Question about Pyle (PLBW124) Car Subwoofer
Negative and positive termanals not marked on speaker for instqllation does it matter?
Easy fix. all you do is connect the wires to the speaker then touch the other end to the car battery quickly when the speaker pops outward the positive and negative on the battery will determine the speaker positive and negative. hope i explained it well enough so that you understand. good luck
Posted on Nov 09, 2010
  • 23 Answers
It matters. Get a 9-volt battery and touch it to the terminals. When the positive side of the 9-volt is connected to the positive speaker terminal, the cone will pop out. If it pops in, then the positive side of the battery is touching the negative speaker terminal.
NOTE: A subwoofer should be strong enough to handle this. If you try this with a small speaker you can damage it!
Posted on Nov 08, 2010
Testimonial: "Sounds logical thanks for your help."
Which side is positive on a ts a1365 speaker?
Take a 9 volt battery, 0r Evan a 1,.5 volt battery will work, Hook up to the termanals on the speaker ,When the cone draws in ward you no you have it hook up right,
Dec 05, 2012 | Pioneer TS-A1365 Car Subwoofer
Speakers don't work quite right
Check first to make sure impedance marked on speakers is same as original---two sets of positive and negative terminals suggests original ones were dual element speakers----
If for example original were marked 8 ohm and you put 16 or 32 ohm speakers in----volume will be greatly diminished and even distorted.
This is only a suggestion as I do not know what original speakers were or what new ones are----but the key is originals had two sets each of connections.
May 18, 2012 | 2002 Oldsmobile Alero
I have two wires going to my speakers for a 2007 silverado classic, brown & yellow? What is positive & negative
It doesn't actually matter unless the speaker is grounded on one terminal, however if you do get it backwards, you will have audio interference which may make things sound strange at times.
The general rule though is that the brighter color is positive, and the darker is negative.
This goes pretty much for any wiring system for speakers.
Apr 11, 2011 | Car Audio & Video
Which side of the speaker is positive and negative
the fine terminal is the positive and the broader is the negative if it is not marked on the speaker + and -
Mar 05, 2011 | Lanzar VW15D Car Subwoofer
Have on old set of Pioneer TS-X150 car speakers. Trying to figure out which wire is positive and which is negative. Typcially red is positive and black negative, right? However on the speakers I have...
it doesnt matter which way you connect them as they are only a coil when all is said and done at the end of the day ,their will be no loss of performance with the wires either way around ,l would imagine the grey and white is the earth but it doesnt matter
Feb 19, 2011 | Pioneer TS-X150 Car Component System
Which terminal is positive and negative on Pioneer car speakers. thnaks Shane
Look closely at the terminal of the speaker, the size is different from positive and negative.
The bigger terminal should be positive( + ) with a stamp mark on the terminal itself.
The small one should be the negative ( - ).
Hope that helps you!
Thanks for using Fixya!
Dec 11, 2010 | Pioneer TS-A6955 Coaxial Car Speaker
I NEED THE SPEAKER WIRES IDENTIFIED ON A 1992 LINCOLN TOWNCAR. LIKE WHICH WIRES ARE FOR WHICH SPEAKER: LEFT FRONT, LEFT REAR, RIGHT FRONT, RIGHT REAR. & WHICH IS POSITIVE & WHICH IS NEGATIVE.
If you have access to all the wires you can find which is which with a 1.5 volt battery. just place 2 wires at a time on the battery terminals until you hear a small crackle in the speakers. If you can see the connections on the actual speakers they usually have 1 large connector and one small one. The large one is positive. Some are actually marked "+" & "-" Check the wires on a couple of speakers, if they have a stripe or some sort of marking on one wire they will all be similar.
I.E. all positives wires will be marked/striped or all negatives will be marked/striped.
Hope this helps.
Oct 10, 2009 | Car Audio & Video
Im changing factory radio to jvc and cut wires which ones are power source
here is a wiring color break down.
1987 Lincoln Mark VII Car Radio Wire Guide
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Pink/Blue
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Blue/Orange
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
please rate my help.
Jul 26, 2009 | 1987 Lincoln Mark VII
Negative and Positive markings missing on car stereo speakers one connector requires a larger clip than the other, can this make it possible to tell if one or the other is a pos or neg connection. If so...
The speakers have to be polorized. If you take a small battery and put the negative to one terminal and the positive to the other you will see the speaker push out or pull in. Just tap the battery connection to the speaker. The one you see the positive of the battery push the speaker out will be your positive side or terminal. Make sure you mark a + sign on all the speakers to get uniform polarization.
Feb 05, 2009 | Digital Audio DA8012 12" Subwoofer Car...
Pyle (PLBW124) Car Subwoofer Logo
388 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
