this sub but i cant find specs so i cant run it on winisd!
i konw this dont answer a qestion but since you did a graph on it in winisd i thought you might have the right specs?
Dec 24, 2008 | Alpine MRV-F307 Car Audio Amplifier
Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer Logo
65 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
