Question about Matrix Okidata Microline 320 Printer
My okidata microline 320 turbo will not feed paper
SOURCE: Okidata ml 320 form feeding (wasting paper) after each print out
that was really easy man i finally found a fix :) if you need guidance feel free to email me at zulfequar  at  gmail dot com
Posted on Mar 04, 2009
SOURCE: okidata microline 320- having menu problems
Menu Light flashing is a printhead thermister overheat problem.
Power off the printer and try reseating the print head; if this fails you'll need to replace the print head!
Posted on Mar 24, 2009
joeshea123
  • 65 Answers
SOURCE: THE 320 OKIDATA TURBO IS
Give this a try.
let me know if this helps.
Joe
Posted on Mar 26, 2009
SOURCE: could you please tell me why my printer is
could you please tell me why my copier isn't printing the copies dark enough-could it be the ink cartilage or another problem. I don't want to order the cartilage if it is another problem. It is an older copier-PC941
Posted on Oct 16, 2009
Joed911
  • 4338 Answers
SOURCE: We had a computer crash
The most current driver for this product is already included in the Windows XP Operating System. Currently there are no updated drivers available.
If the driver did not work, try to use the IBM Proprinter or Epson LQ driver.
Posted on Mar 16, 2011
We had a computer crash that required replacing the computer we had with one running Windows XP w/SerPk 3. We are still using the okidata microline 320 turbo that we used with the old computer. We are a...
Mar 16, 2011 | Matrix Okidata Microline 320 Printer
I have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Nov 09, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Installed a new okidata microline 320 turbo dot matrix printer and now the tear/set button does not set the paper where i need it to as my old printer did. How can i change the tear line setting?
Make sur that the paper length is correct in the settings. With paper in the printer hold down the "SHIFT" button then press the "SEL/MENU" button. The "SEL" indicatr will light up. Now press the "PARK" button, a settings page will print. Select your paper length you require by going through the settings, if you press the "LF" button it wil take you through the different groups of settings, the "FF/LOAD" button wil take you through the different items in the groups and the "TEAR" button will change the settings on the different items. To save the new settings hold down the "SHIFT" button and press the "SEL/MENU" button.
Aug 20, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 320 turbo problem
Solved this problem by going into the bios and changing the port from ECP to EPP, and then uninstalling the ECP port in device manager and replacing it with a standard parallel port configuration, no problems since doing that.
May 12, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Microline 391 okidata continous feed leaves a page of space
We have downloaded the manual and will see if we can figure it out.
Thanks
Apr 05, 2009 | OKI MICROLINE 390 Turbo Matrix Printer
Okidata 320 turbo microline prints jibberish
sounds like a job was sent to the printer with the wrong driver. There is no way to purge it just load some paper and let it run until it stops. They make sure your emulation matches the driver youa are using. Example Epson 9pin compatiable or OKI ML320 Turbo-IBM drive you want the emulation set to Epson FX. Or if using the OKI ML320 Drive you want the emulation set to ML.
Jan 15, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Microline 320 turbo won't go into menu mode
just use the buttons, SHIFT+SEL(MENU) with the printer on and you will see the MENU light
Sep 05, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Microline 320
Looks like you can get the non-T manual from the Oki site:
http://my.okidata.com/PP-ML320.nsf?opendatabase
Aug 26, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata ML320 feeding blank sheets
Which IBM driver are you using ? try using a IBM proprinter driver.
Hope this helps.
Dezzi
Mar 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
158 people viewed this question
Top Matrix Office Equipment & Supplies Experts
Dimitar Todorov
ray gallant
Tom Chichester
Are you a Matrix Office Equipment and Supply Expert? Answer questions, earn points and help others
