Question about Acer (54.AA806.001) Sound Card
Laptop stopped playing audio - Acer (54.AA806.001) Sound Card
How do I fix Dell Latitude E5430 audio? Look in the details section for more info.
When this happens, go to device manager in the control panel and look for the audio section under sound video and game controllers. Then delete them and reboot the computer, if it is a driver issue the drivers will reinstall, if it is a hardware issue, they wont and you will know that the sound card chip is bad.
Mar 09, 2016 | Dell Computers & Internet
My laptop plays audio by itself and I can't find out how to close it. Please help.
what applications if any do you have open, if you have facebook or some other social media page it's possible that there is an Ad playing music. facebook for example has an ad for a game (some kind of castle in the pic) that plays audio and you have to search for the pause/stop button so it will *******.
Apr 05, 2012 | ASUS Computers & Internet
My Compaq Celeron processor laptop stopped playing audio for a yera now. However, I am able to hear audio through the USB port
be sure its driver is the correct one from hp compaq web site its may be stop the sound best regardes
Mar 28, 2011 | Compaq Computers & Internet
Having sound problem in my laptop after i got plug in the headset , but the sounds coming through the headset but vice versa in laptop
Go to Control Panel >> Sound >> Play back tab >> Right click on Speaker and set it default.
Connect Headset >> Play any music >> As soon as the music started, remove the headset with a slight ****.
Restart Audio services if issue is same and then update the audio driver.
Start search >> services.msc >> right pane, double click on Windows Audio >> Stop >> Start >> Startup Type: Automatic.
Update the drivers
Jul 28, 2010 | Computers & Internet
I have sound from my HP5500 laptop but the volume is very low, it works great when played through external speakers or headphones??? Regards, Tony
On another HP laptop, the solution ended up being to stop the audio services and then restart them. In Vista (Win 7 will be similar), Press the Windows key then hit R. In the Run window, type services.msc and hit enter. Scroll down and look for any Windows Audio Service (or related items), if they are Started, click Stop and OK.
Reopen the services window (as above). Now click Start for each audio item, click Apply, and then click OK. Check the audio volume.
I hope this helps.
(Setting the Windows Audio to Manual sometimes is needed. In the case of the laptop I dealt with, the above solution has continued to work through multiple reboots.)
Dec 26, 2009 | HP 530 Notebook PC
My lap top has stopped playing audio
Right click the volume control - select open - this will open a larger volume control showing the volumes for each type of sound. Make sure none of the sliders are muted or low.
Apr 20, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Problem with c graphics and playing audio and video
i have suggestion..i think youre windows/operating system need to re-install,,,then install carefully the mother board installer/CD Driver...
i think..Thanks
Apr 02, 2009 | Acer Aspire 5920-6335 Laptop
REQUIRED VIDEO DRIVER SOFTWARE FOR ABOVE LAPTOP . 1. NO VIDEO WHILE PLAYING DVD ON WINDOW MEDIA ONLY AUDIO. 2. IN POWER DVD OR VLC MEDIA PLAYER, VIDEO AND AUDIO IS IS NOT PLAYING SMOOTHLY AS NORMAL BUT...
1. It seems to be codec problem . Download K-Lite Mega Pack and install it. Then try playing the movie in windows media player classic that comes with k lite mega codec pack.
2. check your system for trojan , virus or any program that is using system resources. Often Video problems are caused by insufficient resources available by video/audio decoders.
3. System stand by could be missing because your bios settings dont allow it. Enter the BIOS and reset settings to default.
Mar 21, 2009 | Computers & Internet
How to play audio clip in java
  • Create an AudioClip object
  • Load .au sound file into AudioClip
  • Play sounds once or loop continuously
  • Stop playback
Here's how the code for these steps looks:
import java.applet.*;
AudioClip ac = getAudioClip(getCodeBase(), soundFile);
ac.play(); //play once
ac.stop(); //stop playing
ac.loop(); //play continuously
It would seem logical to use this same code to play audio clips in a Java application. Unfortunately, if you do that you will get errors from the compiler. Why? Because the AudioClip object and the getAudioClip() method are part of the java.applet package -- and are not part of applications. The good news is we can dive down and make things work ourselves.
The trick to solving this problem is to use some undocumented features that are provided by Sun in its JDK. Taking a peek inside the classes.zip file from the Sun JDK (using any of the various zipfile utilities), we find not only the standard Java packages such as java.applet but also sun.audio. (These are in the directory sun/audio.)
The sun.audio package contains everything we need to be able to play audio clips! Here's the code:
import sun.audio.*; //import the sun.audio package
import java.io.*;
//** add this into your application code as appropriate
// Open an input stream to the audio file.
InputStream in = new FileInputStream(Filename);
// Create an AudioStream object from the input stream.
AudioStream as = new AudioStream(in);
// Use the static class member "player" from class AudioPlayer to play
// clip.
AudioPlayer.player.start(as);
// Similarly, to stop the audio.
AudioPlayer.player.stop(as);
To use a URL as the audio stream source, substitute the following for the input stream and audio stream setup:
AudioStream as = new AudioStream (url.openStream());
Playing the audio stream continuously adds a bit more complexity:
// Create audio stream as discussed previously.
// Create AudioData source.
AudioData data = as.getData();
// Create ContinuousAudioDataStream.
ContinuousAudioDataStream cas = new ContinuousAudioDataStream (data);
// Play audio.
AudioPlayer.player.play (cas);
AudioPlayer.player.stop (cas);
Jan 22, 2009 | Computers & Internet
My laptop's sound has all of a sudden stopped.
Generic problem for all Sound Cards My laptop's sound has all of a sudden stopped.
Jan 07, 2009 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
