Question about Canon PIXMA iP4300 InkJet Photo Printer
Canon iP4300 is noting "offline or no power" blinking orange light 3 times then turns off
The cable seems fine, but all of a sudden the printer won't work and I get a note stating "offline or cable disconnected from computer". I've tried using different cable or switching adapter in computer but still won't connect. I press power button and printer turns on for maybe 30 seconds, blinks orange light a few times then shuts down again.
  • 197 Answers
Maybe you have some driver issues..
go here, get new ones, re install
Posted on Jun 16, 2008
Printer doesn't respond via USB only WiFi
As my helper partner states, I quite agree but I would also use a different USB which the one you're using might be damaged, use another USB station cause maybe its also damaged. But if it states that the printer is offline...it will never print because its not selected as your active Printer. Actually you are sending the printing jobs to that printer wich is not active or recognized.
Apr 06, 2014 | Office Equipment & Supplies
Offline printing from computer
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Oct 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Hi, My Star TSP100 printer always goes offline after computer shutdown
Hi Valued Star Customer
It seems like the USB host may be going into "sleep mode" and not awakening. Please contact Star Support at support@star-emea.com for documentation.
Best regards
Star Technical Support
Feb 13, 2012 | Star Micronics TSP100 Thermal Printer
I have 3 computers connected by router. All 3 have been using the hp 6310 all in one printer for a long time. Now all of a sudden when we try to print is says printer is off line. I have tried turning...
Hi! you can try this. rightclick to open all active printers in right downcorner there click the printer section and remove the x mark in use the printer in offline. you can allso check that your default printer is right not example the hpxxxxxxx (copy 1)
Aug 03, 2010 | HP OfficeJet 6310 All-in-One Printer...
HP Deskjet 3500 series, my printer keeps telling me that is is off when the light is green, keeps stating it is offline. When I installed the printer everything was fine, now when i print the printer...
Hi
HP Deskjet 3500 serie --
There could be a Software issue or hardware issue --
1) To check the software issue
Print a Test Page -- from the computer
2) To check the hardware
Press the Power button to turn the product on.
Press and hold the Power button
Open and close the front cover four times.
Release the Power button. The self-test will print
and it it is printing the hardware is fine ...
3) Then you can check by changing the USB Cable connection
Jan 01, 2010 | HP DeskJet 3520 InkJet Printer
Printer stating it's offline
first of all try reinstall the printer driver, if the problem were still there change the usb cable.
Aug 14, 2009 | HP Photosmart C6100 All-In-One Printer
OFFLINE PROBLEM
disconnect USB, go to RUN and type in services.msc and then find print spool and right click, then choose restart .plug in usb
Mar 02, 2008 | HP PhotoSmart C4280 Laser Printer
Printer not receiving jobs from computers in office..HELP!
what type of connector do you use? if its network printing then check ip address, cable, and the network card of the machine if it shows light, if its usb cable check the driver or cable.
note: make sure when you press the print buttom on the machine it doesnot show offline! if it shows offline you cannot print hit go or start to make it online.
if none of this work, reset the machine by hitting 1087 twice this will take you to maintenance mode then hit 906 then start, highlight the words that come on screen by your finger then hit start, the machine will ask you to put the main power on and off, do that and you will be fine.
Best Regards
Feb 15, 2008 | Kyocera Mita KM-2050 Printer
Problem with hp officejet4315v all in one
Hi there check that the data cable hasn't fallen out if not change data cable. If still not working check that you are using the correct port within the driver .
  • Goto Printers and faxes
  • Make sure that the printer states Ready not offline
  • If states offline Right Hand click and select use printer Online
  • If not above right click and select properties
  • Once in properties select Ports from the Tab at the top of the window
  • Make sure that you are using the correct Port i.e. LPT1 or USB that the printer is connected to.
  • If you aren't change the port by clicking the appropriate one or add new port.
  • If you are on the right port try reinstalling the print drivers
I hope this helps you
Thanks J
Jan 13, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Canon PIXMA  iP4300 InkJet Photo Printer Logo
478 people viewed this question
old marine
old marine
