What happens when you dont have a filter in the furnace
  • 10,865 Answers
Hello. When you do not have a filter in the furnace there is nothing to stop dust and dirt that the fresh air intake sucks into the furnace from being blown through out your house. Definitely put a filter in the furnace to prevent folks from having allergy attacks and other ailments. Joe
4 thumbs up please. ty.
Posted on Nov 08, 2010
What causes it to emit a fine dry white powder?
If a humidifier is being used, it is dried minerals from the water supply. This happens with household furnace humidifiers also.
Mar 04, 2016 | Intertherm E3EB010H Electric Furnac
How to change filters
Amazon.com: Furnace Filters: Tools & Home Improvement
www.amazon.com > ... > Furnace Parts & Accessories
Amazon.com, Inc.Results 1 - 24 of 25810 - Online shopping for Furnace Filters from a great selection at Tools & Home Improvement Store. ... Clear2GO Grab N Go Replacement.
[PS]Optical Filters - STScI
www.stsci.edu/.../ch3_opticalfilters.ps
Space Telescope Science InstituteThe polarizer quad filter can be crossed with any other filter over the wavelength .....40. Chapter 3: Optical Filters. 3.2. Choice of Broad Band Filters. A number of different... GO programs and the WF/PC-1 and WFPC2 science teams that F336W, F439W, .... .9306 .01366 .007458. Ramp 3 Position. -24.7145 .00598254 .0000.
Nov 23, 2015 | Cars & Trucks
YORK PROPANE 90% FURNACE, Ventor motor runs when furnace turns off, Think switch is stuck closed but need part number
That is all on a circuit board. But I think your furnace is shutting off because of a high limit situation. (they run the vent motor if this happens.)check the filter-don't use a hepa filter. also if the A-coil is dirty it can cause the same prob.
Jan 30, 2015 | Heating & Cooling
Ruud Achiever 80. How do I replace the filter?
if its not on the outside of furnace where cold air duct goes in, and you dont have a high efficency filter, which may not look like what your used to, it will be on the inside of the bottom door where blower is located. If its a standard filter, it should be changed monthly, so you may have a really really dirty furnace and this requires immediate attention to avoid fire hazards and part/blower failure and overall efficency.
Dec 22, 2011 | Heating & Cooling
I changed the furnace filter on my american Standard Freedom 80 filter and now my burner won't light.
does anything happen, i door that you removed might have a kill switch on it so if the door comes off or is not installed right the furnace wont light, let me know and maybe i can help. wally
Mar 10, 2011 | American Standard Heating & Cooling
I install the filters in my york furnance and now heat fan just runs. take out the filters furnace works fine
Did you happen to notice with the filters in a blinking light on the PC Board? You may have to look through a small viewing port in the lower section of the front panel because if you open the filter door, you will erase the code. If you get a blinking code, look at the reverse side of the top front panel for a wiring diagram and diagnostic error code chart. It will direct you to where you should start looking. I suspect you may have registers closed and not enough returning air to the furnace.
Mar 05, 2011 | Heating & Cooling
Furnace goes on red light stays on exhaust fan for heat chamber goes on gas igniter comes on but soon as gas comes on furnace kicks off have to shut off power for furnace for it to reycyckle but same...
Check your filter to make sure it is not plugged. If it is plugged - replace with filter recommended for your furnace. Every manufacture recommends you have your furnace checked and cleaned on an anual basis to keep itrunning safely and at it's top efficiency. If the filter is plugged or the blower wheel plugged, the furnace will shut itself off. Make sure all registers are uncovered - suppply and return registers.
Jan 03, 2011 | Heating & Cooling
The coil in my furnace is freezing up. Can to fast of air flow be the cause. My furnace filter is a inexpensive filter. The gas levels are correct.
The temperature difference across the coil should be between 14-21 deg. Temperature taken near filter and
take temperature above the indoor coil. Not enough
air can cause the coil to freeze-up. Has this always
happened?
Jun 18, 2010 | Heating & Cooling
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
