How to set up a time guard ETU2000 timer - Heating & Cooling
Looking for some help with my TimeGuard ETU2000. I'm not getting any hot water whatsoever, tried boost, reset, resetting timed hot water all that but still no hot water, in fact I kept the main switch button so that it heats up water but no joy till date. Please advice anybody out there..
Posted on Dec 09, 2011
How does a smiths time guard timer work
if new check wiring if old bad board in it
May 06, 2014 | Pool & Spa
Red light off on time guard , hot water not coming on
Lets try a general answer. A time guard is a feature that prevents a unit from short cycling. This, as well as a lot of other data is programmable by the user. Repeatedly pushing the set button will scroll through all the adjustable options. Pick what settings you want at each window then press "RUN" to lock it all in. Hope this helps you.
Dec 02, 2013 | Honeywell Programmable Thermostat Heater
Nokia C6-00, I have disabled the Autokeyguard, still the phone is getting locked automatically at a very short interval.
Hi, there are two options for you to lock your cell phone under "Key Guard Settings", One is the "Automatic Key Guard" where you can set the delay time to lock the phone, and the other one is "Key Guard Code" where you can set a password every time you wish to unlock your phone. I think you have only disabled the Key Guard Code, please try turning OFF the Automatic Key Guard. I hope this helps.
Thanks for using FixYa.
Sep 08, 2011 | Cell Phones
Dryer cuts on run a minute starts buzzing loudly and shuts off then a little while later starts by its self
DOES THIS DRYER HAVE A WRINKLE GUARD CYCLE OR SWITCH THEN THIS IS NORMAL ASLONG YOUR IN A WRINKLE GUARD CYCLE ON TIMER OR WRINKLE GUARD SWITCH IS ON
Jan 26, 2011 | KitchenAid Dryers
I have an old intermatic (1983) freeze guard that I am trying to wire into my pump timers. 4 wires are 2 for load and 2 for line in. 2 orange and 2 red. WHICH COLOR IS THE LOAD AND WHICH COLOR IS THE LINE...
There is not a set color code when it comes to that stuff. If the timer is still connected and there is power to it, turn the manual ON/OFF lever inside the timer to the OFF position. Using a volt meter set to at least 240 volts, test the wires. The set of wires that are still hot are the LINE wires.
If the timer has altready been removed, you'll have to _carefully_ separate all the wires so that they aren't touching anything and re-energize the circuit from the breaker. Then test the wires. The 2 wires that are hot after re-energizing the circuit will be the LINE wires.
Mar 16, 2010 | Intermatic Electrical Supplies
My dryer will automaticall start the auto dry
appears that timer is not timing out or shutting off at end of cycle.correct ,the timer itself appears to be the problem.
Oct 16, 2009 | Dryers
My Timeguard ETU2000 timer sometimes seems to get lost and continually switches on/off. This seems to happen after I use the 1hr or 2hr or continuous on functions. Does anyone know how to reset this...
hi there im having problems with my timer imersion and came here looking for awnser of my own lol any hows just seen your question and if you want to reset the unit completly ive found that press and hold the black setting button in at the same time hold the white program button in so basic hold both buttons in at the same time watch the screen display and you will see it display all the digit featuers when you see that release and its reset hope this helps you
regards mike
Sep 18, 2009 | Hardware & Accessories
Replaced timer, new one stops turning and doesn't turn dryer off.
Some dryers have a "press guard" setting. This willkeep the dryer tumbling with no heat at the end of the cycle. Usually you can select it on or off and in some cases can set the time. see if you have this feature.
Apr 07, 2009 | Dryers
Moisture Sensor Location
It could be the sensor. However, check the exhaust vent for restrictions first. you can test the moisture sensor Damp Dry Test 1. Set the following Timer- DAMP DRY Fabric Care/Temperature switch- COTTON HIGH Wrinkle Guard switch- OFF Signal switch- LOUD Door- must be closed 2. Press the PUSH TO START switch. After approximately 16 seconds, the Timer will start to advance to the OFF position, and the ?End of Cycle? signal will sound. If one or more of these functions do not occur, proceed to the Factory Test. Factory Test The Factory Test allows factory/service personnel to test and verify all inputs to the Even Heat control. The basic operation of this test is to notify the operator with an audible beep every time the status of an input to the control changes state. Activating the Test Mode 1. Set the following configuration: Door- must be open Fabric Care/Temperature switch- AIR FLUFF Signal switch- LOUD Timer- TIMED DRY OR AUTO MOISTURE SESING PLUS selection 2. Turn the Wrinkle Guard switch from OFF to ON three times within a five second period. A single beep will sound to indicate that the factory test mode is activated. NOTE: If any of these initial conditions are not satisfied, the control will not enter the test mode. Test Mode Functionality When the control is in the Factory Test mode, every input change of state will result in a beep (with the exception of the Signal switch). This includes: Door switch Moisture Sensor (short/open Sensor will result in a beep) NOTE: A moistened finger or damp cloth may also be used. Fabric Care/ Temperature switch Wrinkle Guard switch Push to Start (PTS) switch (with the door switch closed) Timer (any cam input change will result in a beep) NOTE: Timer will advance during test. If any of the inputs do not result in a beep, proceed to the following component tests If the dryer shuts off too soon when set to the AUTO MOISTURE SENSING PLUS cycle, check the following: -HARNESS/CONNECTION -MOISTURE SENSOR -THERMISTOR -EVEN HEAT CONTROL Procedure: 1. Test the Moisture Sensor by following the procedure outlined in ?Factory Test?, beginning on page 3. If the Moisture sensor fails the ?Factory Test? (does not produce a beep sound), check the Moisture Sensor. a. If there is continuity to Ground for Yellow/Red (Y/R) wire with no load, look for a short in the Sensor or Y/R wire. Verify harness connections both at the Sensor and the Even Heat control. b. If the Sensor and Y/R wire are good, replace the Even Heat control. 2. If Factory Test passed, verify thermistor by performing test procedures outlined in ?Thermistor Test? 3. If problem persists after replacing Moisture Sensor and thermistor
Aug 27, 2007 | Kenmore 62972 Electric Dryer
Heating & Cooling Logo
305 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
