Question about Garden
I have a Skil Wrench Model #2238 Type 2 120 RPM 3.6 volts I've used it many times and now I have no power light out of the charger and trhe wrench does not work at all. I love the tool but I need to use it. Can you help? Had it for at least 6 years.
I've the same problem. It's the battery inside. Due to the age the battery died. It's a special one with special dimensions. My tip: if you like it, buy a new one ...
Posted on Dec 13, 2010
  • skil wrench Apr 30, 2011
    (if you don't want it you can send me a e-male at iamsotweeky@yahoo.com for farther information e male me.
I had the same problem with mine. I used a voltmeter to check the output of the charger and found that there was none. I then used a Dremel tool and cut open the power cube. I found that the transformer had burnt up. My battery in the wrench had shorted and caused the charger to burn up. I couldn't find a new charger but I was able to find a power cube with the right voltage output. The original output was 5VAC at 300 ma. I found a 5VAC at 400 ma. It was an Atlink branded power cube. I found a battery at Interstate Batteries that is listed as a replacement. It will have to be soldered in. I now have a working wrench again.
Posted on Dec 09, 2012
Take it aprt carefuuly. remove thr crappy old nicad pack. drill a small hole below the plus terminal point, solder in a JST female connector that exists outside the wrench. I then Velcro on ANY 1 cell LIPO RC pack. Brings new life to this tool.
Posted on Jan 06, 2013
  • r_veach
    r_veach Jan 06, 2013
    take it aprt carefuuly. remove thr crappy old nicad pack. drill a small hole below the plus terminal point, solder in a JST female connector that exists outside the wrench. I then velcro on ANY 1 cell LIPO RC pack. Brings new life to this tool.
Cooling fan stopped working
any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Jan 04, 2014 | Sony Vaio PCG 7Q1M Laptop Universal AC...
The charger that comes with Homelite 24v mower is crappy. I've gone thru 3 of them. What's a better alternative?
I have used a DieHard portable battery charger (model 200.71222) for several years to recharge my 24-volt, 18-year old Craftsman mulcher, model 315.370270. This is after the on-board charger died. I just disconnect the link between the two 12-volt batteries and remove all other battery connections. Then connect the charger leads to the positive and negative terminals on one of the batteries before plugging in the charger. I put the settings on the charger at conventional low maintenance and 2 amps. Charge one battery and then the other (assuming you have two 12-volt sealed lead acid batteries like my mower). I use binder clips 530-t.jpgfrom an office supply store to hold the battery wires on the terminals when I'm mowing...makes it simpler to remove and reattach for charging instead of the nut-and-bolt connectors that came with the mower.
May 14, 2012 | Garden
I have a Skil Model 2363 drill. Used it about 3 times. Put it in the charger and it won't charge. I have it for about 1-1/2 years. Skil says I have to buy a new one. That the battery is no longer made....
Sometimes places like Batteries + and the Battery Barn (on line web sites) will have replacement batteries for popular models even after the manufactures quit producing them. That is where I found batteries for my Bosch drill.
Jun 24, 2011 | Skil 2362 02 7.2 Volt Lithium Ion...
What is the motor rpm on a skil 3385-01 rt table bandsaw?
This Band Saw is designed to use a 1700 RPM motor. It
is wired for operation on 110-120 volts, 60 Hz.
Taken straight from the Owners Manual found here.
https://mdm.boschwebservices.com/MDMCache/English%20[US]//t10/0000001/r01047v-1.pdf
Let me know if you need anything else!
Nov 24, 2010 | Skil 3385-01-RT Factory-Reconditioned 9"...
Charged it and it stopped working
Here is the link to Skil. http://www.skiltools.com/en/CustomerService/ServiceCenters/
Call them and see what they recommend that you do. They will want to keep you as a valued customer. Regards, Joe
Jan 25, 2010 | Skil 2362 02 7.2 Volt Lithium Ion...
Where is the blade lock button on a skilsaw 5150 2 1/8hp ???? i can't get the blade off and turning the saw bolt the same direction as it spins isn't working.
First, there is no blade lock button on the Skil model 5150. I called the Skil customer service and they emailed me the exact manual for this circular saw. The method I used to loosen a VERY TIGHT blade stud was: spray with WD-40, imbed the blade in scrap wood, set Skil wrench (usually found in back of foot under handle) on so it could be struck going in counter-clockwise direction. Use hammer to strike handle of wrench a couple of times. To replace blade, finger-tighten blade stud, then use wrench to tighten 1/8 turn or (45°).
Jun 25, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skil charger & batteries won't charge
The only thing I suggest is taking your Skil driver to a Bosch service center (Skil is now owned by Bosch) and they will replace the charger under warranty if the driver is less than a yr old. If not those chargers are not that expensive. Either way you need a new charger because they are not repairable.
Jun 10, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
Skil cordless drill model 2362 - won't charge
I have the same problem. The guys at Batterries Plus told me that 7.2 volt battereis are not easily replaced and definately not through them. If you left it charging for to long (ie over a week when you were gone like me) then the battery is never gonna charge again. You might as well find the same model of dril at skil's reconditioned site for around $40 or buy a brand new one for $60 or $70
Mar 30, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
Need to send Skil power wrench in for repair
OK the nearest one to Hayward is the Factory Service Center located at Bosch/Skil Service Center 4980 Landon Dr., Anaheim CA 92807 or call toll free 1-800-346-4103. You can also go to Skiltools.com and type in your zip code to find the nearest authorized center within a specific radius. Hope this helps
Jan 31, 2009 | Drills
SKIL 18V BATTERY PACK
There are three visble screws and one hidden. Use the right size torx driver if you have it, or a small allen wrench works too and undo the screw that is visble on one side of the pack. Snap the false bottom off of the pack and reveal two more screws to remove. One screw is behid a plastic cap over a fourth obvious screw location. Drill the cap and unscre this screw also. Be sure there are no lables holding the two side together. Pressing down on the battery holdin clasp makes the sides easier to separate. Watch for falling parts. That's it!
Nov 28, 2008 | Skil 2887 05 18 Volt 2 Speed 3/8 Inch...
Garden Logo
1,811 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
