Question about Pioneer DEH-1900MP CD Player
Need to know where wires go to make stereo work
  • 35 Answers
Posted on Nov 08, 2010
  • Ross Walker Nov 08, 2010
    Yellow
    Connect to the constant 12 V supply terminal.
    Red
    Connect to terminal controlled by ignition switch (12 V DC).
    Black
    Connect to a clean, paint-free metal location.
    Blue/white
    Connect to system control terminal ofthe power amp or auto-antenna relay control terminal (max. 300 mA 12 V DC).
    White - Front Left Speaker Pos
    White / Black - Front Left Speaker Neg
    Green - Rear Left speaker Pos
    Green / Black - Rear Left Speaker Neg
    Gray - Front Right Speaker Pos
    Gray / Black - Front Right Speaker Neg
    Violet - Rear Right Speaker Pos
    Violet / Black - Rear Right Speaker Neg
    With a 2 speaker system, do not connect anything to the speaker leads that are not connected to speakers.
I have a 2001 ford focus se and the previous owner had a stereo just taped together with the wires from the car . The wires are just sticking out and i bought a new one and i need to know what the colors...
a reputable car stereo place will sell you a wiring harness for your vehicle and after market stereo, that tells you which color wires to hook to what.
Oct 21, 2013 | Cars & Trucks
Can you put a newer radio in a 2001 yukon
Hi, my research indicates you can install a single din aftermarket head unit in the 2001 Yukon.
A couple of good websites to use are crutchfield and modifiedlife.
Crutchfields will identify exactly what adapters are needed, and modified life has the factory wire colors.
You will need an adapter to fill the space between the aftermarket stereo and the hole left by removing the factory head unit.
You will also need an antenna plug adapter.
I recommend you buy the wire harness pigtail to simplify the installation--this may or may not include the antenna plug adapter.
If you have onstar, you will need an additional adapter.
If you have steering wheel controls, you will need another adapter to keep those.
Keep the above things in mind when selecting a new aftermarket stereo, as you will need one that is compatible with steering wheel controls and onstar, if you have either of those and want them to continue to work with the new stereo.
Crutchfield has an link called "outfit my car" that takes you through a "Turbo tax" style questionaire and tells you what will work and what you will need. here is the link: http://www.crutchfield.com/App/Car/outfitmycar/MyCar.aspx
Assuming you have a base Yukon, here are your factory wire colors from modifiedlife.com:
2001 GMC Yukon Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Please let me know if you have questions, and thanks for using FixYa.
Jan 18, 2011 | 2001 GMC Yukon
I have 2 wires coming from the positive battery terminal. The first wire goes underneath the car to the starter. The second wire is separated at what appears to be a fuse link which goes into the drivers...
Hi, this second wire is a permanent live feed for inside the car, the things it runs are things like the stereo all its their for is so the stereo dont lose any stations that you have stored into the memory other than that their isnt much else it runs, maybe the clock, you could check by seeing what isnt working when the key is out, check the clock and stereo, if the stereo works with the key out then it must have its own live feed.
the chances are it wont work and you will lose the preset saved stations.
i hope that has given you some idea of what its for.
please let me know if you need further assistance.
plz can you rate this post as i have pages of unrated posts, thanks
Aug 25, 2010 | 2004 Hyundai Santa Fe
I need help with a wiring layout for a stereo.
Forget it...go to a car stereo installation shop and buy a wiring harness for your car ($20-40) and you're done!
Good Luck
P.S. might as well buy a dash kit ($30) to make installing the radio simpler as well...if you DON'T have a car stereo shop nearby, order parts from crutchfield.com
Jun 23, 2009 | 2007 Hyundai Sonata Limited Sedan
I need a wiring color code for 2004 nissan sentra factory stereo.
I have the same car...04 nissan sentra....with the exact same problem....left side speakers just quit working. I still do not know what caused the problem, or how to fix it. I know it not the wiring, it is a defect within the stereo.
Mar 26, 2009 | 2004 Nissan Sentra
Subwoofer istalation into a clarion DXZ375MP stereo
The DXZ375 has two sets of RCA outputs (1 red plug, 1 white plug) located on the back of the unit. The set with the white main wire is for a front amplifier, and the one with the black main wire is the rear. You want the black one.
I'm assuming you also have an amplifier for your subs and the necessary wiring. You will need to run a 12v+ from the battery to the amplifier, splice a power-on signal wire from the ACC Power wire on the stereo's wiring harness (red wire) as well as connect the amp to the stereo via the RCA outputs.
Mar 11, 2009 | Clarion DXZ375MP CD Player
Nissan sentra 1995 wireing help
go to crutchfield .com and let them know your car and your stereo. they are great at this.
Nov 28, 2008 | 2007 Nissan Sentra 2.0 SL Sedan
Pioneer DEH-1900MP CD Player Logo
192 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
