Question about Biostar G31D-M7 Motherboard
Added a video card and now the on board monitor does not work
2 Suggested Answers
  • 11800 Answers
SOURCE: I have a Biostar G31-M7 TE Motherboard, I had two
You can't do that, the pci-e disables the onboard video chip. Connect both monitors to the pci-e video card.
Posted on Nov 28, 2010
System will not turn on
If you are certian the pc is powered on, check the video card and any new card that has been added to the pc. If you have a video card installed, remove all other cards and retry your boot. If you still have no video, replace the card. If the video connection is on the board and you and have added a new video card, use the "old" connection to open your operating system and configure the video setting to use the new card and change connection.
Good Luck,
C2Solutions
Jan 02, 2012 | HP Pavilion a350n PC Desktop
Analog output cannot display video mode
Hi, there!
Please check the connection of DVI or VGA cable which connect between your computer box and monitor. Check at the back of your computer box, how many VGA ports(the blue port)? If your computer box have 2 VGA ports( one in-built on-board and one from added graphic card), always connect to the one from added graphic card, not the one on-board. Hope this help. Thanks for readin.
Jul 11, 2011 | Dell Monitors:Dell 1801FP Driver
My computer will not boot up completly. The montior has power and the so does the mouse. I pulled the video card and plugged the monitor right into the on board plug. Nothing. The monitor works because I...
Sound like you have a hardware conflict,did you try to add new hardware?go back to working setup if you you added video board make sure you disable on board video in cmos,if you are going back to original setup remove all memory chips when you power up should hear beeping,power down reinstall memory you should boot ok
Jan 07, 2011 | Biostar M7NCG-400 Motherboard
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
No display but power led is on
sounds like a video card problem in your pc. If you are using the onboard video output on your motherboard, you probably need a new one. If you are using a card that has been added to the board in a slot, try your onboard output (looks the same)
Jun 15, 2009 | Dell E151FPp 15" Flat Panel LCD Monitor
Added a new video card, now my monitor stays in sleep mode
If the computer originally had integrated video, have you tried reconnecting the monitor to that output? Most system boards will automatically detect when you install a separate video card, but on some you need to disable the built-in video in the BIOS before the new card will work. Also, have you considered the chance you just got a lemon of a new card? It happens sometimes (it's happened to me!).
Nov 18, 2008 | HP Vs17 17" LCD Flat Panel Monitor
3 monitors on dell vostro 200
Go to your bios and check if your bios allow that. Usually if you connect a card on the motherboard slot automatically the on board card becomes unavailable.
If your bios doesn't allow to make changes you can add another pci video card or connect some vga split signal to get the image on 3, 4, or more monitors with a single device.
Oct 22, 2008 | Computers & Internet
Monitor problem
Hello soltaino, your board (K7VT2), did not come with a video card. (New). If you have a video card in your PC it was added. I'll need to know the name of the card to advise you regarding a cable to connect to the monitor. My guess is it's like the pictures listed below.
The Asrock does have an AGP 4x video slot. If your board has a video card installed it's connector would connect to a standard VGA connector at both the monitor & at the video card.
Whick looks like this.
The picture above shows a female VGA port, (like on a monitor).
b9662ed.jpg See the bue cable. That's a standard SVGA cable connector.
If you can not connect to the PC you need a new video card, not a new monitor. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3667003&CatId=876
Suggest this card. It has both VGA & DVI connectores.
Best Regards!
Mike
Apr 01, 2008 | Asrock K7VT2 Motherboard
Computer won't come on
Does this computer have on board video? You mention that you added a new video card. Did you remove an old video card?
Do you see anything at all on the monitor at anytime while booting?
If it has onboard video have you checked the BIOS to insure that it is enabled?
Nov 20, 2007 | E-Machines eMachines Desktop PC
Biostar G31D-M7 Motherboard Logo
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
