Question about Rowenta DM990 Iron
My wife needs a user's manual for a Rowena 990e. Are any available?
Fix Rowena iron with retractable cord
I would contact a small appliance repair business near you, they can supply the needed cord and the repair for very little money I would think
Sep 23, 2016 | Irons
No steam coming out my Rowena DG8960,but the water is been used in the tank.
It could just be blocked. To unblock you can pour vinigar in the iron, then switch on as normal. Put iron to cleaning mode if it has the option, or else tilt the iron to let it start steaming. The vinigar should clear the blockage and iron should work normally if the internals are not damaged.
May 04, 2016 | Irons
Need parts manual and wiring diagram
there are several sites and you really need to be more detailed on what product that you need a manual for. The bottom line is most of the time just go straight to the vender or manufacturer of the product. For example if you needed a manual on a 2015 ford Tarus you would go to www.ford.com. If you needed a manual on a Huffy Bicycle you would go to www.huffy.com. Good Luck.
other resources:
Product Manuals Retrieved
Free User Manuals and Owners Guides ManualsOnline com
User Manual Product Guide Download
May 29, 2015 | Irons
My rowena precision steam iron steam does not work
Solution for me:
I just bought a Rowenta Precision for $5.95 at Goodwill. I brought it home and it didn't work
I read about the cords and weird size screwdriver needed. It sounds like a lot of work. So what I did was push the electrical cord into the iron. it didn't seem to move but must have. The iron works perfectly now. Such a deal!
Mar 05, 2011 | Rowenta Precision DM580 Iron
Rowenta Iron-Professional Luxe The power cord seems to short out when you move iron. You can wiggle it next to the movable ball and it clicks on and off. The two screw heads on bottom appear to be special...
I drilled out the nubs in the center of the screws. removed the screws, and took off the back plate. The problem is that the cord seems to be abraiding when it swivels, and eventually wears thru. It seems like a fire hazard and should be looked into by Rowena. Anyway, I cut out the damaged cord and reattached it. Problem fixed..
Oct 22, 2009 | Rowenta Irons
Need a User Manual
my home touch ps200 has the reset button that wont reset ?
Oct 10, 2009 | Irons
Rowenta DZ5080 iron -lost manual - how do you go about the "self-clean" ?
I actually found the manual online - copied the pages needed for my wife to confirm how to perform "the self-clean". Took a while surfing but worth the time. Thanks.
May 11, 2009 | Rowenta DZ5080 Iron with Auto Shut-off
My grandson knocked my Rowena Iron model DE-87.1b
go to the store get a 2 part epoxy glue follow the directions and mix the glue put it on both the knob and the part the knob goes on wait untill the glue gets tacky then put the knob back on wait 24 hrs. before you use the iron so that the glue can set
Apr 24, 2009 | Rowenta Irons
Irons Logo
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
