Question about Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt
The problem with my Line 6 is that no matter what setting it is on, it sounds clean and has some effect. Before, the "Insane" button would provide a very heavy metal sound, but now it just sounds a lot less heavy, almost like the Drive is turned all the way down, but it isn't.
    President:
  • 1,138 Answers
See the reset procedure here:http://line6.com/community/docs/DO Here is another link that might help:http://line6.com/community/docs/DOC-4519
Posted on Nov 09, 2010
Why is channel 1 clean/green not allowing my effects pedals to be heard? Only straight clean is audible. On all other channels they are present. Has anyone had this same issue? If so, is there a solution?...
Frankly, I've never heard of this problem and I've used Line 6 gear for years. I suggest contacting Line 6 customer support. Here is a link to their contact page
Line 6 Support
Mar 02, 2015 | Music
"Insane button has stopped working"
those micro switches tend to go out after awhile. what i have done is (if you have experience with circuit board handling and are proficient at soldering.) de-solder the bad switch and take it down to radio shack and have them size it up. and just replace it. i have had to do this with several of my line 6 products
May 25, 2014 | Line 6 Spider Iii 30
Line 6 how do i get it to work
Line 6 connected to AC power and LED showing power to unit. Guitar into effect input, effect output to guitar amp. Does guitar make sound through amp in bypass mode? No then check cables...yes then use foot switch to turn Line 6 effects unit on. Adjust control knobs for desired effect levels/settings.
If pedal provides no effects...off/on switch defective or internal electronics in need of repair.
Oct 26, 2012 | Line 6 DL4 Delay Modeler Effects Guitar
Wheres the preset button on a line 6 spider III 30 WATT
I am guessing that you are trying to replace the presets the amp comes with, with your own. In which case all you do is dial in the sound you want and then hold either the clean,crunch,metal, or insane buttons until you see the light flash. Usually hold it for about four seconds.
Mar 08, 2010 | Line 6 Spider Iii 30
How do i change the settings on my line 6 FBV Express MK11 pedals A B C D to settings that i use?
Hi, befarms. The line 6 FBV Express allows you to select the A B C D in the existing/current bank. You will not be able to change the current bank, disable or enable the effects.
What you can do is, save the preset on the bank number that you desire by holding down the channel button on your amp whether it is A B C or D. Then when the button flashes, you can reinsert or rename the preset and save it to the channel(or bank) that you wish for by scrolling to the bank number and pushing the button on the amp (A B Cor D).
Therefore, you will be able to save your personal setting to a specific bank and channel.
Hope it helps you.
Feb 01, 2010 | Line 6 Music
Only the clean and insane channels are working, i no longer have the crunch or metal channel i get no distortion on these 2? the amp is only 2 years since i bought it brand new and the metal channel is my...
If you have the manual try doing a factory reset. The info is here:http://line6.com/community/docs/DOC-4499 You might also be interested in joining this forum:http://line6.com/community/community/support/amplifiers/spider?view=discussions
Jan 23, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
When you 1st buy the amp when u turn it on it always starts on the Insane Channel when i turn my own now it starts on the Clean Channel and gives no sound on any channel and when the cable is not connected...
The post at this site might help:http://line6.com/community/message/59307 Also this chart if you don't have it:http://bx.line6.com/spiderii/pdf/spider2_settings.pdf Try doing the reset first and if that doesn't work try contacting them. Did this help?
Oct 23, 2009 | Line 6 Spider Iii 30
My Line 6 spider II amplifier sounds crappy. I need a quick fix.
If you are using the factory settings, and you have accidently changed the settings. Look at your manual and it tells you how to get it back to factory settings. If you tweaked the clean channel when you got it, you will have to play around with the settings to get what you want. Hope this is helpful.
Mar 21, 2009 | Music
Open Questions:
See all Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Questions
Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt Logo
146 people viewed this question
Top Line 6 Music Experts
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
freddybrass
Level 1 Expert
Don Hart
Are you a Line 6 Music Expert? Answer questions, earn points and help others
