Question about Samsung HCL4715W 47" Rear Projection Television
On-Off problem When turned on, set turns itself off immediately (within 2 seconds).
  • 58 Answers
Hello
Does the sound and Picture come on?
let me know and I will be better able to help you.
Thanks guy9
Posted on Jun 16, 2008
Programming keyless entry to 95 landcruiser
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
Oct 29, 2013 | 2008 Toyota Land Cruiser
Coding spare key for a Toyota Echo?
Adding key.
Note:
You must be having one working master key to perform this function.
1. Start with the key out of the ignition, drivers door is open all others closed and drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
C. Insert the key into ignition and leave it in ignition.
D. Close the drivers door.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock and then unlock once indicating successful programming. If the door locks cycle twice, repeat steps A and B in step 6 as the remote was not accepted.
7. Open drivers door.
Jan 09, 2013 | 2001 Toyota Echo
Programming key sienna 2006 tk
Here are the instructions per the factory manual.
not accepted.
Feb 05, 2011 | GPS
I need to know how to program a remote alarm control for a toyota 4runner 2000
f
1. Start with the following conditions: you are in the vehicle
a. Key is out of the ignition
b. Drive door is open ( all other doors are closed)
c. Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times. Use an even pace and try
to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times (same as before).
b. Turn the ignition to ON then back to OFF.
c. Turn the ignition to ON then back to OFF.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically)
indicating successful entry into programming mode. Return to step 1
6. Perform these steps within 40 seconds:
a. Press the LOCK and UNLOCK buttons on the transmitter
b. Immediately after letting go of the lock and unlock buttons,
press the lock button by itself and hold for 2 seconds.
Within 3 seconds, the door locks should cycle ( LOCK then
UNLOCK) once-- indicating successful programming. If
the door locks don't cycle, or cycle twice. Repeat steps
6a and 6b--this remote has not been accepted.
c. Repeat steps 6a and 6b for EACH transmitter that will
operate the vehicle. Including any old transmitters.
7. Close the driver door.
Also can check this procedure: http://www.toyota-4runner.org/60925-post2.html
Hope this help.
Mar 22, 2010 | 1997 Toyota 4Runner
Need to program a new remote
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here are the instructions for programming the 99-02 4Runner Keyless Entry factory remotes:
c. Driver door
6a and 6b--this
Hope this helps you, it did me greatly-- Good luck,
Mar 04, 2010 | 2000 Toyota 4Runner
Lost remote and like to program new remote. HELP. 2000 prado vx.
1. Start with the following conditions: you are in the vehicle a. Key is out of the ignition
3. Perform these steps within 40 seconds: a. Cycle the power locks 5 times. Use an even pace and try
4. Perform these steps within 40 seconds: a. Cycle the power locks 5 times (same as before).
6. Perform these steps within 40 seconds: a. Press the LOCK and UNLOCK buttons on the transmitter
Good luck and hope this helps.
Nov 04, 2009 | 2000 Toyota Land Cruiser
2003 toyota camry how do you reset wireless entry remote
if remote is good here are the factory instructions to program it, if this doesn't work u may have a bad remote or receiver in car.
not accepted.
Sep 09, 2009 | 2002 Toyota Corolla
Tv shuts off immediately
check first for the contact point of your control panel button maybe the tact switch is shoted specially when your always using remote control for function operation.second check power supply for leak capacitor or change in value,check also the photo coupler for leak test or change in actual.
Aug 01, 2009 | Mitsubishi VS-5043 50" Rear Projection...
I need programming instructions for a 2002 toyota highlander for my remote.
not accepted.
Jun 30, 2009 | Toyota Highlander Cars & Trucks
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung HCL4715W 47" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
