Question about Garden
Need steps 1-6 for a VST Oil Kit Husqvarna / Peerless Part number 799030
Peerless faucet sometimes won't turn on
It sounds to me like the rubber o-rings are getting old. Try posting your concerns on the Peerless Customer Support webpage. They can help you identify the model of your faucet and what repair kit to purchase. (Repair is fairly easy, the faucet is repaired in-place).
Customer Support Peerless Faucet
Apr 16, 2014 | Peerless Industries Peerless& Single...
What is the fuel mix for 359
hi there troyandbec
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Husqvarna Chain Saw Maintenance Kit 357xp ...
I am needing a manual for an 18: Husqvarna chainsaw. Serial Number 3490744. Need to know what type of oil, etc. to use in it. Thanks
We cannot answer without a model number. You can find what you seek here (if a model 18 it very old; please use the second link):
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Husky recommends 50:1 today (last 15 years ±)
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jun 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
, No.455 Rancher, 20" Gas - Powered Chainsaw: What is the oil mixture ratio for the Rancher 455...
50: 1; You can download an OM here:
HusqvarnaUSA.com
06 1500198
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years and is what Husky suggests for your saw..
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
Lou
May 10, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Turning up the bar oil?
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
An excerpt from page 38 of the above OM follows (forcing it may render it inoperative):
Adjustment of the oil pump
Adjustments are made by turning the screw using a screwdriver or combination spanner.
The machine is supplied from the factory with the screw set to position 2.
Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow.
Recommended settings:
• Bar 13"-15": Position 1 (full CW)
• Bar 15"-18": Position 2 (center)
• Bar 18"-20": Position (full CCW)
These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step.
WARNING! The engine must be stopped when making adjustments.
All OMs and IPLs can be found here:
HusqvarnaUSA.com
06 1500198
Lou
Apr 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna model 50 chain saw and am not sure of the ratio of the oil & gas mixture.
Husqvarna Rancher 50 1982-11 OM Follows:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS1982/HOUS1982_O8200003.PDF
50:1 according to your manual if using Husqvarna (quality) 2-cycle oil.
HusqvarnaUSA.com
06 1500198
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 01, 2010 | Husqvarna Forest & Garden No.967012396 345...
What is fuel oil mix for the 136
Page 8 of your manual says 40:1 (3.2oz/1gal) Stihl or Husqvarna 2 cycle oil.
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Oct 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Ive just bought a husqvarna 34 husky is this the model number 34? its serial number is 016810 but i cannot find details of it anywhere an want a manual can you tell me mixture also its my first chainsaw,...
Get Chain lube for the chain oiler. Naturally, husqvarna recommends that you use "genuine husqvarna" oil for your mixture, I recommend a quality oil, doesn't have to be husky. Husqvarna recommends a 50:1 ratio, other manufacturers, of vertually all 2 cycle power equiptment use a 40:1 ratio. This mixture is slightly richer, but will not hurt your chainsaw. May produce a bit more smoke. Not sure what a 34 husky is...neither is Husqvarna, I visited the website and even tried to download a manual. Looked at every husky model, no 34.
Jun 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a peerless tub diverter and I need to replace it because it leaks. Where can I find a replacement unit?
the kit to rebuild the peerless diverter is very common. take the cartridge to any hardware store and ask the plumbing clerk to assist you in getting the correct kit. good luck
Jan 19, 2009 | Peerless Industries Peerless& Single...
Cubasis vst version 5 serial number
If you go to
http://www.steinberg.net/en/support/steinberg_support_creative_tools/cubasis_vst_faqs.html
you will find a serial number for Cubasis VST version 5.
Hope this helps.
Feb 15, 2008 | Computers & Internet
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
