No picture being displayed when using hdmi input. sound is working but no picture
  • 144 Answers
If tv otherwise ok then suspect hdmi cable fault, but are you sure you are on the correct hdmi input. Your tv may have more than one hdmi socket.
pete
Posted on Nov 08, 2010
My Denon 301 has no picture but sound thru hdmi connection. Only works on scart lead
Try lowering your source input like DVD or playstation video display settings to a lower setting. Try a higher qualty HDMI cable.
Last the HDMI input port might be faulty
Oct 23, 2015 | Televison & Video
Why did I lose the video signal from the receiver to the TV?
I assume you have tried both hdmi cables from box to tv. If both works good.Cconnect to amp. Connect cable box also on other hdmi inputs like bd, dvd, etc to make sure the spesific port is not faulty. If still no picture try to lower hdmi video display on cable box. You amp may not be able to display the higher resolution.
May 06, 2015 | Onkyo TX-NR535 Receiver 5.2 Channels, 65...
Klv 40s400a
TVs need an input to display a picture. Some TVs have several inputs and you must select the one you are using. Example: my TV has four HDMI inputs on the back. If I connect my PC to one of the HDMI ports I must select that input in setup to display My HDMI ports are labeled HDMI 1, HDMI 2, HDMI 3, and HDMI 4.
If I connect my PC to HDMI 3, I must select in setting HDMI 3 as the input.
Oct 16, 2013 | Televison & Video
Hi our PS3 has no sound or picture. It does have the green power light on.
What is probably happening, is your PS3 is set for the wrong type of output. If you are using an HDMI cord, try switching to the AV cables that came with your PS3, and set your TV at the appropriate input to correspond with the AV hookups, and see if the picture works then.
If you are using the AV cables, it may have been set to HDMI accidentally. You need to use an HDMI cord, and hook the PS3 up to an HDMI compatible TV or monitor, and select the HDMI input. Once you get the picture working, go to Settings>Display Settings and set the display you wish to use.
May 16, 2011 | Sony Playstation 3 (PS3) Console
No Signal (picture), but sound from HD inputs. Other ports working fine.
make sure you have the correct video cable. if it uses HDMI, use highspeed HDMI cables. Same goes if you use display port and make sure the correct input source is selected on the tv.
Dec 04, 2010 | Polaroid FLM-3201 Television
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
