I need to find a fan blade bracket and a finial for this fan. Where can I get them?
  • 81 Answers
What kind of fan what kind of unit model number?
Posted on Nov 09, 2010
How can I get a bracket that holds the leaf blade????. #ST306-002-22
  1. Check and see if bracket is broken
  2. If not then see if screw is tight enough if not tighten more
Jul 05, 2014 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Bent ceiling fan blade brackets
This is what you need to do:
So how do you contact the Hampton Bay Replacement Parts Department?
Simply call 1-877-527-0313 then select option #2. This department will then help you find the replacement part you need for your hamton Bay product.
Dec 23, 2012 | Dryers
Fan rubs against light after banging into blades while turning over mattress. Is there a way to straighten out center hub?
remove fan blade and bracket from unit. remove blade from bracket. put the down side of bracket on a very solid surface and apply downward preasure. Now go easy, its a soft metal, and might be cast, but this should work for you.
Mar 06, 2011 | Hunter Heating & Cooling
My celing fan is wobbling, how do i fix it?
Ceiling fans need to have balanced blades if they are not to wobble. At it's simplest this means that all blades should weigh the same, and they should all be exactly the same shape. But it's not quite as simple as that, as the brackets that each blade is secured to also have to be balanced.
In practice, good quality fans will have the blades carefully balanced by the factory, and on better quality models the blades will be matched to individual mounting brackets in which case there will be markings to identify which bracket goes with which blade (and also to identify where each bracket mounts to the motor).
Cheap fans (almost anything under £130) will not be carefully balanced and so whether they wobble or not is a matter of pot-luck.
To try and cure your fault, first remove and accurately weigh each blade complete with the brackets attached. You can buy strips of self-adhesive balancing lead to add a gram at a time to the upper side of the tip of any blade which is under weight. Note that if any blades are damaged, you must repair the damage before weighing. If any blades are twisted along their length (normally they're simple flat paddles set at identical pitch angles by the way the brackets are shaped) then they must be counter-twisted to match the other blades. Also, check for manufacturer markings to see whether there are any suggestions as to which blade goes with which bracket and whether the brackets are marked to match a particular mounting point on the motor (usually simply by matching coloured paint blobs).
Once you have checked all that you can, see if the wobble remains. If it does you should try swapping the brackets around on the motor: by doing so you'll normally remove the wobble altogether or will considerably reduce it. You might not achieve perfect balance, but you may get to a point where the resonances which cause the wobble offset each other.
A well-balanced fan will not wobble appreciably at any speed, a less well-balanced example might still wobble at some speeds and not others.
I hope that I've helped and that you will take a moment to rate my answer. If there's any part of my reply which is unclear to you then add a comment and I shall try to assist you further when I'm next online.
Jul 11, 2010 | Dryers
Although this is posted in completely the wrong category, I shall try to assist you.
Jul 11, 2010 | Meade Capture View Binoculars
There is a humming noise coming from fan no matter what speed it is on. I have run the fan for hours and still humming
The key to a quiet fan is to isolate the motor vibration from all other parts. This occurs, in the majority of fans, in three places: between the motor and the blade brackets, between the blade brackets and the blades, and between the downrod/motor flange and the mounting bracket. Some fans also have vibration-isolating material between the mounting bracket and the ceiling. If your fan makes a noticable humming noise, inspect it for the above mentioned types of vibration-isolating material. With the exception of the rubber flywheel, if your fan is lacking any of the above, they are easy to add and should solve the majority of humming problems. You can always add additional material as rubber washers and spacers are readily available.
Jun 09, 2010 | Hampton Bay 52 In.Carriage House II in...
Fan blades will not line up with holes on motor, can not attach blades
I had fun like this once! Check and see if the holes line up after turning the blade bracket upside down, next move the blade bracket to the next set of holes.
Feb 11, 2010 | Hampton Bay Sidewinder 04890 Ceiling Fan
I NEED A CONDENSER FAN MOTOR WITH BLADE AND
cna't find your model with this # reck model # ser # there is no problem getting the parts for whrlpool . the motor and fan are normal service parts but the mounting bracket would have to be ordered . as the do not ware out . ****..
Dec 23, 2009 | Refrigerators
Broken bracket
The brackets are made from cheap pot metal and susceptible to breakage.
Dec 01, 2017 | Hampton Bay 04345 Cruiser Ceiling Fan
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
