Question about HP DesignJet 450c InkJet Printer
Media discrepancy with roll feed
Our DesignJet 450c is set up in the software to run 24" roll paper, but is actually loaded with 17" wide roll paper. It does not even have a selection for any other size roll. Do you know of a solution? My next step is to order a roll that is actually 24" wide, but we already stock 17" in house. We would like to make it work. Thanks.
    President:
  • 2,712 Answers
Try resetting the printer properties to default and retry. Or else try reinstalling the driver software and change the settings therein.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Posted on Jun 16, 2008
Roll feed Paper will not load
You need to make sure that the leading edge of the paper is straight.If the leading edge is crooked or angled it will often cause a load issue. Also make sure that the roll is mounted properly on the spindle.h
Jun 26, 2015 | HP "Designjet 111 24"" Wide-Format Inkjet...
Will not load paper
An obstruction for the paper roller could be causing this re fix the paper roll
DESIGNJET 450C SMEARS (BLEEDS) INK
Most likely the media (paper) is touching the print heads. This can occur because 1) the media holding mechanism is not holding the media correctly, and the media buckles, or 2) the carriage to media distance is too small. (Check the adjustment in chapter 5 of the manual).
I found a copy of the procesure online:
HP DesignJet 430 Service Manual Adjusting The Carriage To Media Distance
Dec 21, 2017 | HP DesignJet 450c InkJet Printer
Will not take media. keeps flashing LOAD MEDIA and rejects any paper.....
Your media sensor is faulty. This is not actually available as a spare part. Drop me a mail at davkor@telkomsa.net and I will see if I can help you out. Regards Dave
May 12, 2011 | HP DesignJet 450c InkJet Printer
450 c
Make sure your paper is aligned with the left edge of the rectanglular holes on the right side of the printer paper feed slot
those slots are monitored to check for proper paper alignement and if it is not --it spits out the paper
Jul 25, 2008 | HP DesignJet 450c InkJet Printer
PRINTER DO NOT ACCEPT PAPER ON HP DESIGNJET 450C
I don't know if you are running in sheet or roll media, but we have this problem with roll media if it is not aligned properly. Usually if I release the media lever and pull 10-12" of paper through and align it with itself and with the dotted line to the right of the plotter, then it will accept it. Sometimes takes several tries. Sheet problems may be caused by dirty sensors. Good luck.
Jun 12, 2008 | HP DesignJet 450c InkJet Printer
Designjet 450C
In my 8 years of servicing plotters I haven't seen published specs as far as the paper thickness goes.But from experience and seeing my customers produce problems free plots, you don't want to plot on anything past 30 lb media. 99% of plots are done in the 18-24lbs range. Media Types: Paper (plain, vellum, coated, glossy) Film (vellum, coated, glossy, clear, matte), Translucent Bond for Black output only
Hope this helps
Mar 02, 2008 | HP DesignJet 450c InkJet Printer
Designjet 450C
I would use 24 # max we use/sell this for cad guys w/ no problems
much heavier and you might experience feed problems.
Feb 12, 2008 | HP DesignJet 450c InkJet Printer
HP design jet 450C inkjet Media Error`
Clean the Paper sensor which is down button use to feed the paper & the paper edge sensor on the carriage unit
Jan 09, 2008 | HP DesignJet 450c InkJet Printer
HP DesignJet 450c InkJet Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
