Question about Jenn-Air 24 in. JDB1090AWS Stainless Steel Built-in Dishwasher
Dishwahser won't start, start button won't light
All of a sudden the start button won't light up or actually start the dishwasher. We've turned off the power and nothing seems to get the washer to start. Help!
  • supra661 Nov 20, 2008
    I have the same problem with my Jenn-Air dishwasher as well.... I have already taken the door apart once and "operated" on it.... I will next try the suggestion I just saw on this page (cleaning the ribbon cable contacts), as I observed last time I was in there that it appeared as though that was a poor design and subject to corrosion.
    As an electrical engineer, I have a little bit of insight into the proper design of electronics (I work in the aerospace/military space industry -i.e. high reliability products is what I do best)
    So far, here is what I've observed about the design of this product:
    1) The steam ventillation when drying is accomplished at the back of the unit. Because the unit is installed in a relatively tight space under my cabinets, it essentially creates a sauna for itself when drying the dishes. It is so bad, in fact, that the seam between the quartz counter and backboard above the dishwasher has actually come unglued and will "ooze" water if the dishwasher is used too much... -Solution = I am going to add: add better ventilation beneath the cabinets to provide an exit for the steam. -I may put a small computer case fan under there with a small thermostat to kick it on as soon as the dishwasher gets warm from the heated dry cycle operating.
    2) The bottom of the inside panel of the front door of this model actually rests slightly IN the wash tub area of the unit, meaning a small amount of water is actually pooled into that space as the unit runs. -It has drains to exit out when done... BUT the water is HOT, which creates STEAM!... And guess what else resides inside the door, up higher where something like STEAM would rise up and condense on.... YES! you are right, it is the control circuitry for the dishwasher -along with that ribbon cable interface to the touch panel at the top of the door. ---The GOOD news is, the computer board is actually coated very nicely with what appears to be a standard RTV silicone (waterproof sealant) compound. -Thus, I honestly believe that in general it is at least "okay" to house the electronics as designed in this very moist/humid environment inside the door.... HOWEVER, the same can NOT be said for the connectors, relays, and cables that interface *with* the electronics... None of them are protected from corrosion in any way, and most are made of simple lead-free solder (easy to corrode), copper (also easy to corrode, brass (again easy to corrode), and nickel (can also corrode but not so bad).... As to the LARGER connectors, the ones that switch the heater on/off, run the electric pump motor and solenoids, etc, they all appeared to be perfectly fine in my now 3 year old dishwasher.... The RIBBON CABLE is another story. Normally for an interface like that, with such delicate connections and the extreme humid/wet environment, a competent design would use gold plated connections for the ribbon cable and the "pins" in its mating connector on the controller card (costlier, yes, but they DO NOT CORRODE!)
    ........Soooooo the point of all the above is, I am betting that the connector there is the problem. I am going to take the door apart again, and clean the ribbon cable gently with de-ionized water and alcohol. If necessary, i will scrub at the individual connection points (pads) on the cable with either a pencil eraser or possibly even a **light** scrub with some very fine sandpaper (followed with another rinse as before)... HOPEFULLY the mating connector contacts aren't too bad, because I don't think they can be cleaned very easily without risking damage to the "pins" in there. When I get this all done, I'll get back here and report if it works or not... My guess is that it will.
I took the door apart, removed the control board, which I had expected to replace. I disconnected the ribbon cable that connects the control panel to control board cleaned the connections and reassembled everything. The dishwasher has been working since.
Posted on Jul 03, 2008
Red light comes on but power button won't turn it on
Please confirm actual brand and model as it is not clear what set you have
Mar 11, 2012 | Televison & Video
I have a Maytag LSE1000. The dryer and washer each have an issue at the moment. The dryer intermittently won't engage when it is turned in. When you press the "regular" button to start it,...
I really have NO idea what's causing your Maytags to misbehave, BUT I can tell you that the Maytag service centers have always been very accommodating when I've called about problems with dishwashers, dryers, and washing machines.They have explained the construction of the appliance and even told me the type of tools I needed to make repairs! If you still have your owner's manual, the toll free number should be in there. I hope this helps!
Jul 28, 2011 | Maytag Dryers
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Zanussi Aquapulse DE6854 dishwahser programe lights not working
got same probleme with my aquapulse 4744 slimline
Oct 07, 2009 | Electrolux Dishwashers
Bosch dishwasher Start Process
lol...yes this is normal for a Bosch. They have several "safety" measures incorporated into their dishwashers. Look on the bright side they are one of the very best dishwashers on the market and are known for their longevity and quietness.
Jul 31, 2009 | Dishwashers
DIshwasher wont start, flashes pre-wash and was lights
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position).
Apr 19, 2009 | Ariston Technologies L63SNA Stainless...
The normal and cancel blinking, dishwahser not work
This usually means a microprocessor failure. Under the lower toe kick plate is the tech sheet( some phillips head screws) and the sheet will tell you what the two blinking lights mean.
Good Luck!
Jan 09, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Indesit dishwasher.
It sounds like the anti flood switch is activated, lean the dishwasher back at a 45 degree angle. If water comes out the back you have a leak. Stand it up and try it try dishwasher, if it works this comfirms leak, you will need to find where it is coming from.
Dec 03, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Prima lpr 600 dishwahser
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No Heat Dry" button for 4 seconds (or more.  I'd suggest trying this on yours...
Oct 14, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Jenn-Air 24 in. JDB1090AWS Stainless Steel Built-in Dishwasher Logo
1,019 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
