Question about Video Game Consoles & Games
Babrie Pet Patrol
My neice wants to play the game on the XP and i've tried useing Program Compatability Wizard on windows XP to make it work but the programe will load and when it asks her to type in her name the programe freezes. It's really upsetting her, i hope you can help me out.xx
  • 8,617 Answers
Sorry my area of expertise is strictly TVs and large appliances. I know hardly nothing about computers except the power supply repairs.
Posted on Jun 16, 2008
I have a copy of starcon 3 but it won't install on my computer my os is windows 7 but it says that the game isn't compatable with my version of windows
Hi, welcome to Fixya. I hope my info helps you.
What it said is true. Starcon 3 is an OLD game, with compatability with win 95, and DOS. I think there may be a way for you to get to work though, right click on the installer program, and put the program in compatability mode, and tell it win 95 for the o.s. If that doesn't work, then download a program called DOSBOX, and run the installer with it, Dosbox is designed for just this sort of thing.
I hope that you do get it to work, as Starcon 3 was a really good game when it came out.
Jan 20, 2011 | Computers & Internet
18 wheels of steel american long haul will not run on my win7 computer, so I want a solution. Plus I am 10 years old.
Hello jad_1234, Try to run your the game using Windows XP compatability mode in Win7. To change the mode to XP do the following:
  • Right click the game icon
  • Select Properties
  • Select the compatibility tab
  • Check the "Run this program in compatibility mode" box
  • From the drop down menu select Windows XP
  • Click Apply then Ok
  • Try running the program again.
The compatibility mode has helped me play several games in the past. Post a reply with any issues or please rate this solution if you found it helpful. Thanks, Edward
Aug 23, 2010 | ValuSoft 18 Wheels of Steel: American Long...
I wanted 18 wheels of steel haulin' on my comp and was wondering if it worked on windows 7
Hello suttonplaya3, The game may work natively on Windows 7. If not you could try to run it using Windows XP compatability mode in Win7. To change the mode to XP do the following:
  • Right click the games icon
  • Select Properties
The compatibility mode has helped me play some of my classic games in the past. Post a reply with any issues or please rate this solution if you found it helpful. Thanks, Edward
Aug 23, 2010 | ValuSoft 18 Wheels of Steel: Haulin' for...
Wont play in windows xp
There must be a problem with your app
Jul 15, 2017 | 3DO Video Game Consoles & Games
When i try to install big game hunter 3 it tells me i am using windows nt in fact i am using windows 7
Windows 7 is nt based you will have to install that game under the program compatability wizard and even the sometimes they don't work.
You might also check with the software maker to see if they have a fix for that game that will make it work with windows 7
Nov 24, 2009 | Activision Cabela's Big Game Hunter 3 for...
I am unable to install hunting unlimited 4.Is it vista compatable?
It seems that Hunting unlimited 4 is only for systems up to Windows XP....
Try installing the game in compatability mode...might work...
explore the game cd
look for the setup.exe or install.exe
right click and view properties
look for the compatability tab
under compatability click the box that says run this program in compatability mode ....make sure you choose windows xp then ok the window
now double click on the exe file that you´ve just changed and see if that works
Nov 26, 2008 | Computers & Internet
Komodo K600 (WIN98) on XP
Is it possible to use the win98 program and install the driver using the XP compatability wizard?
Start, Programs, Acessories, Program compatability wizard,, then Next, "locate program manually"
please post back resultas so we all learn
Jul 06, 2008 | Office Equipment & Supplies
Barbie Pet Patrol
What are the minimum requirements for the game, and is it actually compatible with XP?
Also try to uninstall and reinstall the software and see if that helps..
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Jun 16, 2008 | Video Game Consoles & Games
Barbie Pet Patrol
mine is the same i can still play it when it ask to type name put it in spaces like space space space u can play it then
Macromedia projector
I have had same problem last time. What I did was run Program Compatibility Wizard and next set compatibility to win98 (dont remember if that is the one I choose, but you can test it). No idea what does it have to do with it, but it solved problem in my case. Hope it will help you.
Oct 22, 2007 | Microsoft Windows XP Home Edition
Video Game Consoles & Games Logo
89 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
