Question about Denon AVR-4800 Receiver
In the past, I occasionally got no sound from my 4800. Then it would pop on after the unit had been switched on for a few minutes. This past weekend, the sound just wouldn't come on at all. I even tried to reboot the unit as it says to do in the manual with no success. I use as a 5.1 home theater unit and only run the audio from the cable through it. The cable and DVD video feeds go directly to the monitor. It's been set up this way for years with no failure, until now.
    Novelist:
    Champion:
  • 225 Answers
Protection circuit (audio delay between the time you turn the unit on and actually hearing sound) is engaging because....check your speaker wiring for frays or poor connection at rear of Denon and at the individual speaker connections. If you don't find problems there you may have a noisy transistor or capacitor inside the Denon that is creating static and/or DC leakage which will keep the protection circuit from connecting the speakers to the amplifier. If it's the latter start looking for a repair shop or replacement.
Posted on Nov 08, 2010
Frigidaire FMV156DC 950 Microwave sometimes stops heating
This sounds like a common primary interlock switch. Need to check and or replace both door switches. DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Frigidaire FMV156DC Microwave Oven
What causes the TV to go on and off when first turned on, until it warms up for 5 to 10 minutes
Try turning the volume all the way down then power the TV an see how
long it takes to bring a screen up if you still hear a popping sound then you have a bad part with a bad connection most likey a lamp and wiring.
Call to have it serviced a must if so.
Jun 08, 2012 | Mitsubishi LT-3280 32 in. LCD HDTV
I am tying to print a document...the printer list pops open shows it then disappears and nothing is printed (mfc 4800; Vista)
First of all, restart your system and your printer. Leave the printer off for few minutes (let the printer get cooled) and then reconnect it's usb cable and try giving a print command. If the problem persists, uninstall it's drivers and reinstall it. It'll be helpful if you update it's driver.
It's also important to run a registry cleaner and system cleaner.
If you have further problem, do let me know with the description of the outcome from the above tips.
Good luck.
Thanks for using FixYa.
Jul 03, 2010 | Brother MFC 4800 All-In-One Laser Printer
Infocus Screenplay 5000 - Pop - Gone!
the power supply is bad. there is a fuse on it, but it wouldn't be a occasional problem. the caps on the ps board may be drying up and causing it notto function. replace the ps.
Jun 30, 2009 | InFocus ScreenPlay 5000 Multimedia...
No home theater sound
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 07, 2009 | Denon AVR-4800 Receiver
Panasonic DVD player problems - switches to
get the dvd player len cleaned using a len cleaner.
are you operating the unit with the remote when find the mentioned issue try manually.
Jul 31, 2008 | Audio Players & Recorders
Denon AVR-4800 Receiver Logo
319 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
