Question about IBM Wheelwriter 30 Typewriter
WHEN DEPRESSING THER SPACE BAR, THE PRINT WHEEL BACKSPACES INSTEAD OF ADVANCING TO THE RIGHT. I'M ALSO GETTING A 215 CODE.
  • IBM Master
  • 3,594 Answers
You are probably in centering mode code "C" should get you out of that. 215 coce is not sensing the printwheel, remove theP/W, look for debris in that area, if you have some canned air blow the area out. If the problem persists you will need a printwheel sensor.
DickyO
Posted on Nov 08, 2010
IBM Wheelwriter 30 Series II is showing an error code of 215 with a box with a slash through it and am unable to type on it
215 is a Print Wheel error. Remove the print wheel, look for debris in the P/W area, if you have a compressed air source blow the P/W area out. If these don't work the P/W sensor is probably bad.
DickyO
Sep 07, 2011 | IBM Wheelwriter 30 Typewriter
When I try to punch in the number to192.168.0.1" it says servor cannot be found and I have internet use
It may be because your Default Gateway is set to a different IP number.
Press the Windows Key (the one with the Windows Flag on it near the [SPACE BAR] on your keyboard and while depressing it press the [R] key. Release them both.
A command window should open.
In the command window, type: IPCONFIG /ALL and press [ENTER]
Look for a line that reads: Default Gateway . . . . . . . . . : ***.***.***.***
The number that ***.***.***.*** represents will be your Default Gateway and what you would type in instead of 192.168.0.1
Sep 04, 2011 | Computers & Internet
Lexmark wheelwriter 3500 indicates code 215.
215 is print wheel error. Remove the printwheel look for dirt and debris in that area, if you have a compressed air source blow thw P/W area out. If these don't work the printwheel sensor is likely bad.
DickyO
Jun 17, 2011 | Lexmark Wheelwriter 3500 Typewriter
Error 215 code. Looks like a small part that is attached to a spring under the daisy wheel is either broken or loose.
215 is a print wheel error. If you have the "FLAG" broken it will have to be replaced. You will probably need a tech.
DickyO
Mar 15, 2011 | IBM Office Equipment & Supplies
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
Space bar doesn't work
IF YOU HEAR A SLIGHT CLICK WHEN DEPRESSING THE SPACE BAR, THE BAR AND SPRING ARE OK, THE TROUBLE IS EITHER A BROKEN OR DAMAGED KEYBOARD MEMBRANE. IT IS A SEALED UNIT AND SHOULD BE SENT TO A REPAIR CENTER TO BE RE-BUILT. OR TRY TO BUY A NON FUNCTIONING WW 3500 AND SWAP THE KEYBOARD UNIT
Aug 18, 2010 | Lexmark Wheelwriter 3500 Typewriter
Can not print on letter headed paper
probably itsa different size and this is the issue ..cause the actual paper does not have much to do with cause most printers work with all kinda paper *** long as it is the right dimension in format ...A4 in general ...
so ...print your logo on paper that will be detected...you can also make a trial first ...
Oct 07, 2009 | Kodak ESP 5 Printer
TYPING II IN PLACE OF LETTERS
the mark you are seeing is the print hammer hitting the paper. remove the ribbon. corr. tape & print wheel. turn on the typewriter. close cover let it home it's self. open cover put in print wheel. close cover let it nome. put in ribbon close cover. try typing if marks are still ther. you will need a new print wheel. if working then put in corr. tape or if you are better at spelling then me you will not need it
Jan 21, 2009 | Smith Corona Wordsmith 200 Typewriter
Reset Margins
on the upper L.H. side of the key board ther is a button marked MAR REL. turn typ. on press the return key then press the MAR REL key back space to move the carrier backwards or space bar to go forwords. when you are at the spot you need to be fined the button that reads L MRG. press it know your left hand margin is set,
know space the carrier over to the left by the space bar if it stops befor you whant it to press the MAR REL button space to where you whant.
now you have another button saying L MAR
press that and you left hand margin is set. Or the R MAR has small green letters saying L MAR if so you need to hold down the CODE key wile pressing the R MAG key ( any thing in green on key board can only be actavated by the code key ) hope this works
Jan 21, 2009 | Brother GX-6750 Typewriter
IBM Wheelwriter 30 Typewriter Logo
153 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
