Question about MSI K7T266 Pro MS6380 (MS-6380 V2.0) Motherboard
I can't find my Manual for my K7T266 PRO (MS-6380) MSI Socket A VIA VT8366 motherboard and I need the pin settings layout any manual I find online is not complete where can I find the layout as I am putting it in a new case but can't connect it with out the layout of the pins .....
  • 1,675 Answers
What is the Front Side Bus speed of MSI MS-7312 ver 1.0 motherboard
MOBOT Motherboard Spec Sheet MSI K9MM MS 7312 Motherboards org
THE LINK ABOVE GIVES THE SPECS
MSI K9MM-V (MS-7312) Spec Sheet Powered by MOBOT 10428.jpg Part Number K9MM-V (MS-7312) Manufacturer MSI Price Check Find Best Price Downloads BIOS
Drivers
Manuals Chipset VIA K8M800 VT8237R+ North Bridge VIA K8M800 Socket Socket AM2 (940) Processor Types Athlon 64X2, Athlon 64FX, Athlon 64 Number of CPUs Front Side Bus 800MHz HyperTransport Bus Link Memory Type DDR Memory Channels Dual Maximum Memory 2GB External Graphics AGP8X IGP VIA UniChrome Pro South Bridge VIA VT8237R+ Audio 6-channel IDE SCSI None SATA 1.5 GB/s RAID LAN Firewire None USB USB 2.0 Expansion Slots BIOS AWARD Form Factor microATX
Jun 05, 2014 | MSI K9MM-V Motherboard
IDE devices not detected
daer customer check ahci mode (pata )mode will be check & your problu is solve.
Mar 02, 2012 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
Diver/K7T266 PRO (MS-680) MSI Socket A VIA VT8366 motherboard
if these units are pata ( parallel ATA) units, make sure they are set as masters or slaves which do not conflict with any other items on the same bus or cable.
If you have the hard drive on the same bus, make sure it is set to master and the optical drive is set to slave.
If these are SATA units, try swapping them onto another drive bus.
If this fails, have the units checked on another PC. This will confirm that the units are good and working, if they are not detected on another PC, then they may be faulty.
If you are using Windows 7, check for an updated driver and install it as W7 has a habit of ignoring older peripherals.
Feb 14, 2012 | MSI K7T266 Pro MS6380 (MS-6380 V2.0)...
K7t266 pro2 ver:2 the mother board can't be powered on. Could some one tell me how to check it ok please
When your motherboard/CPU board CMOS battery dry or have charge then you can not run to power *********** board.Or CMOS is disable.Please check
1 Power supply
2 CMOS Battery
Mar 15, 2010 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
My c media ac97 audio device wil not start
Check the Device Manager for driver errors. The error code will signal the type of problem. But in most cases reinstalling the driver will help.
Mode tips: http://www.pcauthorities.com/pc-errors/no-audio-device-in-windows
Jan 28, 2010 | MSI K7T266 Pro MS6380 (MS-6380 V2.0)...
Pinning layout for Micro Star WS 6330 motherboard
Hi Hunter45,
Download the manual from MSI, click on the link below.
MSI K7T Pro MS-6330
You'll need winrar or winzip to uncompress the manual & you'll find there are 5, *.pdf files rather than just one for the hole manual.
http://global.msi.com.tw/index.php?func=searchresult&keywords=K7T+Pro&table=download
File name: 6330-1.PDF will show the MB layout. Page 1-4.
You ca see the 2 USB pins to the left of JMDM1.
JFP1 close up;
Open file 6330-2.pdf, page 2-22 for the pin layout for the MB USB's.
If you need more information, post here.
Good luck Hunter45!
Thank you for trying FixYa.
Mike
Jan 19, 2009 | MSI MS-6330 Motherboard
Msi motherboard
use the booklet that came with the MOBO...i used it and it was pretty user friendly...the acronyms on the MOBO will confuse you
Sep 14, 2007 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
Trying to fix old computer
Disconnect the drive and see if your video card works. If not, something else is broken. Could be the video card, the motherboard, processor or power supply. It is possible for a power supply to fail in such a way that it destroys everything connected to it. If that works, you have made some mistake hooking up the hard drive or it is badly damaged. Hard drives have jumpers that must be set correctly to indicate whether it is a master (1st drive on the ribbon cable) or slave (2nd drive on the ribbon cable). The ribbon cable must be correctly oriented with the red strip going to pin 1 (pin 1 should be marked in very, very small print on the drive's connector).
Sep 10, 2007 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
Computers & Internet Logo
327 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
