Question about Panasonic Lumix DMC-ZS3 Digital Camera
My Lumix DMC-ZS3 pictures are just about always out-of focus in any mode. I have cleaned the lens and have made tests beiing very still. No difference; always out of focus. Might it be broken? Tks
    Brigadier General:
  • 11,967 Answers
First, make sure you haven't accidentally left the camera in AF Macro or Macro Zoom. Make sure the stabilizer is on and set to Mode 2. You probably know to press the shutter button half-way and allow the focus to "lock" (it will beep) before pressing the rest of the way. Fire off a few test shots....any better? If not, then you may have a lens problem. the lens may not be extending normally. If that's the case..try these:
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 08, 2010
Can I use my Digital Camera Lumix DMC-ZS3 as a webcam?
REF: https://www.techwalla.com/articles/how-to-use-my-lumix-dmc-fp2-camera-as-a-webcam An unknown fact is that many digital cameras can be used as webcams. The digital camera needs to have a line-out feature as well as a video feature. If you own a Lumix DMC-ZS3 camera, your camera already has those features. With a few easy steps, connect your Lumix to your computer and use it as a webcam. There are no other items needed other than your camera and USB cord.
Step 1 Connect the USB cord to the output of your camera. Connect the other end of the USB cord to an open USB port in your computer. One end of the USB cord fits into the output. The other end of the USB cord fits into the USB port of your computer.
Step 2 Open the lens cover that turns on your camera. Slide the lens cover to the side to open.
Step 3 Press the "Mode" button on your Lumix camera. It is located next to your LCD screen.
Step 4 Press the "Down Arrow" button until you reach "Motion Picture" mode. Click on the "Set" button on the "Motion Picture" setting.
Step 5 Open the program or online site on your computer. Select your Lumix camera as the video source for your program or online site.
Oct 10, 2017 | Digital Camera Cameras
I have black spots on my Panasonic Lumix DMC-ZS8 lens camera
If you want to know if these spots are on the sensor. Or you want to exclude this, You could try this:
Put the camera in A priority. (manual mode). Turn the aperture to the highest setting. Greatest figure like f 22 I can't find the exact figure. It could be it is only 8. Then in a bright light, take a picture of a white sheet of paper. The picture that comes out, should be checked on dark spots. If they are there the spots are on the sensor. If you can't find the spots on the white picture, something else is wrong.
Feb 12, 2014 | Panasonic Lumix DMC-ZS3 Digital Camera
Camera appears to have a poor autofocus, images are consistently blurred and out of focus, worse in artificial light but similar problem in all conditions.
If the camera works well with the manual mode then the possibility of the auto- focus section being faulty needs to be checked. it can be an issue with the drive within the lens unit that is not correcting the lens to focus.
remove battery and tap on the lens hood on your palms, replace battery and switch on to see if there was any change. repeat to see if the drive gets corrected, if not the camera must be opened up to confirm if the sensor or the lens mechanism is faulty.
Oct 19, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
Panasonic Lumix DMC-ZS3 When I focus the camera
hi
you have a problem wtih the photo shutter of camera
you must replace it
the cost of it is to high you better replace the camera
Jan 09, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
Lumix DMC TZ10 Dust in lens. Is there a solutions for internaly cleaning the lens. I read that this is a more common problem for this camera. Are there solutions to prefent this? I always use a case to...
The only way to clean the lens internally is by disassembling the camera. As this is difficult and easy to damage the camera if doing yourself or expensive if sending for repair, I would leave it unless it is causing bad problems with the picture. You could try putting the camera in a ziplock plastic bag before putting inside the case to keep dust out.
Jan 02, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
My Panasonic Lumix® DMC-ZS3 will not focus properly. All pictures are blurry. Anyone know what might be the problem?
Try checking your settings or menu for a vibration sensor or changing the focus. You might also be using the wrong setting, like indoor, when you're at the beach. You can also change the quality of the pictures and if you are taking still photography or movement.
May 31, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
Lumix DMC-FX33. Keep on getting "Please turn camera off and then on again" over and over again. Occasionally I can focus and take a picture and the camera works for a day or two. Then the problem...
I have the same problem. It resulted when we used the camera is windy conditions with very fine sand blowing around. Some of those grains are lodged in the automatic lens cover and in the autofocus/zoom mechanism in the lens. I can actually hear the grinding as the camera tries to open.
Now, how do I fix it?
May 06, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-ZS3 Digital Camera Logo
594 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
