Question about Riso Office Equipment & Supplies
I have a Riso EZ 220-U. I have an error message A01-201. I have replaced the master roll. My thinking was there was something wrong with the roll. I have also turned it off and unplugged it. I still have the same error message. Any suggestions?
    New Friend:
Error p986
Posted on Dec 27, 2011
  • 55 Answers
SOURCE: riso 390U error code p19
Error P19-208
Error type P19: Thermal-pressure motor lock Error point 208: TPH pressure sensor does not go ON within 2 seconds after the thermal-pressure motor activates in the decompressing direction.
Hints: Check mentioned sensor. Check mentioned motor.
Posted on Apr 29, 2011
micromatikal
  • 2777 Answers
SOURCE: Riso RP 3700 indicates that the master is still on
It honestly sounds like the unit is going to need some repair work. All the types of troubleshooting possible have been done by the looks of it. It's a hardware problem which is impossible to repair remotely.
You can call Riso at 978-777-7377 to find the nearest service center.
Sorry about that.
Thanks for your patience and understanding,
Tim
Posted on Aug 12, 2009
  • 17 Answers
SOURCE: need to know how to disable rf chip feature on Riso
Short answer: You can't. RISO designed it this way so you need to order supplies from them.
Solution: 1-800-942-RISO to order genuine supplies.
Posted on Mar 30, 2010
  • 97 Answers
SOURCE: Riso gr 3770
- Please check if they have Master Roll Jam?
- Install properly the Master Roll.
Posted on Sep 22, 2008
  • 17 Answers
SOURCE: i have a problem error fo115 of riso rz-220
F01-115 means no master on drum at start of printing. Make sure you make a master before trying to print.
Riso EZ 200E model gives error message A-01 -211
A-01-211 basically means there is master material under the position sensor while in standby. Referring to the manual open the master drawer and clamp rewind the master material back on it roll and close the lid/clamp. This allows the master unit to reset or to say "return home" action. Now open and re-insert the master material in its proper place. This is similar to A-34-218 code.
Nov 07, 2013 | Riso RZ220 Duplicator
Error A-01-211. Master roll not feeding properly.
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
OR replace it
Feb 22, 2013 | Riso RZ220 Duplicator
Riso EZ 570 e "T12-301" error. What is this error
check master disposal box. take it out and check for jams
Nov 01, 2011 | Riso RZ220 Duplicator
Our school owns a Riso RZ machine and theirs a problem with it; the code is A-06 it also has this -403. Could you please help?
our school owns a Riso EZ 200ep machines and their problem with it ; does not want to pull a master roll and give the code error A-06 and -403. Could you please help me on this.
E-mail me; nambwex007@yahoo.com
Jan 04, 2011 | Riso RZ390 Duplicator
I have the d17 error message. I did try to reset it but it still shows the error.
D17
236 - incorect master roll
237 - master roll undetected
238 - master roll communication error
239 - wrong master roll detect
241 - detected a mismatch in master roll information
you must stop the machine and remove the cable from the print drum PCB and check that there is no ink on the connector or the PCB.
If there is no ink try to enter in test mode and activate 0890 test.
If it dose not work call for tech from Riso.
Dec 01, 2010 | Riso RZ220 Duplicator
Riso EZ 200E model gives error message A-34 -218 but all seems fine at master roll installation. What can we try ?
It means to reset the master material in the master making unit. Should be ok after that.
Jul 27, 2010 | Riso RZ220 Duplicator
I have a problem error fo115 of riso rz-220
Jan 20, 2010 | Riso RZ220 Duplicator
My rizo 220 wich cannot pull a muaster roll
Normally when this model does not feed the master,there is a drive band jump off it place n the master drive unit.To correct this open the front panel of the master making unit and check that all the drive bands is in place.I am working 10 years with Riso and this machines is the best I ever worked with.
Nov 26, 2009 | Riso RZ220 Duplicator
Riso Rz 220
Remove the master that is on the drum. Then check the master roll remove it cut about 18 inches off then re install master roll. hit the reset, then print bottons.
Jun 11, 2008 | Riso RZ220 Duplicator
1,155 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
