Question about Maytag PGR5710 Performa Gas Kitchen Range
My Maytag Model PGR5710BDW stove does not heat up in Bake mode but does work in Broil Mode. The stove is over 10 years old and we just replaced the computer board less than 8 months ago.
SOURCE: Gas stove Thermadore 36 inch Model PGR366 PL Oven wont bake but will broil
this may seem like a silly question if you've already tried it but have you checked the over temp breaker? If you have no idea what I'm saying there is a breaker on the back side of your machine. Of course Thermador is so kind to place it convenietly behind the back panel so you'll have to remove that. There should be a little red button in there somewhere toward the top middle half of the machine I should say. If you press that button it may work.
Posted on Nov 11, 2008
  • 126 Answers
SOURCE: Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Posted on Jan 16, 2009
VtToolMan
  • 704 Answers
SOURCE: My stove is not allowing to bake. The broil works
It would appear that the electric ignitor isn't functioning as it should and might need to be replaced.
You can remove the oven racks and the bottom oven floor to observe the ignitor. now turn the oven on and see if the ignitor glows, if not, the ignitor is faulty and needs to be replaced.
You can enter in your full model number at the following site and get the replacement part number (and price). If you're going to do the repair yourself, be sure to turn off the power or unplug the range from the power outlet before doing any work on it.
You'll need to pull the oven out so you can get at the backside panel where the electrical connections are located. There is also a screw on the inside of the oven that holds the lower iginitor in place. Simply remove and replace the faulty one with the new one and you should be fine.
If you want to confirm that the ignitor is the only issue, you can swap out the broiler ignitor with the oven (lower) ignitor, as they should be the same part for your range. If you swap them and the oven doesn't ignite, then the faulty part is probably either thermocouple that tells the gas inlet valve control, which lets gas enter into the oven. The thermocouple which tells the gas valve to open, once the ignitor has reached the proper temperature, so if the thermocouple isn't working, the gas valve won't open.
Here's a link that you can enter in your model number and get the parts list and a line drawing for your range. I think you're missing a few letters or numbers in your model#.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=JGBP90
My bet is on the ignitor as the faulty part, but the swap test will confirm that, and if the swap doesn't work, then the thermocouple is bad.
Hope you find this Very Helpful and best regards!
Posted on Sep 10, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Posted on Jan 13, 2010
Macmarkus
  • 2605 Answers
SOURCE: oven will not light in bake mode but will light
Hello, welcome to FixYa.
Based on your description, I`d suggest the hot surface ignitor for the bake burner is likely the problem. Here's what you can try to verify if it's indeed the ignitor...if you're mechanically inclined.
It'll look like this...
** FIRST unplug the range and turn off the gas to the appliance before attempting any service...safety first**
since your boiler has the same ignitor ( some do some don't, only a model number would confirm or dismiss this...thankfully you provided yours ) one could swap the ignitor`s ( very carefully, they are very fragile and don`t like to be handled ) this will allow you to use the bake burner, but it will leave you without the broil function...until you can purchase another.
This will confirm or dismiss if the ignitor is at fault...99% of the time this is the case.
Many people overlook the ignitor, especially if it "glows" since that gives the untrained person the impression it works...that is not the case however.
You can also ohm it out to test it as follows...
You should be able to find one at most brick & mortar appliance parts vendors or on-line depot's such as "repairclinic.com", "searspartsdirect.com" to name a couple.
You can ask for part number based on the model number for the bake & broil ignitor. The number I got based on the premise it is a JGBP90 model is part # WB13K21
I would still double check with your model number with the part`s professional`s.
Hope that help`s. It is very unlikely to be the control panel/timer contrary to what your repairman has said...in my opinion. Let me know if I can assist you further and good luck.
Thank`s for visiting "fixya" for your repair needs.
Regards,
Macmarkus :)
Posted on May 23, 2011
Top element does not work in bake mode,but it does work in broil mode
The top element is a broil element and will not come on in bake mode just as the lower bake element will not come on during the broil mode
Aug 21, 2011 | Maytag MER5775Q Electric Kitchen Range
My 2003 Matag range model mer5770 will no heat in bake mode. The bottem or top element wont heat although the top element will heat on broil Hi mode. Also when bake mode is on the oven control shows both...
,first make sure you have 240 volts going to the stove,the broil runs on 120 volts,the bake on 240 volts,unplug it,remove the two screws and pull out the bake element,pull off at least one wire and read it out with a meter,if it's good remove the back panel,check for burnt wires,plug it back in and where the block is or where the cord connects to the machine make sure you have 240 volts,if you do you the computer board is bad or the clock assy. part number 5701M556-60 and it's around 225 dollars on the sears site,when you call your parts store give them the full number off the machine,the number that came up was mer577oaaa.hope this helps.also when the bake is on the broil element heats up too,that's why both elements show up,if the relay is bad in the clock assy,you can't get a new relay you have to change out the whole assy.
Feb 27, 2011 | Maytag MER5770 Electric Kitchen Range
The oven is taking forever to heat to 250...The broil works and the stove works...The oven will not heat above 250 on regular bake mode
Sounds like the bottom element is not working, Check it. If it is, there is a high limit, that shuts the oven off it it overheats. When they go bad, they shut down at lower temps. Sounds like that might be your problem
Mar 31, 2010 | Maytag MER5755QAS CleanDesign Electric...
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Stuck in broil mode
sounds like you need to call MAYTAG repair service ,control board has probably failed .we do not recommend DIY fixing of any gas appliance.
Feb 15, 2018 | Ovens
Kenmore gas stove doesn't heat properly in bake mode,takes 2hrs to heat to luke warm. Smell gas when I open door. Works fine in broil mode
hi
the heating element is coroded better to change the heating element first clean the gas valves...
thank you......
Mar 06, 2009 | Kenmore Kitchen Ranges
Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Oct 16, 2008 | Kitchen Ranges
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Maytag PGR5710 Performa Gas Kitchen Range Logo
229 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
