I have no sound card how do i install one - Computers & Internet
How to instal sound card
i cant understand what you exactly want ??? sound card installation or sound card driver installation ??? if u want to install sound card driver then just put a CD given with sound card into drive n simply install it and if you want to install sound card into your laptop then you have to go to manufacturer's service center ok??? ahope this will solve your problem...
Jul 07, 2010 | Dell Inspiron 6000 Notebook
No soud in my pc..what can i do for this problem?
It mean Your sound card driver is not installed. Installation of Sound Card.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install
  • if the problem is still exist.
  • Replace the sound card or have a local tech take a look at the sound card.
May 10, 2010 | Creative Labs Sound Blaster Live! 5.1...
No audio card inspiron 6400
Sound Card Drivers
Mar 19, 2010 | Computers & Internet
Sound card stopped working
1st you disable the onboard sound card in BIOS level, then install/update the sound driver for Maddog Prowler 4.1 DSP soud card will solve your problem.
Dec 08, 2009 | Mad Dog Multimedia Prowler 4.1 DSP Sound...
I dont have sound
Good day sir, sound problems solutions could be any of the following:
  • You did not install a sound card, the enlight enpc has no built in sound port, so you need to install one, I recomend Creative Labs or Realtek sound card, (any sound card will do if you like).
  • If you buy one, there is a CD driver, use the CD to install the sound card driver files.
  • Or buy a USB sound card. (as long as you are using the XP windows version for compatibility.
Install the sound card on any available PCI slot and use the CD to install the driver. thats it!
Nov 04, 2009 | Enlight ENPC KB23 Motherboard
Sound
You will need drivers for your sound card. Go to Control Panel.....select Device Manager....find your sound card on the list.....Right click on it and select Properties........select drivers tab.......have windows look for drivers and install. You can also install your card in ADD/REMOVE HADRWARE in control panel. Have windows search for new hardware. When it finds your sound card follow prompts to install.
Aug 14, 2009 | Intel Frontier Design Dakota 24-Bit PCI...
I want install my sound card by net c97 now
Hy i'm Kabeer Khan for installing sound card it is first required AMR(Audio Modem Riser) slot on your motherboard. AMR slot is 64 pin very smal slot is like as PCI(Peripheral Compnent Interconnect) If it avialable then open your sound card and try to set your sound card. Remember one thing during installing card it must be considered that the cuts of slots should be matched according to your card alignment. After installing card bind you CPU and install driver that would be given with your sound card packet for this open conrol panel and found add hardware icon and double click on it then install driver from CD option would be selected and click next. When wizard is finished you will be able to use your sound card.
Thanks.
Regards
Kabeer Khan
Apr 20, 2009 | M-Audio Audiophile Sound Card
HOW TO INSTALL SOUND CARD DRIVERS WITH CD ROM
Providing the CD Rom, is the same software as the sound-card.
If the sound card, is a seperate ( Add-On ) the drivers cd should accompany the card. if there are no drivers with the card. you can usually visit the manufacturers website ( Support centre ) And download the Drivers.
Additionally, you may have to disable the on-board sound-card ( Via The Bios ) and instruct the computer to start up, with the required or installed card.
If you are running an operating system, such as Windows XP, it should automatically detect and install the best drivers for the device. although you may not get full functionability.
If you install from CD Rom, ensure the card is installed first, then insert the CD, and open to find the Icon ( setup.exe Or Similar )
Mike@Compurepair.
Aug 19, 2008 | Foxconn P4M9007MB-8RS2H Motherboard
SOUND DRIVERS
in your computer sound card problem. otherwise please check the control pannal in sounds and vedios.
then check the computer wheather the sound card installed or not. if the sound card not installed please installed the sound card drivers.
Aug 16, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Sound card
install the driver cd of your sound card prior from this, you should have installed the motherboard cd
Dec 02, 2007 | Creative Labs Sound Blaster 5.1 Audio...
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
