Question about American Audio CDI-100 Personal CD Player
Cd tray will not open. Is there a quick fix for this I can do myself?
    Novelist:
    Champion:
  • 225 Answers
If when ejecting the disc tray you can hear motor noise from inside but the tray doesn't open up...
1. Unplug the unit from the A.C. outlet
2. Remove top cover
3. Look for rubber drive belt that causes load/unloading tray to move in and out.
4. Replace with new rubber belt..not a rubber band but a rubber belt.
Posted on Nov 08, 2010
I have quick heal software in cd,but cd is not open in pc.
"Quick heal software"? What is that? Do you mean that the cd tray will not open if you trigger it? IF that is what you mean, there is usually a small hole in the front of the CD player that you can insert a small wire (a paper clip will work good), press in and it releases the tray door so that you can open it with your fingers. But I am not sure that is what you are asking.
Jul 15, 2014 | Computers & Internet
Cd tray closes quickly without pressing switch on Technics SL-pd688
There is a small switch under the tray that stops the motor at the end of it's travel, also one when the tray goes back in.
These can have wires broke off or can be stuck or open circuit
Jun 19, 2014 | Technics SL-PD8 5-Disc CD Changer
My xbox 360 has the open tray error which is when i put a game dvd or any cd in then it says reding for about 2-3 seconds then it says open tray like there is no cd inserted into my console and i know its...
I would not recommend doing anything on your own. If you want a cheap good fix you should try www.videogame911.com. They beat manufacturers pricing and are really fast. The systems I had repaired there came back looking and working awesome!
Apr 30, 2011 | Video Game Consoles & Games
NAD C541 tray does not open.
if i'm right it will have the sony mechanism so if you take the lid off and unscrew the 2 screws, 1 at either end of the cd clamp and remove it, you should see part of a large cog just under the front of the cd tray, try turn this clockwise and the tray should open.
once open, you should be able to see a small plastic cover, loosen this slightly and replace the belt as this is prone to slipping on this mechanism stopping the cd tray from opening and also clamping the disc properly when closed.
hope this helps?
Mar 11, 2010 | NAD C541 CD Player
CD tray on Technics SL-PS670A compact disc player will not close
Just a quick notion! Had you made sure the transit locking pieces were removed?
Jan 10, 2010 | Technics SL-MC6 CD Player
Ps2 cd tray does not open and the eject button light flashes
This is the tray getting stuck on the PS2 shell/casing. I can fix mine as it does the same thing but I tap it one quick time after I hit the eject button and it will usually open. Don't try to pry the tray open or this will make the problem worse.
Jan 08, 2009 | Sony PlayStation 2 (PS2) Console
CD Carousel for the Onkyo Shelf System
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Oct 11, 2007 | Audio Players & Recorders
Loading tray will not load or close-reopens immediately
Sounds like the tray position switch has gone wrong.
Sep 30, 2007 | Onkyo DX-C340 CD Player
CD tray got knocked off track
You can try to fix mechanics by takin apart cd, remove tray and try open/close operation WITHOUT tray. Leave it as OPEN, then try to place tray back in fully open position, but be careful, you have to pres OPEN and then unplug it from outlet to avoid electric shock risk. BE CAREFUL!!!
Sep 25, 2007 | Technics SL-MC6 CD Player
American Audio CDI-100 Personal CD Player Logo
139 people viewed this question
Top American Audio Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you an American Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
