Question about Singer Sewing Machines
I have acquired a Singer Touch and Sew 600E. I went through and oiled and cleaned it up. Seems to be in pretty good shape; however,I can't get a good bottom stitch. The manual that was with it is for a 628 so it does not have all the info for the 600E. The manual says that the lower tension is set at the factory so there is no lower tension adjustment. Can you give me some pointers on getting the underside stitch set correctly.
    Genius:
  • 1,788 Answers
Usually it is in the top threading to cause the underneath stitch problems. Try this, totally rethread the machine, now with the presser foot up, pull on the top thread, it should feed smoothly, now put the presser foot down, it should barely move. Sometimes that seats the thread in the tension discs. You can download a manual, if you need one, at www.sewingmanuals.com for $10. and keep it on your computer (plus enlarge the diagrams), plus print it.
Posted on Nov 12, 2010
The Singer Touch and Sew 600e is now only sewing in slow motion. Any suggestions?
It appears your machine is a mechanical (Not computerized). If so, it probably needs a good cleaning and thorough oiling.
Your machine has seized due to lack of cleaning and oiling. Might be best to take it for a standard service.
If you have the patience and time, you can try fixing it yourself. It will require purchasing some oil, using a handheld hairdryer, and applying a lot of elbow grease. But if you are persistent, you will probably be successful:
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
In the future, be sure to clean and oil regularly (every 40 hours of sewing, every 6 months if not in use). Use ONLY fresh good quality sewing machine oil, applying 1-2 drops of oil each spot. Consult the owner's manual for instructions.
Dec 21, 2015 | Singer Sewing Machines
How to fix tensioner on singer touch and sew 600e
There is a wonderful website on all the Touch & Sew models. http://www.tandtrepair.com/600TandSstuff.html
Feb 25, 2015 | Singer Sewing Machines
Oiling Singer 626 Touch & Sew
here is a link for a free manual for the machine, it should show the oiling for the machine, if it doesn't then contact singer website to see if the machine is a self oiling sewing machine. http://www.singerco.com/uploads/download/1304_626.pdf
Mar 18, 2014 | Sewing Machines
I have a singer touch n sew model 638. All parts seem to be working, except when I try to sew, no thread is left in the fabric. Also, when I use the pedal, I have to push it pretty far, and when it finally...
Make sure the divot in the needle is facing the bobbin case.
Thread can be wound up in the rear of the bobbin case causing a delayed advance... This is often not visible when bobbin is removed.
Jun 01, 2017 | Singer Sewing Machines
Put top back on my Singer Golden Touch and Sew.
Make sure the faceplate is open and thge takup lever down, hook the hook shape spring over the spindle at a bit of an angle, lower the top and push it to the right.
Mar 07, 2010 | Sewing Machines
It makes a rattling sound when I sew. It has been
If its an older singer featherweight it should sound pretty quiet but if its a newer 221 it has plastic or nylon gears and they can make a "barking" sound
Jul 16, 2009 | Singer Featherweight 132Q Mechanical...
I have a Singer Touch and sew 600E and need to know how to thread the bobbin?
thread the machine up as normal, presser foot up,open the slide plate, push the button over to raise the winder, take the thread from the needle and wind it round a few times round the screw on the presser foot, press gently on the foot control and wind the bobbin, when you have enough thread close the slide plate and draw the threads to the back of the machine and away you go.
Jun 06, 2009 | Singer 3116 Simple
Sewing Machines Logo
211 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
