Computer will not turn on I believe the motherboard is bad. Is there a replacement for this
The problem is me getting a CMOS CHECKSUM error, My system clock in the bios is wrong, and when i try to change it, It freezes. My computer will not turn off or on properly due to this i have to unplug...
Your CMOS battery may be bad. This battery is an inexpensive 3.0 Volt battery mounted on your motherboard. You could buy one at a local computer store and install it but there's a lot more involved than just replacing the battery.
I reccommend that you have it replaced by a PC technician, as after he replaces it he will have to go into CMOS setup and set all the BIOS parameters. These settings must be correct in order for your motherboard and operating system to know what devices you have installed in your system.
Hopefully this will solve your problem.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 18, 2011 | Computers & Internet
After turning computer on it immediatly powersdown about a second later. repeats untill power is cut. changed PSU out and didnt fix problem. Believe it is a problem with my asus p7p55m mobo. please...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 19, 2010 | ASUS P7P55M Motherboard
Cooling vent on motherboard fell off
your processor is not working it may be harmful for pc just go to workshop they will repair your motherboard and your smps they will help you
May 02, 2010 | HP Computers & Internet
My Dell 5000e unexpectidly turns itself off.
There are a few things this could be, most of them are motherboard related, but there could be a cooling issue or a power supply issue. Check the BIOS log for "thermal events". Things like CPU overheating can cause weird reactions in the machine, called System hysteresis. Basically, the computer goes crazy, opening things, crashing, rebooting, etc. Based on what youve said, "restarts normally", I dont think there is a CPU issue, nor a memory issue.
The first thing I would try is replacing the power supply and remove the battery (just as a test), and see if the machine starts behaving better or exhibits the same issues.
I believe the issue you have described can be most likely resolved with a new motherboard, especially if the power supply route does not yield positive results. Bad news is, a p3 motherboard is rather hard to get, and hard to replace, and rather pricey. I would sooner consider getting another notebook pc before replacing the board.
Jan 24, 2010 | Dell INSPIRON 5000E (969PG) Motherboard
Computer will not turn on. Possible power surge.
If the power supply is good then your motherboard must have gone bad during a surge.
Dec 26, 2009 | Intel D865PERL Motherboard
COMPUTER DOES NOT BOOT
If nothing was disturbed then this is usually an indication of either the power supply going bad or the hard driver going bad. I start by substituting a power supply of the same wattage or larger. If that doens't work , I change out the hard driver.  I believe that is usually a good place to start.
Jan 04, 2009 | Computers & Internet
Motherboard
i believe your motherboard is already bad. have it replaced.
Sep 13, 2008 | Gigabyte GA-945GM-S2 Motherboard
I need replace my motherboard form my laptop
I believe this is a laptop and it would be cheaper and easier to buy a new one They range in price AU $7550 upward. As to replace motherboard could be expensive as a computer repair shop would have to do it
Aug 07, 2008 | Sony Computers & Internet
Won't Charge
Common fix for this problem is a simple Power Management Unit (PMU) reset. This will basically re-sync the battery "brain" to the computer so they when when to charge and when to stop. To do this, simply turn your computer off, remove battery and power cord and hold the power button down for 7-15 seconds. Then you MUST wait 15 seconds after pressing the button before applying power or inserting battery. 75% chance this will fix your problem. If Not, Replace Adapter/Charger. They have a microchip in them that can go bad that senses when to send more current to charge battery. Apple motherboards are generally better built so I'm not suspecting that at this moment. Let me know what you find out.
Jun 10, 2008 | Apple PowerBook G4 Mac Notebook
Onboard Lan causes boot and shut down problem
It sounds like you have some bad LAN circuity on your motherboard. You might try a workaround by installing a separate LAN card and using that. If the separate card doesn't solve the problem your motherboard is just bad and needs to be replaced.
Aug 19, 2006 | Abit AA8-DURAMAX Motherboard
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
