I have an XACT XTR3. All it does is display "SIRIUS". No response from the remote or buttons except for power.
3 Suggested Answers
  • 3 Answers
SOURCE: satellite radio
I have several 'ghettoblasters' that fit this unit if interested --- Frank
Posted on Sep 17, 2008
  • 4 Answers
SOURCE: trying to connect Sirius Xact Radio
Got to here for direct DL: http://www.xacttechnology.com/getdoc.php?id=37 -or- Here and click on the Documents: XTR1 Manual link: http://www.xacttechnology.com/Sirius-Satellite-Radios-7/XTR1-Sirius-Satellite-Plug-and-Play-Receiver-12.html
Posted on Aug 27, 2009
Unit powers up but display is frozen and no nothing after that. No remote or button response except for display off.
The display microprocessor(computer within your unit) may be bad. This IC is responsible for processing any and all IR(infra red) commands from the remote, as well as scanning all the push buttons on the front of the unit. If you're interested in having your unit repair, please visit me website at audioserviceclinic.com. You may contact me there. Thank you.
Sep 04, 2015 | Pioneer X-smc3-s Music Tap Airplay Music...
How do I get the Sirius ID number to display on my Jensen MSR4115G? Have tried following manual but cannot get it to work.
Go back to where the direct tune display reads 000 and do not touch any buttons. After approximately 5 seconds the display will read ESN followed by a 4 digit number. Be patient it may take a few seconds to display. Write down the four digits then press the Disp button. The last 8 digits of the number will be displayed. You should have 12 digits total not counting ESN. I have the same model Jensen and this worked for me. The Sirius tech line did not have the correct process for this model. Good luck!
Jun 15, 2012 | Audiovox Jensen Msr4115g AmFmCd Stereo
One of my customers has a CMD6 with SIR-CL3 Sirius receiver. When powered up the unit displays "SIRIUS NO TUNER" and then shuts off, powers itself up again, repeats display message then shuts...
I am having the exact same problem with my CMD6. The sirius worked fine with my CMD4, but has the same problem with constantly rebooting when I hook it up to the CMD6. Did you find a solution?
Feb 08, 2011 | Clarion CMD6
Problem with Xact Communication XTR1 SIRIUS Radio Receiver
Turns out the radio isn't broken after all. In my research on your site I ran across a user who said he/she just plugged their radio in, turned it on and waited. I tried that and after a couple of minutes of a Sirius logo screen, then a blank screen followed by a high pitched beep the radio started playing again. I then remembered that one of the last things I input with the remote before the radio stopped working properly was mistakenly selecting an unwanted prompt on the AutoShutDown menu. When the radio finally came back on I selected Factory Default to reset all functions and now it operates properly. Thanks for the help.
Mar 28, 2009 | Xact Communication XTR1 SIRIUS Radio...
Satellite radio
Jul 14, 2008 | Xact Communication XTR1 SIRIUS Radio...
Sirius XTR1 Receiver cycles on dog screen with beep - keyboard locked
Hello, I had the same problem with my xact xtr1 and I was advised by xact that they have no repair process in works and most likely wont. They did say let it run for 10 minutes and once you have a menu switch to factory defaults which proves to be a worthless fix. I would have to pay $39.95 for a new radio...horrible customer service. The bright side is that Sirius will not charge me the $75.00 transfer fee as a good faith gesture. I have decided to switch to another radio and leave the Xact brand out of the equation, if there is no upgrade or modification to the existing equipment why set yourself up for a future failure.
Aug 05, 2007 | Xact Communication XTR1 SIRIUS Radio...
CANNOT READ ANTENNA
I had a similar type problem where i have a lifetime subscription and my XACT VISOR XTR3 unit had a faulty power connection that was driving me nuts. i decided to try and swap out the internal receiver component with a new unactivated unit i bought on ebay. (all the types are out there and pretty cheap even for new)
in opening the new one up i found the only difference from unit to unit is the receiver brain inside the unit, and it is relatively easy to swap out the brain into the body of a new unactivated unit. just four small screws and carefully pull the brain out of the long multi-pin connector. i put the old brain into the new carcass, screwed it back together and it works like a champ. just have some patience in figuring out exactly how your particular unit comes apart, and you will need small screwdrivers and either a small allen-key set or torx set - my old unit had the allen-key screws on the outer case and the newer one had torx screws.
Aug 10, 2006 | Xact Communication XTR1 SIRIUS Radio...
Will not pick up signal
my guess is that in some point u droped it or something like that the problem sounds like a crystal fault and with u cannot do nothing before u send it to fix try opening the device and see if the wireing of the antenna R fine good luck windman
Jan 19, 2006 | Xact Communication XTR1 SIRIUS Radio...
208 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
