Question about Samsung LN-T4671F 46 in. LCD Television
When turning on the tv it takes a long time and you can hear it clicking trying to come on
    Novelist:
    Champion:
  • 225 Answers
Sounds like the early stages of an eventual power supply failure. Start asking around for a reputable repair shop in your area.
Posted on Nov 08, 2010
Popped lamp, rapid clicking after replacement
Take it out and get in there with a vacuum. There are fans that keep it cool and there is a color wheel that might be damaged. All those shards need to be removed
Jan 22, 2014 | Mitsubishi Diamond WD-65831 65" Projection...
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Why does my tv take a long time to turn on? it takes like 2 or 3 minutes and i hear a clicking sound while it tries to turn on.
There is problem with power supply capacitor in the line of 5Voltage you need to replaced. Check part number on it replaced with same number.
Oct 28, 2010 | Samsung LA40A450 40 in. LCD TV
Tv takes 20 minutes to turn on, keep hearing a clicking sounc
Ur tv the Ballast board the help to turn on the tv projection bulb is dead.Try website like Tvrepairworld.com to buy the Ballast board for the replacement.The Samsung/Akai tvs use the same Ballast board.When in the website go to the menu that said Samsung/Akai circuit boards.Pick that option click on it,u will see a picture of a Ballast board look like.
May 31, 2010 | Samsung HCN4226W 42" Rear Projection...
Tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Feb 14, 2010 | Panasonic TC-32LX700 Television
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
Hyundai plasma model HP-4200
Hello ****, I have the same problem. However. I manage to get the TV on by pulling the cable out and then plug it back in again several times. A couple of times just after you have heard the first click and the a couple of times just when you hear the second click. Sudenly the TV decided to work again. I think it must be a problem with one of the two relays that sits next to each other near the centre of the TV. If you take the back of and then plug the power back in you will see the two lights next to those relays come on and then die out when the relays let go. This is what hapens if the TV doesnt work. If the TV works those lights/LED's will stay green and the relays will hold on and feeding the TV screen. I will probably try to see if I can buy replacement relays and replace these. If I can get hold of them, then probably I would take the existing relays appart to see if I could see any fault. If those relays ar ok and the replacement relays appear in the same manor like the old ones I would look for problems before those relays. Maby order a new circut board from Samsung.
Con
Jan 08, 2008 | Televison & Video
Panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Dec 29, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Samsung LN-T4671F 46 in. LCD Television Logo
76 people viewed this question
Henry  Thomas
Henry Thomas
