Question about GE JKS05 Electric Single Oven
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to correct this difference?
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Posted on Jan 28, 2011
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
Ge gas oven jgbp28dej3ct.. oven pre heats good to right temp but wont maintain temp during cooking.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 29, 2011 | GE 30 In Freestanding Gas Range ...
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
I am attempting to pre-heat oven to 400 degrees but oven heat will not raise above 100 degrees
Hi, Upon reading your post I immediately thought of a bad ignitor for the oven, but I am not sure whether you have a gas oven or a conventional electric range. So...If it is gas, I'd suggest replacing the ignitor for the hot surface ignition. If it's electric the bake element may be at fault although most range's use the broil in the preheat, so it should still climb up to 400, it would just take a really long time. Maybe you can clarify if it's electric or gas and I can try to move you forward from there. Macmarkus :)
Dec 09, 2009 | GE Ovens
NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Jun 25, 2008 | GE Profile JT912 Electric Single Oven
GE JKS05 Electric Single Oven Logo
212 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
