Question about Hayward Aquabug Above Ground Pool Cleaner Hay500
Turning only one direction - Hayward Aquabug Above Ground Pool Cleaner Hay500
    Problem Solver:
  • 16 Answers
The gear box is bad or has debris in it or a screw has come loose that connects the a-frame to the pod. I would recommend you take the cleaner to a pool store unless you are familiar how to take the cleaner most of way apart. They can check it out and fix or replace any parts needed.
Posted on Dec 29, 2010
My Toyota corrola 4afe engine fan is turning with aircon and is turning the wrong direction
fans on cars are dc fans and that means to change direction of rotation change the wires over ( that changes the motor polarity)
Jan 31, 2016 | Toyota Cars & Trucks
In what direction loosens the bolt holding the blades on?
Normally on fast moving parts the direction of turning determines the direction of thread. I say normally, but this will not be the case EVERY time, just more often than not. If the blades travel in a clockwise direction, then the bolt will also tighten in a clockwise direction. So, if counter clockwise is the direction of turning then so will the bolt. This is because if the turning of the bolt was opposite to turning of the blade, the bolt could unscrew itself whilst in use and that could end in tears
Sep 28, 2015 | Garden
My car makes a clicking noise from the right tire when turning either direction
It could probably be your passenger CV Axle that needs to be replaced. They tend to make a loud/soft clicking noise if they go out.
Jan 18, 2013 | 2003 Chevrolet Cavalier
I have a problem with my 1998 yamaha125 breeze atv, i think the engine is turning over backwards, there is an arrow on the flywheel, pointing to the front of the bike, does that arrow indicate engine...
most engines turn the same way, looking from the left side the flywheel turns anticlockwise.
never checked for spark on a backwards turning engine, I guess it should still spark
Jul 08, 2011 | Yamaha Vorona Motorcycles
My dryer knob has broken again. Wich direction should I be turning the knob when choosing a drying cycle? I was told I was turning wrong direction.
GE dryers turn in the clockwise direction and if you turn in the counterclockwise direction you could break the stops off the switch.
Jun 20, 2011 | GE Dryers
My washing machin suddenly stop while I was doing laundry when it gt fill with water
After water filled, the machine will enter agitation mode. It stopped since the mechanism to engage the agitation to one direction of motor turning is not engaged. It is a helix nut to lock in the direction of motor turning (motor has 2 direction : one is for agitating and the other is for spinning). It is worn out and needed replacement.
Sep 20, 2010 | Kenmore Washing Machines
Steering column wont turn ignition is stuck
Rock Steering Wheel Back and Fourth While Turning KEY.
Or If the Wheels are Turned HARD in one direction you mest Turn Steer Wheel in THAT Direction While Turning KEY
Dec 23, 2009 | 1998 Dodge Caravan
Directions on turning on and off the Crystal Eye
In your user guide (Start, My Computer, Acer (C:), Folder labeled "Book").
Mar 01, 2009 | Acer Aspire 6930-6771 Laptop
Belt sander adjustment
There should be a knob on the front of the sander which adjusts the front roller on the sander. If the belt runs off in the same direction each time try turning the knob as the sander is running and while watching the belt. If turning the knob one direction does not work try turning the other direction. If turning the knob does not have any affect on the way the belt tracks on the sander then you probably have a broken or missing part on the front of the sander. This may require taking the sander to a service center.
Sep 15, 2008 | Tools & Hardware - Others
SA-AK95 volume control problem
This volume controls is actually what is called an encoder. The control itself needs to be replaced. Figure on $5-$10 for the part plus the local labor rate for the total repair cost.
Dan
May 01, 2008 | Panasonic SC-AK75 Shelf System
Hayward Aquabug Above Ground Pool Cleaner Hay500 Logo
164 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
