Question about Compaq Presario CQ60-212US Notebook
My screen is inverted, how do i fix it? - Compaq Presario CQ60-212US Notebook
How to fix my screen?
check and make sure your video card is seated properly if it is my best guess without doing any testing is that your video graphic card is broken
Jan 08, 2015 | Samsung 700Z COREI7-2675 15.6 8GB 750GB...
PACKARD BELL EASYNOTE SJ51. NO INVERTER VOLTAGE. ALL LEDS OK, SOUND OK, BOOTS OK, SCREEN BLACK OR POSSIBLY DIM.
Simple test: get a flashlight, go with the laptop in a dark room and point the flash light at the screen. If you see the image then indeed the inverter isn't working. of you don't see it then the data cable between the motherboard and the screen has been damaged: replace it.
If the inverter is at fault you will need to open the screen cover and check if the inverter board receives power from the motherboard: if it does you need a new inverter board
http://sparepartworld.com/display-inverter-board-for-packard-bell-easynote-sj51/product_info.php/products_id/1724545
If it doesn't then a complete testing of the motherboard will have to take place to find out why and if it can be fixed.
Aug 12, 2011 | Computers & Internet
My touch screen works when you touch it: but the outer screen is black off. when i put a UV light up to the screen i can see the back buttons and i can touch them. how can i fix my screen what part do i...
Looks like ur inverter, thats lights up ur LCD screen don't work!
Either ur inverter is disconnected or capacitors in the inverter is broken.
better bring that unit to ur nearest service center to fix on that.
Dec 01, 2010 | Pioneer AVIC-N1 Car DVD Player
Screen is totally blank at startup. HDD light blinks for a little bit, but screen stays blank.
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Oct 11, 2010 | Dell Latitude D830 Laptop Computer PC...
Screen is dark
Oct 10, 2010 | Dell Computers & Internet
Your Question My Toshiba Satellite m115 will boot up but the monitor wont light up, you can see the images in the back round but the screen is dark. if i connect to external monitor the external monitor...
Diagnosis:
Oct 07, 2010 | Toshiba Satellite M115-S3094 Notebook
Compaq nc6000 screen brightness - very dark
Oct 07, 2010 | HP Compaq nc6000 Notebook
The screen is not working it will however run an external monitor jus fine
Diagnosis:
Oct 06, 2010 | Dell Inspiron 1501 Notebook
Replaced cracked display screen with new one and screen is black. System works with external monitor. Is there any drivers that need installed?
Sep 26, 2010 | HP Compaq Presario CQ50-210US Notebook
No light on screen of acer extensa 4620 4605 PC notebook
This is a problem I have experienced with my HP laptop as well. I found some info on this and was told that it was the inverter. I managed to fix this by finding the inverter and, unplugging both ends of it and plugging it back in. This fixed the problem and a week later its still working!
The inverter is usually located at the bottom of the screen. To access it you need to unscrew the screws around the screen. This will involve removing the plastic covers and simply unscrewing them.
Once you have removed the plastic cover from around the screen, you should see the inverter at the bottom. Re-seat the connectors, and see if this fixes it. If not, replace with inverter. The site below is an example of where you can buy one.
http://www.laptopbacklights.co.uk/
This may help you with the process
http://www.laptoprepair.co.uk/how-to-repair-backlight-inverter.htm
Hope this helps, let me know
Jun 02, 2008 | Acer Extensa 500T Notebook
Compaq Presario CQ60-212US Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
