Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Hi i have a sealey space warmer it will not power up and i have checked the 2 fuse's and they are ok can you help please thanks
Hold a sheet of cardboard an inch in front of where the heat comes out when you switch it on it should fire up then.
Posted on Dec 04, 2010
Dear discophil,
If you contact the technical hotline for Jack Sealey Ltd on 01284 757500 they should be able to solve your problem for you.
Regards,
Jack Sealey Ltd
Posted on Nov 10, 2010
I have a Technics SA - DX750 Amp Everytime I turn it on I get an error message F70 and then it requests that I turn the power off. This is all it does now, so sound. How do I solve this issue I have...
Hi!
The F70 error certainly indicates a blown fuse inside.
The real problem is why the fuse is blown: there are only two possible reasons
1. there is a short circuit on the output (lines or speakers)
2. you have a blown output transistor (and that means some work and skills to replace).
To be sure, please change the fuse with a same rated fuse (buy more than one because it can blow again). Disconnect the speakers and turn the amp on. If the fuse blows again, it is sure something wrong with the output transistors. If the fuse remains ok, then please check all the wiring to the speakers.
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Technics SA-DX950 Receiver
Low beams on my 2006 r1200rt do not come on and their is no error lights on
The power for the low beams starts at the dimmer switch. The power then travels on a black/green wire to fuse number 2.From fuse #2 the juice goes again on a black/green wire to the low beams. So, check if the power is getting to fuse #2 and that the fuse holder is OK. Check the black/green wires for breaks. Finally if you have no power to fuse 2 then check the dimmer switch itself.
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2011 | 2007 BMW R 1200 RT
IS SEALEY HOOKS GOOD AND WHAT MAKES THEM GOOD
Edgar Sealey & Sons from Brockhill Works in Redditch, England have long been known for the outstanding fishing rods and tackle that they have produced since 1895. They are known for using quality steel in the production of their hooks.
Jan 13, 2011 | Sealey Edgar Fish Hooks S4310 Lsbe Sz 10...
Sony str-da50es. Does not power when power button is pushed.
This problem is very common in this model the solution is to replace the fuse with improved one 10A 125V of type CES710A having part No.1-576-695-11. Remember that this fuse would be larger in size of earlier one so that you have to drill it first in the holder and adjust the fuse to a proper space of 1.4 drill bit.
Do the changes and your product work fine.
Thanks.
Nov 24, 2009 | Sony STR-DA50ES Receiver
Bucket seats with driver 1 and 2 memory and also seat warmer oh and the seat warmer does not work ever since.
Hi I'm not to clued up on 2004 silverado 1500 LT crew cab, obviously you'll check the fuse box & even replace the fuse wouldn't hurt giving it a try. Also try checking the electric motor for the seat. No cables lose or broken? Nothing jamming the seat? Is there any sound at all coming from the area where all the electrics are under the seat? Can you hear a motor straining?Just a few thoughts. Good luck
Jun 01, 2009 | 2004 Chevrolet Silverado 2500HD
How to fix Power Adapter
Does your adaptor geting warmer when plugged to power outlet for some time (minutes)?
If not, than there are two possible solutions:
First (the easiest) thing is to check if both wires are not cut or short (one that you connect to power outlet, and the other one you connect to your laptop). You'll need some multimer to do this.
Most possible is that you'll need to open the power adaptor to do these checks.
Second thing is to locate and check the Fuse. Most of the adaptors have a Fuse inside.
If the fuse is OK, the wires are also OK, and the adaptor is getting warmer (or not), than you should buy a new power adaptor.
My experiance sais, not to belive much to repaired laptop adaptors (you don;t say what laptop you have).
Also, do not ask for substitute (cheap) adaptor!
Find an original one!
Most important is the following:
Please note that you should't try to do these checks, if you don't feel you are enough qualified. You should ask some friend of your's or some service. It should't cost you much !
Also, if you try to do this by yourself, be EXTREMELY carefull when adaptor is open. DO NOT PLUG it to power outled !!!
You might be killed !!!
Regards.
Mar 26, 2009 | Toshiba Satellite 2210CDT Notebook
NO BRAKE LIGHTS
Fuse box next to clutch pedal (brake on automatic). There is a fuse in there for the brakes. I have the same problem but my fuse is OK.
Jan 31, 2009 | 1993 Toyota 4Runner
Short Cicuit on my Buffalo external hard disk...Help!!!!!!!!!
First of all Hi!
This Fixya will help you solve this problem. First of all your hard drive should be still ok but you will require to open the hard drive enclosure and replace the power supply (due to the wrong voltage tapping). Please feel free to follow these fixya's not only to recover your photos but get back a working hard drive!
Solution 1: Check fuses
1. Disconnect faulty enclosure from any mains supply
2. If power supply is INTERNAL you will have to OPEN the enclosure but BEFORE you do that WITH THE hard drive UNPLUGGED TURN ON the power switch to discharge the hard drive's internal power supply
2. Open the enclosure and check for any fuses on the inside. There should be one located close to the power swtich from inside. Change it with one of a similar rating because most probably this is the culprit.
3. Try and power up the drive THIS TIME WITH the CORRECT voltage tapping
4. If the power supply is EXTERNAL you do not need to open the enclosure, just change the power supply with a similar one and you should be up and running again.
Solution 2: But the fuse is ok but there is bbq smell when i opened the enclosure!
1. Ok this means that you will need to get hold of the internal hard drive.
2. If you have another computer check if the hard drive is still ok! Here is how:
- Turn off the computer
- Open case , #
- Hook it up to the Internal IDE cable and the internal power connector
- Turn on the computer.
- You should have this detected in my computer as a new hard drive and you
should be able to see all the data in it
2. But probably you still want this as external dont you? Ok buy another enclosure from a computer shop (this time you will just need an empty one)
3. Plug the hard drive in new enclosure. If you're not experienced enough just give it to them to hoook it up for you and FINALLY you should have the reincarnated buffalo hard drive functional again.
Hope this fixya was of help :)
Best Regards
ALx
- Please take some time to rate this solution, really appreiciated thanks :) -
Jan 07, 2009 | Computers & Internet
Please help
Good Day!
if your issue is how to create space to accomodate your printer installation space requrements, then try to free space.
Here are the steps
1. on your desktop point to my computer. double click then you can see something like C:
right click on it. you should see Disk clean up
2. click on disk clean up.
3. the Default check should be enough. If not, try to decide what is not needed then check it.
4. Click on ok then click on perform on actions.
if this does not give you ample space, you should manually delete files in your c:
Hope this helps
Dec 30, 2008 | Lexmark Office Equipment & Supplies
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
258 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
