Question about Car Audio & Video
I have a philips rc604 that I don't have a security code for. Is there a default code I can enter? or do I have to request the code from philips?
  • 6,993 Answers
you need to request the code from Philips.
Good luck.
Posted on Nov 08, 2010
353780041844960 imei security code
If you have not changed your default security code, it is 12345, but if you have, and have forgotten it, this security master code, which is peculiar to your IMEI number would help you to reset the security code to its default of 12345. Enter it when the security code is being requested for.
353780041844960
Hope this was helpful?
Apr 18, 2011 | Nokia Classic 2700 Cell Phone
Need the code for radio. Model rc604. numbers on radio are rc604/97 Phillips cg009962 ph604cx0010091 90793160497900 00999020010091
Please check your Serial Number again to make sure it is correct.
If it is correct  , then unfortunately   your  code will not be available for free (or cheap)  from anywhere on the Internet as this Serial Number is not in the available PHILIPS database.
It requires access to the original manufacturer`s database which is only available from your Main Dealer .(and a few of the larger Professional Radio Decode Specialists)
Otherwise try  a Decoding Service or your local Car Radio / Audio Shop who will electronically "read "/ recode the memory chip (EEPROM) using a laptop and specialist software.
Dec 10, 2009 | Philips Car Audio & Video
I can't remember my unlock code on my sms
sometimes it defaults to the manufacturer security code "000000" or "1234"
also try the last 4 digits of your phone number.
Mar 18, 2009 | AT&T Motorola RAZR V3 Cell Phone - Black
Security code
The default 6-digit security code for this phone is 000000. Hope this helps.
Feb 02, 2009 | Motorola Mobility RAZR V3
Cell blocked
Securing your Shine
Secure your LG Shine and your account from thieves by locking your phone and your SIM card Losing a phone through accident or to a light-fingered thief is annoying, frustrating and potentially very costly, especially if the 'finder' uses your SIM card to make expensive calls. You can, however, lock both your phone and your SIM card with four-figure PIN numbers to prevent unauthorised use.
The first line of defence is to set a SIM card PIN. This means that whenever you turn on your handset you have to enter a PIN code before the SIM can be used. The default PIN code for your SIM is dependent upon your network; usually it will be found in a small booklet that came with the SIM card.
The PIN can be enabled, disabled or changed from the Security menu – but you only get three chances to enter it correctly. After those three, the SIM will get locked and can only be unlocked by entering the PUK (PIN Unlocking Key) which your network can give you. Enter the PUK incorrectly 10 times, and the SIM will be irrecoverably locked.
To activate a PIN code request, open the main menu by clicking on the scroll wheel. Click 9 to access the Settings menu and click 6 to enter the Security menu. The first item is PIN code request - click 1 or OK to open it. By default this will be set to off. To activate a PIN request, click 1; you'll now be prompted to enter the four-digit PIN. When you've done this, click OK, and if the pin was correct, you'll see the confirmation message 'Complete'.
To deactivate the PIN code request, you would simply select Off from the menu by pressing 2; you'll need to enter the PIN code whenever you change this setting.
PIN code request prevents another user from using your lost or stolen SIM card in their own phone. To lock your phone, and thus render it useless to a thief, you can activate Phone lock.
Two levels of handset locking are available. The first - called 'When power on' in the Phone lock menu - is to require an unlock code to be entered whenever the handset is switched on. This can be confusing and irritating when used together with the SIM PIN, so a second option is to only request the handset unlock code when the SIM card has been changed - called 'When SIM changed'. This means that if your phone is stolen, the thief can't use their own SIM card in it as the phone will need a PIN code to unlock.
To activate either option, go to the Security menu (clicking 9 for Settings and 6 for Security from the main menu) and click 2 to enter the Phone lock menu. Click 2 to activate When power on or 3 to activate When SIM changed. In either case you'll be prompted to enter the security code. By default this is 0000. Enter the code and click OK to confirm.
To change either code, go to the Security menu again (clicking 9 for Settings and 6 for Security from the main menu) and click 5 to enter the Change codes menu. To change the handset's security code, click 1 to select Security code, or to change the SIM PIN, click 2 to select PIN1 code. In either case you'll be prompted to enter the old code before entering the new code twice, clicking OK to confirm each time.
Jan 10, 2009 | LG Shine KE970 Cellular Phone
Forgot my security code
The default security code for Nokia is 12345
IMEI: 356438012346609
Master code: 0631367461
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer via an unlock box to restore the Security code.
Sep 08, 2008 | Nokia N73 Cellular Phone
I have an N70, Do you happen to know the Master Reset Code
IMEI: 357968007960658
Master code: 7176552371
Type in the security codes (any code) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
If it does not request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Jul 15, 2008 | Nokia N70 Cellular Phone
PLEASE HEEEEELLLPP
The default Security code for Nokia is 12345
IMEI: 358672010590572
Master code: 2501005436
Close all applications on your phone. (if you can)
Type in the security codes (anything) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Are you sure it’s the Master code you need. Which is the one that you want?
Jun 23, 2008 | Nokia 3110 Cellular Phone
LG CU400
Locking and Unlocking the Device: FOR LG CU 400
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Security.
  4. Scroll to and select Lock Handset.
  5. Select desired option:
    • When Power On
    • When Smartchip Changed
    • Immediately
    • Off
  6. Enter the Security Code, press OK.
    NOTE: The default security code is 0000.
Setting the PIN Code:
  3. Scroll to and select PIN Code Request.
  4. Scroll to and select On.
  5. Enter the PIN code, press OK.
    NOTE: Default PIN code is 1111.
Changing the Security Code:
  3. Scroll to and select Change Codes.
  4. Scroll to and select Security Code.
  5. Enter the current Security Code, press OK.
  6. Enter in the New security code, press OK.
  7. Confirm Security Code, press OK.
IMPORTANT: If the incorrect lock code is entered more than 3 times the phone will display "ENTER PUK". If this message is displayed contact Customer Care.
Nov 28, 2007 | LG CU400 Cellular Phone
Car Audio & Video Logo
137 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
