Question about Samsung Televison & Video
Samsung LA46M81BD LCD tv shows my cable television as if there is no motion blur. that the pictures seem to glide and it looks un-natural. how do i fix it
  • hamedf Jun 16, 2008
    DVDs work fine. I thought it might be a refresh rate problem but cant find the settings for refresh rates on the tv.
  • 58 Answers
A lot of this type of TVs don't have a good pix on regular cable.
Try it with a dvd.
then let me know.
Thanks Guy9
Posted on Jun 16, 2008
Samsung led TV UN50ES6500FXZA picture problems.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 09, 2016 | Samsung Televison & Video
Samsung 55" blurry picture and words are blurry...netflix comes in perfect...whats wrong
Is it a 3D TV. Try changing the refresh rate in the Picture Menu 60HZ is normally the standard but try others. Or if you're TV has Auto Motion Plus options you try turn it on it can be found in your television's menu under Picture Options. The Auto Motion Plus menu contains several options, including On, Off, Clear, Smooth and Standard. If changing your Auto Motion Plus options doesn't correct blur, call Samsung.
Jan 24, 2015 | Samsung Televison & Video
Blurred picture on Samsung Dv3 LCD tv
You may need to upgrade to better cables. Here is a good set that I recommend.
480p HD Component Cable for Nintendo Wii
- Matt
Jan 25, 2014 | Samsung Televison & Video
Blurred picture, double picture on the tv screen
MB, your set has one or more defective LCD panel tabs. The only true fix is to replace the screen which will be big $$$. There are youtube videos that will show you how to patch the problem. Just search LCD panel tabs and several videos should come up.
Mar 31, 2013 | Samsung Televison & Video
I recently purchased a Samsung 46" LCD TV from Best Buy, model LN46C630K1F. I love the tv except for one issue -- intermittent jerky picture. Samsung, Best Buy and Cox Cable (Omaha, NE) have not yet...
Where ever your signal is going into, it is not tune to the right frequency and that is why your picture is not right, and the TV needs to be replace, The TV has to be tune exactly right to receive a clear signal. There is one more thing I wold try before replacing the TV, that is replace the cables or cable, or what you are using from the cable to the TV replace it and see if that is the problem, if it is the same then it is the TV that has a problem.
Jan 05, 2011 | Samsung Televison & Video
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
May 12, 2010 | Samsung LN-T5271F 52 in. LCD Television
Fuzzy background on tv picture
This is probably a combination of 2 things. In both causes 1 and 2 below, I would suggest checking the TV with a BluRay Player with BluRay disc connected using an HDMI Cable. If you complain about this, then the TV is probably not that great. Expect a $200 jump to a better model at the least (but this depends on what you have now). Honestly, this is fairly normal and wont change much with the next TV.
CAUSE 1: Motion BLUR
Motion blur occurs when fast moving objects are displayed on LCD TVs. Basically, it takes time for the LED lights that make up the picture to turn ON and OFF, when and object shown on the TV is moving faster than the LCD TV can turn these lights ON and OFF, you see the trail left behind as the lights dim to OFF. This look like blur because you see the current image and the trail of the old images. 120HZ and 240HZ LCD TV are supposed to improve this but honestly, they are at times 300+ dollars more and not really worth it. Very little difference except in some few cases.
CAUSE 2: Digital TV
Digital signals are hit or miss. Good or BAD. If you are watching Cable, Satelite or Antenna; it is likely you are seeing some BLOCK NOISE. This block noise is caused by missing information or Noise in the video signal. This will cause the picture to Pixilate (you see blocks and things start looking blurry too). This happens with poor signals. This also happens with the HD channels when they have more information than bandwidth (more data than that have space to send it...image shoving an elephant into a VolksWagon Beetle)
May 27, 2009 | Televison & Video
DVD picture looks odd
Most high end and larger Samsung TV's are equipped with what is called auto motion detection, more or less the TV tries to anticipate where the movement is going to be. The reason your getting the trippy pictures is because the tv's refresh rate is probably twice as fast than the source feeding the video.
To turn this off just go to your menu and scroll down and choose picture option and find auto motion and turn it off there it is problem solved! It won't hurt anything and can be turned back on as easily
Mar 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Motion problems
You need to contact cable company, first for this.
Because of tyhe picture quality is related cable box, cables ,connectors & etc.
Jan 22, 2009 | Samsung LN46A650 46 in. LCD HDTV
Televison & Video Logo
77 people viewed this question
Henry  Thomas
Henry Thomas
