Question about Microwave Ovens
How does it work modle number 790 78789400 kenmore oven door locks then oven did not turn on what am i missing
    President:
  • 2,777 Answers
I need some more information here.. did you try to bake something, run a cleaning cycle or what?
Please let me know, also did you lock the door or it autolocked?
Thanks, just reply to my answer here and I can help
Tim
Posted on Nov 08, 2010
Kenmore microwave model 721 loose door
Loose bottom hinge - slide the microwave to the edge of the counter, and look at the bottom hinge - you may have to remove something to see clearly. Its likely you are missing a screw or the screws have worked themselves loose.
Jan 20, 2014 | Kenmore 62702 Microwave Oven
Kenmore microwave 721 85032010 will turn on but won't heat or spin
Chances are that is just a defective top or bottom door switch or its mount.
See our help file on door switches here.
Also, that model number does not show up as a valid US Kenmore model.
Please check the tag in the cooking cavity or elsewhere n the oven and let us know if you need further help.
Jun 05, 2013 | Microwave Ovens
Kenmore modle 721.80042700
It may be a blown fuse or a bad thermostat / TCO on the oven cavity or above or on the microwave.
Yours should have a "mini-manual" (technical sheet) hidden either behind the grille or control panel. It is very helpful in locating and testing components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Kenmore manuals and installation instructions at http://www.managemylife.com by clicking the Manuals link near the top center of the page. Then enter your full model number from the tag on the oven on the next page.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You can order parts and find helpful exploded views at the Sears Parts Direct Web site .
May 03, 2013 | Kenmore 62622 Microwave Oven
The other day my microwave quit cooking and the turntable stopped turning. The fan still turns on and the light still works as if it is cooking but it doesn't. We shut off the power and tried again but it...
It may just be a bad door switch. See this file.
You can enter your full model number at the Sears parts site to find helpful exploded view diagrams.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
May 27, 2010 | Kenmore 62622 Microwave Oven
Kenmor microwave 62344 runs but does not cook
Check the door safety interlock system. Remove the cover - test the little switches near the door lock.
These switches fail because we all open the oven door while the oven is operating. Thbis causing arcing and failure. When they fail, the oven doesn't know the door is closed and will not turn on the heat.
Need more help with this ...please ask.
Oct 19, 2009 | Kenmore 62342 Microwave Oven
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Door glass
You should be able to find helpful exploded view diagrams if you enter your full modle number (more that 5 digits) here: http://www3.sears.com (the 3 is correct)
Nov 20, 2007 | Kenmore 62702 Microwave Oven
Child lock on Kenmore Microwave
You can contact Sears customer service via http://www.sears.com You need to have your exact / full model number (not just 5 digits) handy when you call.
May 03, 2007 | Kenmore 63672 Convection/Microwave Oven
Turn table wont shut off
This is most likely a problem with a door switch or a stuck relay or other problem on the circuit board. We have important safety information and information about door switches at our site. Our site is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If you need help with a control panel repair, we fix them nationwide for $32.50 postpaid in most cases.
Feb 23, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
