Question about Ovens
I have a kenmore oven (model 9119359181) that we are trying to find a part 345445 to replace, do you know anyone that still has this part? Our oven is great working order but the temp has to be on 500 in order for the oven to work and other than that it's great...hate to purchase a new oven just for this.
Did you have any luck finding this part? We have the same problem...if you've found a source, please share it!!
Posted on Jan 27, 2011
I have a Kenmore model #40121. I tried to use it today and after it was on for about 15 minutes at 425 degrees it started beeping and flashing F3. I turned it off and back on and about a minute later it...
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 04, 2010 | Kenmore 40192 / 40199 Electric Single Oven
What is button on the left next to plug outlet on kenmore c880???
As far as i can tell by your model there is no button there is only a meat probe receptacle. if yours doesn't have such a thing it is likely to be an after market part. part number for the meat probe is WB20X5050. hope this helps
Thanks
Oct 11, 2009 | GE Profile JTP56 Electric Double Oven
Replacing oven bottom liner for Kenmore oven
about to do the same for a friend - hers has two visible screws through the floor at the back of the oven. the new plate has several additional holes. i have not yet removed the old, but looking at other google entries, i may just need to take out the visible screws.
not sure of the model, but it is a free-standing kenmore gas range.
gary
Apr 09, 2009 | Kenmore Ovens
Broken Bottom Element
Remove the element and take it with you to a appliance parts supply.
They will match it with the correct replacement.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Electric Diagram for Kenmore Model 790
Has the oven run out of control or gotten too hot? The 790 series is made by Frigidaire and those fault codes are F0 to F8. F2 indicates the temperature sensor is reading too hot. Now with the double oven models, some manufactures add an extra digit to the fault codes to indicate which oven created the fault.
Your most likely fix is to replace the temperature sensor. The most probable locations for the wiring diagram is taped inside the bottom drawer, on the back or under side of the oven, or behind one of the panels on the back of the oven. This might tell you the room temperature resistance for the temperature sensor so you can test it with an ohmmeter and be sure that it is faulty. Try Appliance Parts Pros for replacement sensors.
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Oct 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore, F1
I really need to know the make and model but most F1 are a bad control board.. F1 Analog to Digital Failure Disconnect from power for 30 seconds - if display reappears - replace control board
Aug 27, 2007 | Ovens
Oven showing F2 fault
tire, if your model starts with 911. the code stands for an overtemperature condition. I would start with the temp sensor, this is the probe inside the oven cavity, part # 334300. You can ohm it out, should be around 1100 ohms at room temp. This is for model number starting with 911. Catriver..post back.
Apr 21, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
154 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
