Question about Bosch Classixx WFL 2066 Front Load Washer
Cannot open the front blockage compartment
I have noticed a rattleing noise and have located it to the small compartment on the front bottom of the machine. I have tried to turn the knob, it will only turn 1/4 i am aware that any loose tems may fall into this part. but i have never had to open it before. Lost instructions. Can you advise how i open it
  • 3 more comments
  • Anonymous Jul 13, 2008
    I have the exact same problem. Please can you help
  • Anonymous Jul 17, 2008
    same problem
  • hat man Aug 04, 2008
    I have the same problem ,but mine just turns though 45 deg
  • suenorton Apr 09, 2009
    I can't open the front compartment, it turns slightly to the left, but it its impossible to open. My machine won't spin, and I have to empty the machine by using the little hose in the front compartment.
  • homerz2020 Apr 11, 2009
    I too can't open the knob it just turns 1/4 of the way!!! what can we do about it!!! need help I need to wash a lot of clothes its piling up!!!! SOMEONE HELP ME
    Vivian Velez
Lad's I Have The Same Problem, I even cut my hand trying to get this thing off.
Posted on Sep 08, 2008
Ford taurus 1994 rattling sound front engine compartment
Place the car on blocks or jack stands so the car can be driven without it going anywhere. Have someone turn the front wheels left, straight, then right while depressing the gas pedal so the tires are turning at 5 miles per hour and listen for location of noise.Have the hood open so that you can listen for that noise that you say the car motor is making.
Sep 07, 2014 | 1994 Ford Taurus
How to replace struts on chevy express van
They are all the same unbolt and replace
Mar 31, 2013 | 2002 Chevrolet Express
Rattling noise coming from upper compartment
remove the suction port covers at both of these locations:
Dec 02, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hoptpoint Washer Dryer - rattling noise and leak from underneath
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | Kenmore Elite 45986 Front Load Washer
JennAir JFC2087HRS makes creaking noises like an old door or someone's stomach growling all day. Now noticed that ice maker not working. Suggestions on how to fix?
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Apr 01, 2010 | Jenn-Air JFC2087HRS Side by Side...
I am getting a loud rattling noise. could this be my compressor
Jan 29, 2010 | Frigidaire Refrigerators
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
A creaking noise when the freezer is opened & then closed
In some freezers they build up excessive vacuum which pulls the plastic housing away from the internal polyurethane insulation, hence the creaking sound. You can make a vacuum breaker by attaching a small stick or similar to the bottom of the door gasket, this will break the vacuum without losing temperature.
Mar 12, 2009 | Refrigerators
Rattle/Vibration from front of vehicle when idling at stop
Hi and welcome to FixYa. Please try this:
GO out to the car, and lift up on the hood. Does it raise a bit and rattle? If so;
Open the hood, and look at the perimeter of the front radiator support. You will see 2 small rubber thingys, that look like that they are screwed onto the metal that is holding the radiator. Unscrew them a little, and close the hood. Pull up on the hood and see if the rattle goes away. If not, repeat unscrewing the rubber things until the lift disappears.
A FixYa rating (4 blue diamonds) would be greatly appreciated for my assistance.
Feb 10, 2009 | 2005 Toyota ECHO
Bosch Classixx WFL 2066 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
