Question about GrandTec ULTIMATE XP PRO PC TO VIDEO
My father just purchased the ultimate xp pro pc to video converter to hook up his mac (vga) to the tv (s-video). However, all we got was color bars. No matter what cables we tried, we never got a picture. Can it be that the converter box is defect or did we forget something?
How can i hook my toshiba satellite pro to my tv
there are some options here.. however they are limited to what ports are available on your computer AND on your tv.. for instance..
1 s-video, this is a round like ps/2 port thatt he computer and your tv have to have for video.
2 you can use a vga port from the laptop onto the tv for video
3 you can get a switch box that will be VGA from the laptop to VGA on the switch box that will use AV cables to the tv like a dvd player, and you'll just hook your computers headphone jack intot he jack on the converter box for sound through the tv.
4 buy a brand new smart tv.
Aug 05, 2011 | Toshiba Satellite Pro L300 Notebook
When I connect my unibody macbook pro to my old tv using a vga to tv converter, my computer doesn't even recognize the disyplay.
When you connect your tv to your mac, make sure the cables are plugged into the TV first, and then plug your mac into the computer.
But a vga to tv converted doesn't make much sense. Your connection should be mini-display from your mac, to an adapter to either VGA, DVI, or HDMI depending on your TV connection type.
Dec 31, 2010 | Apple Computers & Internet
How to watch pc on a crt tv
You can watch pc to tv via wireless. Buy any pc to tv adapter.
Grandtec GWB-4000 Ultimate Wireless PC to TV System - 2.4 GHz, 4-Channels, S-Video, Composite, RGB, 1600x1200.
The Ultimate Wireless is the world's first truly
wireless PC-to-TV converter recommended for
professional presentations, computer gaming, and
internet browsing on TV.
Click here for more features;
Grandtec GWB-400
What's In The Box
* Ultimate Wireless converter/transmitter
* Ultimate Wireless receiver
* Composite + stereo audio cable
* Composite video cable
* S-video cable
* PC audio cable
* VGA pass-through cable
* 2 wallmount power supplies
* Battery Pack
* User's Manua
Jun 06, 2010 | Computers & Internet
How do I hook my tv up to my acer netbook? I dont have a tv port but do have a port for a second moniter and have the cord to hook it up but it will not work...
If the TV doesn't have a VGA input, you have two options. If the TV has component video inputs (3 RCA jacks color-coded red, green and blue, not just a single video jack coded yellow), you can use a simple adapter cable. Here is an example.
If your TV only has a single yellow video input jack (called composite video) you can't use the simple cable. But you can get a VGA to video converter. This device takes the VGA signals and converts them to the form the TV can use.
Hope this helps. Thanks for using Fixya!
Mar 30, 2010 | Acer Aspire One PC Notebook
Macbook pro VGA color display problem
Go into system preferences, click displays, and make sure your color status is set to millions not thousands.
Nov 17, 2009 | Apple MacBook Pro Laptop Computer with...
Color bars only on KWorld PC to TV - Composite and SVideo
found this reference it may be of help
This product appears to be defective. I connected it to a working video camera that produces an excellent picture on a standard monitor. I looped the video from the camera through the monitor to the converter which is connected to a new ACER LCD display. The LCD display workes perfectly when connected to my computer. Using the converter, the results are poor. You can see the desired picture in the background but in the foreground there are horizontal bars that scroll vertically through the picture. I'm returning it for an exchange - will try again.
Jul 26, 2009 | KWorld PC to TV (0872880887527) Video...
Problem hooking my macbook to the Powerlite 62c/82c the projector
For these types of projectors if you're planning to hook it up using you MacBook ;
You will need a converter ( from VGA to DVI )
Using the VGA cable that came with the unit when purchased ;
Connect the VGA cable on the back of the Projector and on the other of the cable you will connect the converter ( VGA TO DVI ) since for MAC systems it has DVI ports for monitors not VGA...
You can purchase the converter at any Mac store or any computer shop near you..
Mar 13, 2009 | Epson PowerLite 62c Multimedia Projector
Connecting my MAC to my LCD TV!
Do you have a DVI port on the LCD screen? Please tell me what connections you have on your macbook and your TV. There may be a converter.
Normally HDTVs can only be hooked up through S video or DVI Depending on your video card.
Oct 24, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
KWorld PC to TV Converter
I had the same problem. It turned out the issue was that I had the VGA Y-cable connectors between the PC and the KWorld box reversed. They look like they should be interchangeable, but they are not. A closer look at the cable connectors shows that one is marked "PC", one is marked "Monitor", and the 3rd is marked "SCAN CNVTR". Once I got them plugged into the right places, I got the screen image on the TV.
Jan 01, 2008 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
GrandTec ULTIMATE XP PRO PC TO VIDEO Logo
41 people viewed this question
Top GrandTec Televison & Video Experts
Electro Med Services...
Are you a GrandTec Televison and Video Expert? Answer questions, earn points and help others
