Question about Weiser Lock POWERBOLT ELEC DEADBOLT
I would like to change my front plastic with the numbers,where i can find one?
  • 963 Answers
Here is a link to their Support Contact page:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
Posted on Nov 08, 2011
Had cab mounts changed but not front. there is a strap from front mount to fender and plastic well that are snaped near front mounts. is there a part number for both of them as it is the same on both
they may be earth wires for the plastic parts or retainer s for the parts in case of an accident. The parts should be available as spares from the dealer spares or from a wreckers that handles your make of vehicle.
Dec 23, 2014 | 2001 Ford Explorer Sport Trac
Change code combination
Setting the Combination
1. Remove the key holder from the KeySafe by pressing the RESET button, followed by the OPEN button. Pull down on the key holder from the bottom of the KeySafe
2. Remove the bracket. Press the Release tab on the bracket and slide the KeySafe upward until it is free of the bracket.
3. Remove the plastic card attached to the bracket. You will see ten numbered buttons with arrows. These numbers correspond to the numbered buttons on the front of the KeySafe. An up arrow indicates that the button is not selected, a down arrow indicates that the button
is selected as part of the combination.
4. Using the screwdriver tip on the plastic card, apply light pressure
to rotate the arrows on the buttons you've selected for your combination a half-turn to the downward position until it snaps into place. Caution: The arrows must either point up or down, with downward arrows representing the numbers in your combination. If any arrow is pointing left, right, or is not fully seated when turned downward, the combination will not work. Improperly setting the combination is not covered under the warranty.
5. Return the plastic card to the bracket for future use
Mar 10, 2014 | GE AccessPoint Digital KeySafe 001847
On sub zero 690 like to change bulb in lighted electronic control panel
you will have to remove the light shield, remove the plastic trim that says the model number in front of the light shield, then the 2 screws holding the side cover on the left side of the fridge section. Then the cover will need to be pushed towards the rear of the fridge then tipped out at the front. It has springs holding it in the back.That should access the bulb you need to change
Nov 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
How do i change out the control board to Breezaire WKE 8000
A WKE 8000 IS PROBABLY THE EASIEST UNIT TO REPLACE THE BOARD ON, REMOVE THE TOP FRONT GRILL(COLD AIR DISCHARGE) AND BOARD WILL BE RIGHT THERE BEHIND THE GRILL, USE NEEDLE NOSE PLIERS TO REMOVE WIRES FROM BOARD, MAKE SURE YOU MARK THE WIRES BEFORE YOU DISCONNECT THEM(USE BLUE TAPE WITH NUMBERS) AND TAKE A PHOTO WITH YOUR PHONE OF THE WIRES WITH THE NUMBERS ON THEM,ONCE WIRES ARE REMOVED PULL THE OLD BOARD UP AWAY FROM THE 6 PLASTIC PEGS IT IS SITTING ON AND INSTALL THE NEW WKE CONTROL BOARD(IT SHOLUD BE BLUE IN COLOR) PRESS IT ON THE PLASTIC PEGS, AND RECONNECT THE WIRES USING THE NUMBERS AS GUIDE
Oct 13, 2012 | Breezaire WKE8000 Wine Cellar Cooling Unit
I would like to remove the center table from between the front seats in my 2009 honda cr-v.
Just did this with my 2010 cr-v. This diagram may help. http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CR-V&catcgry2=2009&catcgry3=5DR+EX+%284WD%29&catcgry4=KA5AT&catcgry5=CENTER+TABLE
You need to remove the plastic cover. Using a flathead screwdriver, pop the plastic anchor, numbered 28 on the diagram. Then, insert the flathead under the front and back edges of the cover, and pop it off. Located behind the plastic panel, are just 2 nuts (# 31 in diagram) holding the entire assembly to the passenger seat. I used a 12mm deep socket to unscrew them. The assembly will lift out. FYI the service dept. said such a cosmetic change will not void any warranty.
Mar 12, 2010 | 2009 Honda CR-V
How do change spark plugs on a 1998 xj8
Remove plastic cover over the engine ( three screws).
You then have access to the front three spark plugs (cylinders 1,3,5) remove the nut which holds down the independant coils and remove the spark plugs, fit new spark plugs and fit coils on the three front cylinders.
Now it gets a little tricky, you will only be able to access number 2 back cylinder so you have to remove the induction manifold (12 bolts I think) to access the back three cylinders (2,3,6,) properly.
Then proceed as with the front three spark plugs, refit manifold and plastic cover,
Sep 29, 2009 | 1998 Jaguar XJ8L
Change sparks plugs on 06 hyundai sonata v6
You didn't specify whether you have the (4) cylinder or the (6) cylinder engine..... I have a 2004 Hyundai Sonata 2.4L 4 cylinder and I just changed the spark plugs in it. I believe that the 2005 2.4L engine is the same. To locate and change the (4) spark plugs on a 2004 Hyundai 2.4L 4 cylinder engine: Remove the (4) 12mm bolts from the decorative plastic engine cover. Remove plastic cover from engine and place it off to the side out of your way. Standing in front of the car, the (4) spark plugs are located laterally (left to right) in the recessed area underneath where the plastic engine cover was removed. Note: This engine has (2) coils....They are located above spark plugs number (2) and (3) from left to right. Starting with the fist spark plug on the left: Remove the spark plug cable by pulling straight up on the insulated connector. Using a spark plug socket, remove the old spark plug and install a new one in it's place. To access the second spark plug from the left, remove the electrical connector and the spark plug cable wire from coil number (1) and then remove the (2) 12mm bolts that secure the coil to the engine. Spark plug number (2) is located directly under the coil. Lift the coil straight up removing the insulated connector from spark plug number (2). Using a spark plug socket, remove old spark and install a new one in it's place. Repeat same procedures for spark plugs number (3) and (4). Note: If you have the (6) cylinder engine, the front (3) sparks pluge are readilly accessible but in order to access the (3) rear spark plugs, you will have to remove the intake manifold
Jul 08, 2009 | 2006 Hyundai Sonata
My picture is dark and have changed the brightness
This model is notorious for needing a new lamp about every 2 years. The lamp is accessed through the front by removing the long plastic cover under the screen (it just pulls off). Under that, to the left of center, is a square cover with one grey plastic screw. Loosen the screw and pull the lamp assembly out. It should just slide right out. Turn it around and look at the lamp. If the lamp face or reflector looks "cloudy" or "misty". Replace the lamp with Philips part number TY-LA1000. Just Google the number and you will find them available for around $100
Mar 18, 2009 | Panasonic PT-43LC14 43" Rear Projection...
I can't find the spark plugs in my 2005 sonata
Note: If you have the (6) cylinder engine, the front (3) sparks pluge are readilly accessible but in order to access the (3) rear spark plugs, you will have to remove the intake manifold.
please rate!
Mar 18, 2009 | 2006 Hyundai Sonata
Hello....
I needed to replace my belt. I called the Danby Customer Service number 1-800-263-2629. I called early in the morning and got straight through. I received wonderful, prompt friendly service.
The belt cost $25.19 plus postage and handling.
Joe
Jan 16, 2008 | Danby DCD5505W Electric Dryer
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
27 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
