Question about Cisco Photosmart C4780 Wireless AllInOne Printer With Linksys By Cisco WirelessN Broadband Router
How do I add the MAC addressof my printer to my wireless router? I've got a MAC address number and the router is a inventel.
  • Cisco Master
  • 7,733 Answers
Add MAC address of wireless printer to my router
You need to log into the control panel of the router from your PC and then create an IP Reservation for that MAC address. As you do not state the brand of router I cannot answer completely.
Sep 08, 2016 | PRINTER Office Equipment & Supplies
Tip
Set up a Wireless printer on your Router for use with a wired PC
First install the Wireless printer driver using the Wizard by connecting either the Ethernet cable to the router during the install process when asked this will set up your wireless laptop with the correct printer port based on the Wireless Node Name it will also use the printers inbuilt MAC address. This is standard install and will work for all your Wireless PC's however if you have a Wired (ethernet) PC connected to your Router this process will not work a wireless port will not work with a wired computer.
Follow my 3 steps below to set up standard IP ports for Wired PC's also connected to your Router.
STEP 1: Find your MAC address for the wireless printer (all types of Network Cards will have one so this is no different) this will either be found under the LCD control panel or may even be printer on the bottom of the printer or Print server if it is seperate set this MAC address with an IP address as a reservation in your admin panel of your router 192.168.0.10 in this example.
You can normally enter your Router this using 192.168.0.1 typed in your browser (not the search engine) as all routers are different check here for your make and model http://www.routerpasswords.com if you can't find the MAC address try using ipconfig /all from them command prompt it will be the physical address aka the MAC address
STEP 2:
Install the Printer as a USB printer port by connecting the USB cable to the PC you want the wired printer driver installed on when finished go to the printer driver properties for the driver you have just added, click the port tab and click add standard IP port as shown below, then disconnect the USB lead this is only required to make sure the correct inf file is used on the driver install and connect your Ethernet cable from you computers NIC to a spare RJ45 socket on the Router.
STEP 3: To check that the Printer has the correct IP address then test using the tracert OR ping command for the IP address that you have reserved on your router, this is a necessary step otherwise when the lease expires it may take another IP address and your Printer driver will not work unless your printer has the reserved address, it will throw a printer error.
c:ping 192.168.0.10
(this example shows a Standard TCP/IP Port for a Brother DCP-340CW)
Also check in your routers admin panel to see if the Wireless Printer is set up with the correct IP and MAC address, if you still can't find it eliminate your known MAC addresses from all your network cards the one left will be your Printer Server NIC in your Wireless Printer.
If you have setup the incorrect IP and or MAC address you will get this window when you try to add the TCP/IP port
That's it try a test print and you will see it burst into life.... Happy Printing
on Dec 02, 2009 | Office Equipment & Supplies
When MAC filtering on Encore enhwi n2, the message " the legal characters are 0-9, A-F or a-f" always appear when I try to add more MAC address to be allowed to access the router. What could be...
The MAC address is a 12 digit number. This number is organized into 6 pairs of Hex numbers with no spaces between each pair of Hex numbers.
A Hex number is 0 to 9 and A to F giving a range 16 possible numbers.
An example of a MAC address number is - 0000AFB9C3F9
When you configure the wireless router with MAC address filtering, the router will only allow the computers with the MAC address listed in the router to connect to this wireless router.
Aug 22, 2011 | Encore ENHWI-N2 802.11n Wireless Router...
My new HP - Officejet 4500 G510n-z wireless printer will not connect to my verizon net work. Tells me that "The printer attempted to join the network but is not receiving any data. This may be...
I tried everything, even called HP and they tried to sell me a new printer. So about 6 hours into trying to fix it, I decided to just reset my router (unplugged it and let it reboot). It was fixed.
Feb 13, 2011 | Office Equipment & Supplies
Change nat setting on router
Step 1 : Check the IP Addressof the Xbox And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of the XboX in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Jul 16, 2010 | Belkin Wireless Surf Router (F7D2301)
Will my belkin g wireless router model f5d7234-4 work with xbox live?
Feb 17, 2010 | Belkin (F5D7231-4) Wireless Router
Brother printer and Neygear router wireless connection bad.
Had the same issue. Change the router wireless security settings from TKIP to AES algorithms. This did the trick for me.
Feb 21, 2009 | Brother MultiFunction Center MFC-440CN...
HELP... unlock my router
1. From the "Setup" page, click Advanced
2. When the "Filters" page opens, click on the Wireless tab
3. Make sure all wireless computers are setup to the router, and are currently able to access the internet. Once this is done, click on the Active MAC Table button.
4. Move the "Wireless Active MAC Table" window and click on Edit MAC Filter Settings on the main window.
5. When the "Wireless Group MAC Table" opens, go to the task bar and click on the Wireless Active MAC Table so that window appears.
6. With the two windows side by side enter the MAC Addresses from the "Wireless Active MAC Table" window into the Wireless Group MAC Table.
Note: When you enter the MAC Addresses do not include the dashes/semi-colon, and do not click "Filter"
7. Click Apply then Continue in the "Wireless Group MAC Table" window.
8. Close the "Wireless Group MAC Table" window and the "Wireless Active MAC Table" window
9. On the Main window Enable the Station MAC Filter setting.
Apr 12, 2008 | Linksys Wireless-G WRT54G Router
PLAYSTATION 3 WIRELESS NETWORK
get a firmware update for ur router
Mar 29, 2007 | Sony Playstation 3 (PS3) Console
Cisco Photosmart C4780 Wireless AllInOne Printer With Linksys By Cisco WirelessN Broadband Router Logo
195 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
