Question about JVC Televison & Video
Model no.DR-MV99BU dvd recorder will not read bought dvd s
    Novelist:
    Champion:
  • 225 Answers
Clean laser lens (fish eye looking thingy) with dry Q-tip.
Posted on Nov 08, 2010
Says "not connected to camcorder"; how can we just get it to read & "autoplay" simple dvd's we put in?JVC
Probably because you have not selected the appropriate "INPUT" (DVD/VCR, etc) from your remote. It plays the DVD you put in but you cannot watch it on your TV because you have not selected the right A/V input source. Hre is a link to the user's manual.
JVC DVD VIDEO RECORDER DR MV99BU Quick Start Manual
Jan 08, 2015 | JVC Televison & Video
Tip
Well, My JVC DR MV1s is reading and records my DVD-R but it stop reading and...
The most common mechanical problems that can prevent a dvd player from playing or reading the discs are the following:
1. The spindle motor not functioning properly (this is by far the most common, if the spindle motor is not spinning the discs then the optical lens can not read them). For the most part it is an cheap part to replace averaging around 25-35 dollars if you can replace it yourself. If you do not know how and have to take it to a repair shop expect to pay 50-75 dollars in labor depending on the area you live in. The best thing is to do some comparison shopping and call the different repair shops and get estimates. The key is to listen closely when you insert the disk into the player, you should be able to hear it spin up. If you hear nothing then that is most likely the problem.
2. The tray could be out of alignment. This is another easy and cheap fix if you have the proper tools. This could happen if you drop or pull/push to hard on the tray (which you should not really do anyway, but always use the open and close button). This is an example picture of the drive assembly with the tray open.
3. The small gears are plastic and often break, this will cause the players other parts to not move and function properly. They are difficult to reach, but inexpensive to replace. It is always recommended that you always order any part from the manufacturer of the device. A visual inspection is usually required to determine if the small teeth have been broken, which requires for the most part taking out the carriage assembly.
4. The small belt drives either break or come off. Again, this will cause the other mechanical parts not to function. They are difficult to put back on as well, so you may need an extra pair of hands if you have not done this before. On average you will usually have 2-3 of them inside your player.
5. The Optical reader has malfunctioned. This is the most expensive thing to replace, so you might consider purchasing another player depending on how much you want to spend and the original cost of the device, unless you can find a great deal on the part you need. You can check to see if the laser is firing with a visual inspection (DO NOT LOOK DIRECTLY INTO THE LASER) put in a disc with the case off and you should see the glow of the laser hitting the disc. You can also see the spindle/spindle motor.
Picture of the optical reading assembly dismantled:
6. The tray also has a drive motor which can fail and cause the cd tray not to open and it also has a track that it rides on (located in the drive assembly). Check these two components if you are having problems with your tray not opening and closing properly or stops working completely. Sometimes, the tray will open and then immediately close on it's own. This is usually caused by the track being dirty or some type of debris is lodged in the track. Cleaning the inside of the player with a can of compressed air will help remove dust and dirt. Blowing out the inside of the device once a month is a good preventative maintenance measure.
CAUTION: When working with any electrical device, you should always ensure safety first. Make sure that the device is turned off and unplugged from any power source. This does not completely prevent electrical shocks because Capacitors will hold an electrical charge for some time even if the device is turned off and unplugged.
The following are example pictures of what Capacitors look like:
on Sep 24, 2008 | Philips DVP5140 DVD Player
Does the JVC DR-MV5S DVD recorder/VCR combo unit have an analog tuner or digital tuner, so that you can record one channel while watching a different channel on your TV?
You can read what JVC is telling about the recorder. It is not an digital tuner, but still you can record a DVD and watch another channel or vice versa.
Want to read the whole manual? click the link:
DVD Recorder Hi Fi VHS Combination DR MV5S Introduction
Jul 25, 2014 | JVC DR-MV5S DVD Recorder/VCR
Our DVD will not read discs. Some that we bought in asia will work but none rented here in the USA. Is there a switch we are missing?
I'm assuming you bought the DVD recorder in Asia as well. US DVDs are region 1 and won't play on a player/recorder from another region without alteration. (See http://en.wikipedia.org/wiki/Dvd_regions for a description of DVD regions). There's nothing as simple as a switch unfortunately.
You may be able to find a way of altering your recorder to play all regions (region-free) but you need to be careful when doing this. Here is one person's story of this going wrong with the same model JVC.
A safer alternative may be to buy another recorder in the USA.
Apr 11, 2010 | JVC DR-MV7 DVD Recorder/VCR
I bought a new JVC dvd recorder vcr combo model#dr-mv79b. I lost the manual and need another one. When can I get another one?
DR-MV79BC:
http://books.jvc.com/booklist.asp?Model=DR-MV79BC
DR-MV79BJ:
http://books.jvc.com/booklist.asp?Model=DR-MV79BJ
Mar 14, 2010 | JVC DR-MV78B DVD Recorder
I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Feb 03, 2009 | JVC DR-MV1S DVD Recorder/VCR
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-MV1SU DVD user manual
http://books.jvcservice.com/booklist.asp?Model=DR-MV1SU
JVC allows download of their manuals in PDF.
Jan 15, 2008 | JVC DR-MV1SU DVD Recorder/VCR
JVC - DVD Video Recorder Model No.: DR-MV5SAX
1 yıl önce JVC DR-MV5SAX MODEL , 062C0323 seri no'lu bir cihaz aldım. Kayıt anında 4-5 dakika sonra "RESETTING" diye mesaj veriyor ve cihaz kendisini kapatıyor. Ne yapmam gerekiyor.
Alaettin Zengin 0 312 290 31 97 Ankara
Nov 08, 2007 | Televison & Video
JVC DR-M100S
I have a JVC DR-MH50 DVD/HD recorder and it will only record on DVD-R or DVD-RW not DVD+R or +RW. so check your format of disk you are trying to record on it may be as simple as that.
Sep 04, 2006 | JVC DR-M100S
Televison & Video Logo
52 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
